Gen 1 PIP hybrid battery replacement
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by southsidedakota, Oct 16, 2021.
  1. southsidedakota
    southsidedakota Junior Member
    27
    22
    Anyone replaced their hybrid battery yet?
    I have 206k miles on my 2013 and I'm wondering when is it time to replace the hybrid battery? I'm doing 80-90mph on the highway so my mpg isn't great like 45mpg.
  2. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    45 MPG at that speed is great. With my Prime while cruising across South Dakota, I'd get about 50 MPG under ideal conditions.
    As for battery-pack replacement, just drive with it until a fault is detected.
    What do you get for EV range now?
  3. bisco
    51,835
    highway doesn't take advantage of the battery much, unless it is mountainous or similar.
    very few reports of bad batteries here, and all within warranty iirc. some have upwards of 300,000 miles and 10 years so far.
  4. southsidedakota
    27
    22
    EV off a full charge is reading 10.0 miles
  5. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    Sounds fine to me.
  6. Mendel Leisk
    41,295
    I don't think anyone here's changed a PIP battery? The discussion's come up a few times, and it seemed like a replacement battery was extremely hard to track down, and very expensive?
    #6 Mendel Leisk, Nov 12, 2021
  7. bisco
    51,835
    10 miles ev is probably average, relative to your driving style, terrain, etc.
    i'm at 12.5 currently, dropping as the weather cools, and i only average 21mph
  8. William Lower
    William Lower Junior Member
    Dixon, California
    2013 Prius v wagon
    Our 2013 PIP has 141,000 miles on it. It charges up to 8.7, and it's been that way for some time now. The northern CA central valley is pretty mild - it doesn't snow here. I assume there is nothing wrong with the car, and that its just aging a bit.
  9. QuantumFireball
    420
    269
    Ireland
    8.7 with the climate control turned on or off?
  10. Mendel Leisk
    41,295
    More specifically, with the Air Conditioning on or off? Not what Toyota refers to as AC, rather the North American "active cooling" concept of AC, freon-in-a-compressor style cooling.
  11. bisco
    51,835
    only the fan switch changes the range estimate.
    range estimate is based on so many things, it is a poor indicator of battery condition
    jerrymildred and Mendel Leisk like this.
  12. QuantumFireball
    420
    269
    Ireland
    Turning on the fan blower at the lowest setting with "A/C" button off reduces the range estimate by the same amount as with the AC on, which is why I didn't say "AC". I'm not American, but we call the system as a whole "automatic climate control".
  13. Mendel Leisk
    41,295
    Ok, was not aware of that.
  14. William Lower
    Dixon, California
    2013 Prius v wagon
    Seems like all the time. It doesn't vary much. I once disconnected the battery and it reset to the standard 11.2. After a couple of months it returned to about 8.7. I usually have the fan on to a low setting. I assume most people do when they drive? You want some circulation.
  15. bisco
    51,835
    no idea how many do, but you're seeing about a 10+% reduction. just turn the fan off for a moment.
    and try to keep in mind that the range estimate is based on past performance. it is not an indicator of battery charge, or potential range.
    it all depends on how you drive, the weather and geography this time, vs some algorithm used from past driving.
  16. Sarge
    Sarge Senior Member
    1,324
    778
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    I have a 2014 PiP with 190k KM (~119k mi) that I have owned since 2016 (~40k KM). Battery still seems fine, though a full charge usually shows about 15.5-16km, where it used to show about 17-18km when it was newer. (All figures without climate control on).
    I attribute it just to age, and really just pennies (well, I guess nickels, since we don’t use pennies anymore in Canada ;)), due to slight battery degradation.
    This is also backed up with precise energy measuring from my ChargePoint L2; when the car was newer, a full charge was usually around 2.7-2.8Kwh of energy on a charge, where as now it is usually about 2.4-2.5Kwh. Which is roughly 10-11% difference, and aligns with the range reduction. Of course, the variance of charge depends on what level the HV portion of the battery was at when I parked…
    In the end though, one km of fuel is about $0.056 around here ($1.40/L and about 4L/100km efficiency), minus the electricity cost for the same, it is about a $0.03 impact per trip. Not losing much sleep here, as long as the battery doesn’t outright fail. ;) (And I still haven’t heard of a PiP with a failed battery….)
    Cheers.
  17. QuantumFireball
    420
    269
    Ireland
    I think I've seen about the same reduction in range in the same space of time, my mileage is lower (about 84k miles) but the car is older (2012). And petrol is currently about €1.70 per litre (about 7.27 USD per US gallon) so I'm still making the most of it!
    Sarge likes this.
  18. Sarge
    Sarge Senior Member
    1,324
    778
    2023 Prius Prime
    XSE Premium
    Ouch… just a reminder for us in North America that as much as people complain about fuel prices, other areas in the world are paying much more! o_O
    Main difference of course is that North America is very much a car culture…. Big countries, lots of wide open spaces, and very poor public transit, outside of a few major city centers. :unsure: As a result, people generally drive a lot here, and it adds up.:(
    Good job keeping the PiP for the long haul though, despite this the criticisms for very poor range, handling, etc, it is still a solidly built vehicle! :)
  19. bisco
    51,835
    i'm at 11.6 miles currently, with the drop in temps, compared to 14 in nice weather.
    75,000 miles, over 50k on ev, so some pretty good use of the battery.
    jerrymildred and Sarge like this.
  20. Sarge
    Sarge Senior Member
    1,324
    778
    2023 Prius Prime
    XSE Premium
    That’s great, and honestly it seems so foreign to me how people can log that many EV miles on a car like the PiP with such limited range. That is a LOT of short trips, lol.
    By contrast, on my 2014 with 190k KM, I am at only 13% EV driving lifetime, even though I plug in religiously whenever I can….
    Of course, the reason for this is the first 3.5 years I had the car, I was doing long commutes, logging on average about 150-200km per day, and about 37K KM per year overall. Since 2019 I have been working mostly from home and driving much less (I.e. much higher EV), but it has barely put a dent in improving the EV ratio. :unsure:
    dig4dirt and bisco like this.
