Heat Will Not Blow Thru the Floor Ducts
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by STX, Feb 5, 2022.
  1. STX
    STX Junior Member
    San Antonio, TX
    I have a 2014 Prius that I bought used. When running the heater, I can get heated air to blow thru the upper AC vents but not thru the floor vent underneath the dash. What is the most likely problem and solution?
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Bad blend door
  3. JC91006
    JC91006 Senior Member
    16,767
    8,565
    Have you checked the cabin filter if it's restrictive? I have this problem with a Gen2 car I've owned, changing the cabin filter somehow makes it better
  4. PriusCamper
    PriusCamper Senior Member
    12,724
    5,143
    Pacific Northwest, USA
    Yes! This is the first step! Next step after that is changing vent settings again and again to isolate where system is normal and where system is a problem. Also sometimes just repeatedly changing vent settings will exercise them enough to get them to function normally. Next step after this is diagnosing the vent controller motors/mechanics that run this...
  5. ChapmanF
    18,133
    There are three doors that move in the heating system:
    • the inlet door controls whether fresh or recirculated air is used
    • the blend door controls how warm the air will be
    • the outlet door controls which set of outlets the air will blow from
    So if there is a bad door, or door actuator servo, involved, for this issue it will have to be the outlet door.
    PriusCamper likes this.
  6. JC91006
    16,767
    8,565
    When I encountered this problem, there was only 1 vent that didn't seem to blow hot air out consistently. When the temperature is changed, it would blow hotter air if it was turned up accordingly. I still can't figure out if this would be an outlet door control problem or a blend door control problem. Or possibly both.
  7. bisco
    51,890
    the good news is that toyota has allowed for easy access and repair in their design
  8. ChapmanF
    18,133
    Toyota of Neptune, that is. They build them a little differently there.
  9. bisco
    51,890
    LOL, i was afraid of that, i'll just wear warmer socks.
  10. STX
    STX Junior Member
    San Antonio, TX
    Are all of these doors electronically-controlled (using a servo)??
  11. ChapmanF
    18,133
    There are three servos, one controlling each door.
    STX likes this.
