Deep Dive into the 2022 Toyota Prius. Is it still a good buy in 2022?
Discussion in 'Gen 4 Prius Main Forum' started by Georgina Rudkus, Feb 2, 2022.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,343
    2,337
    Taylors, SC
    Mendel Leisk and jerrymildred like this.
    51,036
    one would first have to define 'good buy'
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,132
    739
    Monument, Colorado USA
    Don't you just love TheCarCare nuts channel? As a DIYer, I've learned a TON of great stuff from the master mechanic! I need to ask him if my AWD motor has gear lube I need to be draining/filling periodically. (I'd assume it does...I'll have to look next time I have it up on a lift.)
    I did NOT know that strange device on the rear leaf was a sensor to let the car know the rear has extra weight and, automatically, adjusts the headlights....wow! I remember seeing it when I had the car on the lift and wondered what in tarnation IS that thing!
    He told me he's, already, seen 2016-2017 Prius' in his shop for service with over 200,000 miles and were solid...no issues at all.
    jerrymildred likes this.
  4. BellevilleMXZ
    BellevilleMXZ Member
    72
    61
    Ontario,Canada
    2024 Prius
    Limited AWD-e
    Didn't bother watching but love our 21....
    AzWxGuy likes this.
  5. DOHCtor
    DOHCtor Member
    157
    Levis (Quebec city's south shore)
    2024 Prius Prime
    SE
    Electric motors in the rear of those AWD systems use WS ATF.
    Daniel Dang likes this.
  6. Mendel Leisk
    40,491
    He mentions (at 17:00) that for 2022 the tpms sensors are revised, more easily detachable, and they program themselves with a bit of driving. (y)
  7. ColoradoBoo
    1,132
    739
    Excellent! I'll have to add that to my list of things to do at the 3-year mark. Glad it's using WS fluid. In my daughter's 2016 Mazda CX-5, I wanted to change our her rear differential fluid and found you can ONLY use the stuff from Mazda and it's $30 a quart....what a rip-off. At the Mazda stealership, they charge $21 for an oil filter....outrageous!
    Mendel: Yes, those new TPMS sensors are great!!!
  8. Mendel Leisk
    40,491
    And in USD, weird. This for our son's 2018 CX-5:
  9. ColoradoBoo
    1,132
    739
    That's not as bad, Mendel, but charging for a drain plug gasket is a little on the side of "nickle-and-dime!"
    My daughter's Mazda was bought used last year and only came with one key fob. I got an OEM one on-line for under $20 (I didn't even bother asking our Mazda dealership what they charge.)
    Anyway, I'm having a hard time programming it with my automotive scan tool (it has that feature). A mechanic said Mazda's have one of the most difficult electronic key systems out there. So I called Mazda and priced out a program job....$170! So I called my Toyota dealer and they are going to do it Saturday morning for $65. I love the CX-5 but starting to hate the dealership.
  10. Georgina Rudkus
    3,343
    2,337
    Taylors, SC
    My dad owned a 1998 Mazda MPV van which I drove on occasion until 2016. He said that, instead pf a kit for replacing the intake gasket, Mazda charged him for the gasket and the 16 sealing washers separately. That's really nickel and diming it.
    ColoradoBoo likes this.
