Rats ate my HV battery
Discussion in 'Gen 3 Prius Technical Discussion' started by Wiresohmy, Jan 5, 2022.
  1. Wiresohmy
    Wiresohmy New Member
    Virginia
    Four Touring
    prius 1.jpg prius 2.jpg Yup. Wish I was kidding. Had some snacks in the back seat and went away for Christmas, came back and the seats were torn apart, droppings everywhere, and the wires on the HV battery are chewed up.
    Does anyone know the part number for the set of wires (2 black, 2 blue, 2 white) that insert in the top of the battery? There were also two similarly sized wires eaten that look like they go under the battery (first picture), any ideas where they go or is there a schematic I can follow?
    I also need to purchase the whole rear seat, seat belts, and other small removable plastic from the trunk. They destroyed so much. If anyone has advice on where to get the interior, that'd be great too.
  2. Wiresohmy
    Virginia
    Four Touring
    Got the wire set for the second picture, its three temperature probes and the wires connecting them to the battery control module. $30 Ebay, here in 5 days.
    Now I just need to figure out what those two wires are in the first picture, that goes across the width of the car.
  3. bisco
    51,937
    wow!:eek: i thought a mouse nest on my engine was bad:eek::(
    Wiresohmy likes this.
  4. Wiresohmy
    Virginia
    Four Touring
    I don't know what the wires are that the first picture shows, but I'm going to try to start it up now that the HV temp probes are replaced. Then I'll plug in my OBD2 scanner and try to sort it out that way.
  5. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    The green Irish Spring soap does help with keeping rodents away. I don’t know if it covers up the pheromones or they don’t like it or what but it works.
    I have dealt with insurance companies several times with chewed up wiring. If you can’t get it running and you have full coverage you may want to do that.
  6. Wiresohmy
    Virginia
    Four Touring
    Wish I knew that. Good to know moving forward for sure. Thanks
