IC engine starts on a descent with battery fully charged
Discussion in 'Prime Technical Discussion' started by niceandeasy, Jan 23, 2022.
  1. niceandeasy
    niceandeasy Junior Member
    Portuga
    Hello all,
    I am located in Europe and have a Prius Plug In from 2020.
    I am extremely pleased with it but the following behavior puzzles me: after a fully charge overnight, when I drive the car to work I have to pass a long steep descent of around 1 kilometer.
    In winter, towards the end of the descent, despite the fully charged battery, the IC engine starts and runs for around 30 seconds then stops for good, not working again
    This only happens in wInter, do you have any clues why?
    Is some warm up routine of the battery of any other of the car components ?
    Regards to all
  2. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    Mine does the same thing. I don't know why. My IC engine comes on at odd times so I stopped trying to figure it out. I am sure someone on this site has an answer though.
  3. Salamander_King
    Salamander_King Senior Member
    11,023
    8,963
    New England
    It is perfectly normal. When the battery is fully charged and there is no room to put more electrons when regen is working, the engine starts. This tendency is more pronounced when the ambient temp (thus battery temp) is colder. In the summertime, there is probably just enough room to put the regen energy back into the battery even though it is full. In winter with a cold battery pack, the car decides much quicker to start the engine mostly to protect the battery.
    Once the engine starts, it has to complete the warm-up cycle. It won't stop until then. There are some other instances when the engine starts or the engine will not stop as stated in the manual.
    #3 Salamander_King, Jan 23, 2022
    Ovation and jerrymildred like this.
  4. niceandeasy
    Portuga
    Thank you for the reply and explanations, much appreciated !
    Salamander_King likes this.
  5. mikel1
    mikel1 New Member
    Queensbury, NY
    2018 Prius Prime
    I have noticed similar behavior when descending long grades with a full battery, but noticed that the engine gets up to very high revs. I think what is going on is that the computer is trying to use engine compression as braking since the battery can not take any more energy out of the normal brake-to-battery recharging path.
  6. CharlesH
    2,797
    1,164
    Roseville, CA
    Just a pendantic nit: I believe that with gasoline engines, it is really manifold vacuum braking being used to dissipate energy when the battery is full .
    Diesels use compression braking (Jake brake).
  7. Storm88000
    Storm88000 Active Member
    321
    145
    LHValley, PA
    2020 Prius Prime
    Here’s what confuses me. When I’m reading battery charge is gone, going slow with the ICE, and suddenly it shuts off and gets quiet and seems to be running off the electric miles that aren’t there. Sometimes it happens when parking for a moment, sometimes when slowing down but not stopping.
  8. Salamander_King
    11,023
    8,963
    New England
    You are driving HV mode with EV. After the EV mode depletes the battery, there is still ~10-14% SOC remaining in the traction battery. You are now driving the car as a regular hybrid Prius. Initially, the engine will cycle for warmup but after that, the car can drive in EV (not the EV Mode) and cycle between the engine and battery. If you drive gently and as long as the terrain does not require a lot of energy, you can coast and glide in "EV" for a quite while.
  9. PerryD
    PerryD Junior Member
    27
    34
    Near Boston
    2022 Prius Prime
    I came from a 2014 Prius and was surprised and delighted when I saw my new Prime using the battery at 65mph in HV mode (on the older model it would not operate at over ~40mph). I have a 35-mile one-way commute with most being on a highway and the last ~4 miles in an urban area. What I've discovered is that once I've depleted the traction battery the EV is running about half of the time on the highway. Then, when I've turned off the highway and into city streets I'm almost always on battery, except for inclines. This specific route gives me ~350mph recorded for the 35 mile trip.
  10. Salamander_King
    11,023
    8,963
    New England
    If your commute did not have the highway speed, you could make the entire 35 miles in EV mode for the 999.9mpg. My commute is about 18 miles one way. During summer and warmer months without using HVAC, I can sometimes make the round trip on all EV modes. I drive on a rural road, with no stop and go, and a speed limit of 45-50mph at an average speed of ~30mph.
  11. vvillovv
    vvillovv Senior Member
    4,324
    1,511
    NY
    I've always had the 999.9 mpg quest per trip since driving the 14 PiP. With the 17 Prime Plus the gauge is limited to 199.9 mpg so I have to do some manual estimations ie: did I get 999.9 or somewhere between 999.9 mpg and 199.9 mpg per trip.
    Still, 350 mpg for a trip, no matter how long the engine runs, is not too shabby or pretty damned good, considering how fast mpg go down from 999.9 when the engine switches on. It's about a 3x slower reduction in the mpg reading in the Prime than it was in the 14 PiP (estimated). but still, not bad for mostly highway driving.
  12. vvillovv
    4,324
    1,511
    NY
    30 seconds of warmup cycle is not very long and indicates the winter temps in your area are not extremely cold. Some of us have to drive a mile or 2 miles and some probably even more, before the engine will stop running.
    The two easiest things to remember when the gas engine switches on are temperature and speed. When temperatures start to go lower, the Prime behaves differently and trigger points for the gas engine coming on change and continue to change subtly as temps fall lower and lower.
    It gets more complex in how long it takes after the the gas engine turns off as to when the EV mode works much closer to how it behaves in summer time. That usually takes at least a few more miles of driving slowly before all the components warm up enough to provide semi normal EV behavior.
    So the easy way to learn where those tipping points are during your trip down the hill is to slow down to a speed where the gas engine doesn't turn on. You'll have to find a time to experiment when there is no traffic around, because the speed you may have to slow down to ( although not likely in your situation ) can be dangerous if there is traffic around you.
    It's still cold enough locally after sunset that it takes 1.5 mile (2 - 3km) for the warmup cycle to complete for me. It's probably a lot warmer than that for you locally now 3 months after posting your question, although it may help you next winter, at very least.
    #12 vvillovv, Apr 3, 2022
  13. PerryD
    27
    34
    Near Boston
    2022 Prius Prime
    That just happened, and you are absolutely right, I avoided the highway and used secondary roads. It was right at the edge of range, but there were enough small hills that I could generate a percent or two of traction battery several times. It took a lot of thinking and active power management, but clearly I can do it on my commute with some planning.
    vvillovv, Ovation and Salamander_King like this.
  14. OptimalPrime
    OptimalPrime Member
    161
    95
    Keene/Nashua
    If the ICE is cold and then only comes on for 30 seconds during the descent, then turns off and goes back to EV mode, clearly the engine has not completed a warmup cycle. So I would guess that the ICE is merely being spun up, not fed any fuel, just being used for engine braking. Maybe if it's not been fired up and fed fuel, it is not required to complete a warmup cycle.
    This is a scenario I personally have not encountered, because I don't live on top of a mountain. Anytime I drive over a mountain, I climb it using the ICE, and plan ahead to be sure I can absorb the regen of the descent.
    My own scenario I don't like, is when the battery is so cold, that a long descent pumping regen into it, decides to stop doing so, to protect the battery. The green car indicator goes off, the car starts speeding up, and I must use B mode or friction brakes.
    I also notice that in that situation, the SOC might still go up, just much more slowly than when the green EV car symbol is lit.
