open or short in engine wire harness p0302
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by freebird1, Nov 11, 2021.
  1. freebird1
    freebird1 Junior Member
    59
    Dallas, TX
    2010 prius gen 3 ,check engine light on,car does get into ready mode drives
    Im getting this code today open or short in engine wire harness p0302
    replaced all 4 spark plugs and coil also replaced on P0301 code before
    also car shakes turning right in motion ,could be another issue
  2. JC91006
    JC91006 Senior Member
    16,743
    8,551
    How many miles on the car? That code means there's a misfire in cylinder 2. There could be mutiple causes for that error
  3. freebird1
    59
    Dallas, TX
    yes codes not reliable as older car ,or other issues
    getting random before 301 fixed with change coil and all 4 sparks but still got again 301/302/303/304
    after long drive today got check engine light and 302
  4. JC91006
    16,743
    8,551
    unfortunately that sounds like you have bad fuel injectors or a bad head gasket. These cars are well known for headgasket failure at around the 200k miles mark.
    freebird1 likes this.
  5. Mendel Leisk
    41,023
    There's unsubstantiated rumours here, that 3rd gens with those miles are prone to head gasket failure, typically at cylinder one or two, if the EGR (Exhaust Gas Recirculation) circuit, incluiding the Intake Manifold, has not been cleaned of carbon build-up.
    I'd try a leak-down test to see what the head gasket condition is.
    Also, is engine coolant reservoir level stable?
    I'd get on the EGR cleaning ASAP; more info in my signature.
