Recovery from cat theft with almost no tools
Discussion in 'Gen 2 Prius Main Forum' started by nickec, Dec 8, 2021.
  1. nickec
    nickec Junior Member
    26
    Texas/California
    Three Touring
    Bought my third Prius. Napped inside to discourage cat theft for 3 days. Finally about to protect cat. Skipped a night. Cat gone.
    Almost no tools at my disposal. Forced to work on street. This will be a challenge.
    Purchased two 18" X 1.75" ID flex pipes, a union, and some high temp tape. 2 clamps included with pipes.
    Hoping to stack wood and use Prius jack.
    Any bright ideas welcomed. Planning more permanent fix. Need car while waiting and for chasing parts.
    Yet to get a good look at length needed.
    First cat theft adventure. Stay tuned.
  2. Dirty Jim
    Dirty Jim New Member
    Nashville
    Wow, Id spend the $100 on a plate to sleep in my bed.
    Or move out of the city.
    nickec likes this.
  3. Mendel Leisk
    41,198
    That's ridiculuous... :mad:
    nickec likes this.
  4. nickec
    26
    Texas/California
    Three Touring
    It is reality. Lesson learned.
  5. Tombukt2
    12,851
    2,312
    This is in the gym too I guess yeah I've got two with aftermarket cats trimmed out silencers pipes added where needed so they've already been done I guess maybe they'll get left alone and we're in the country and I drove one a bit with no cat no pipe at all blowing right out of the manifold didn't seem to bother it too much as a little loud but not really bad because you know those engines don't run too high RPMs
    SM-A715F ?
    nickec likes this.
  6. nickec
    26
    Texas/California
    Three Touring
    Me too. Did that. Just needed to install it. The day I wanted to install it, that morning, super early, they struck.
    I am willing to spend more than $100 to sleep in my bed. I already do that. I am far from home at the moment.
    No worries. I will persist.
  7. OC63RAG
    OC63RAG Member
    94
    42
    Where are you located? Do you need help/tools?
    nickec likes this.
  8. nickec
    26
    Texas/California
    Three Touring
    90018
    About 40 miles from your zip.
    #8 nickec, Dec 8, 2021
  9. nickec
    26
    Texas/California
    Three Touring
    Used Prius jack. Unsafe without stands. Found some plastic Rhino Ramps. Moved 30 feet to alley.
    Unwilling to work with only smartphone light. Got a peek. Might get lucky with flex pipe length.
    Tomorrow beckons.
    Hopefully, 9 inch lift of ramps will be enough. Could be tight. Need to shrink my head.
    Will probably dream about being under car.
    Would it be great if you could float under your car and see everything with ease. That is a good dream.
    Blue Potato and bisco like this.
  10. PriusCamper
    PriusCamper Senior Member
    12,620
    5,103
    Pacific Northwest, USA
    It's a good example of the law of attraction...
  11. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    You could probably sell this solution as a kit on eBay
    Great way to get a cheap California CatLess car out of the state to a no-test state
    American ingenuity
    nickec likes this.
  12. nickec
    26
    Texas/California
    Three Touring
    Just to make sure I get your meaning: Are you claiming I caused this theft?
  13. bisco
    51,774
    because you skipped one night? no way
    PriusCamper and nickec like this.
  14. nickec
    26
    Texas/California
    Three Touring
    Position of the forward cut seems to preclude my initial plan. Might be reduced to waiting on part delivery instead of using Prius to transport material.
    In Texas I would fabricate needed parts. Here that won't happen quickly.
  15. JC91006
    JC91006 Senior Member
    16,750
    8,556
    90018? Dang, that area....only thing that won't get stolen there, if you put out some nice new books.
  16. Another
    1,819
    517
    Naples, Florida
    Can you upload photo so we can see where the problem area is? Maybe a sleeve joint would work?
    nickec likes this.
  17. nickec
    26
    Texas/California
    Three Touring
    Will do photo tomorrow.
    A sleeve joint will work for the rear cut, from what I saw. But the forward cut, if memory serves, is so close to the bell that a sleeve would have to insert inside the flange stub. Am I wrong about that being a problem? A sleeve, when used properly, is sealed by a clamp. And clamps for the bell shape, well, I have never seen that.
    In other words, short of using something like JB Weld, there seems to be no way to do a quick attachment to the bell stub. I will avoid doing anything that prevents me from doing a proper job later. Right now the second flange, not the exhaust manifold flange, is cut right where the pipe expands. So unless I am mistaken, the sleeve contact would be very small, basically like a ring, instead of the preferred contact area of an inch or two along the lengths of the mating pieces.
    If there is only a contact area of say an 1/8", it seems likely it will leak, making noise. Could be an intermittent whistle. I realize that hoping for a really good seal, in a temporary fix, might be unreasonable expectations.
    Using bailing wire to hold a right-sized pipe inside the end of the bell might work. Seems very iffy. And leaky.
    Another thought: Remove flange stub and use JB Weld to attach a short sleeve. Then use the flex pipes I have. The challenge is diameter reduction. The reducers needed must be ordered.
    Quickly handling this seems out of reach at the moment.
  18. nickec
    26
    Texas/California
    Three Touring
    Depends on where you are in the zip. It is right next to USC. One mile as the crow flies. Still, a mile can be light-years away.
  19. Another
    1,819
    517
    Naples, Florida
    Since I don’t see what you’re looking at, it’s hard to figure out, but how does the ‘proper’ repair connect to the forward attachment point?
  20. nickec
    26
    Texas/California
    Three Touring
    By proper repair I meant "just like Toyota made it". Springs, bolts, flanges, gasket. Nothing extra, and nothing less than stock.
