Car sounds like angle grinder
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gprimr1, Feb 10, 2022.
  1. gprimr1
    gprimr1 New Member
    Towson MD
    I have a 2010 Prius and about a week ago, it started making a grinding noise. It sounds at times like an angle grinder under the hood.
    I took it to a mechanic who looked it over. He was not able to find the cause of the noise.
    There are no codes in the computer system, and performance has not been impacted.
    The noise is loudest when the engine is cold and goes away once the engine warms up.
    This is a video I took to capture the noise Tuesday night. The engine had been off since Monday evening:
    I'd really like to keep the car going another year, so I'm def concerned about this noise, but I'm also concerned if I take it to a Toyota dealership, I'm going to end up with a repair bill bigger than the car's worth.
  2. PriusCamper
    PriusCamper Senior Member
    12,771
    5,174
    Pacific Northwest, USA
    1) When you open the coolant reservoir cap does it make a sucking sound?
    2) Consider cleaning / having an Exhaust Gas Recirculation (EGR) valve maintenance schedule
    3) Aggressively shake your tail pipe when this noise happens to ensure it's not loose exhaust shielding
  3. AzWxGuy
    AzWxGuy Weather Guy
    1,055
    538
    Tucson, AZ
    2021 Prius
    Could be the water pump bearing or pump idler pulley. Sort of hard to locate and confirm though. I've used the piece of broom handle to ear technique, which must be done carefully around moving parts. A precise squirt of water may also temporarily eliminate the noise. Or loosen up the water pump belt and remove and see if the sound stops. Don't run the engine very long though.
    PriusCamper likes this.
  4. ASRDogman
    ASRDogman Senior Member
    7,597
    3,916
    There are NO belts on a 2010 Prius. Nothing to snag.
    Hard to tell from the video what the noise is, it almost sounds like a rattle, like something is loose.
    You could use a screw drive, long one, or long socket extension, to the ear, and touch the water pump.
    If it's the water pump, you'll know it instantly. You also have the inverter coolant pump, it's under the
    fuze box.
    What area is it coming from? Have someone start the car while you are listening close to the engine.
    I would say it could also be the ac compressor, but with the cooler weather, it probably no turned on.
    But check to make sure...
    Danno5060 likes this.
  5. AzWxGuy
    AzWxGuy Weather Guy
    1,055
    538
    Tucson, AZ
    2021 Prius
    Oh, yes, sorry. I was remembering my 2008. I'll see myself out...
  6. ASRDogman
    7,597
    3,916
    It's not that big of a deal...
  7. gprimr1
    gprimr1 New Member
    Towson MD
    I opened the coolant tanks after letting the car cool down.
    The engine tank hissed when opening.
    The inverter tank had a very slight sucking noise.
  8. PriusCamper
    12,771
    5,174
    Opening the coolant reservoir to the sound of air sucking in is a sign of lost coolant due to blown headgasket.
  9. ETC(SS)
    7,164
    Time to check the dipstick......
    ...and prices on a replacement........
  10. AzusaPrius
    AzusaPrius Senior Member
    2,184
    921
    For starters that does not sound like a HG issue and people are already pointing you in the direction as if it was.
    The coolant res will always make a small hiss but if it last like 3 seconds a sounds like pffttt, then you have a blown HG.
    Best to check that in the morning on cold start.
    I would assume like someone else said the waterpump or pully.
  11. Mendel Leisk
    41,464
    How many miles?
  12. Noah Ray Roberts
    Noah Ray Roberts New Member
    Utah
    I have a 2015 Prius experiencing the same issue (same sound from your video). 151,000 miles.
    **Did you ever find out what the issue was??**
  13. bisco
    51,950
    are you losing any engine coolant?
  14. oskr24
    oskr24 New Member
    Australia
    Angle grinders are crazy loud. Was it ear protection level loud? I wouldn't be driving the car in those circumstances.
