Modified Prius gen 3 List
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Matth Torrijos, Feb 15, 2022.
  1. Matth Torrijos
    Matth Torrijos Active Member
    114
    207
    Poway
    I'm making this thread to get some ideas on your gen 3 modification list. Here's my current setup. Hope you share your list (even if its long, and please add pictures for inspiration)
    2015 Prius trim 5
    Suspension: Airlift 3p w/d2 bags&struts
    Wheels: JNC 032 18x9.5 1.5in spacer rear 1in spacer front all with hub centric rings
    Tires: Pirelli Pzero 225/40/18
    Flares: 4in universal
    Ground effects: MD style front lip, challenger side skirt splitter, mustang rear diffuser, and rear duck lip wing (unknown)
    Interior: Scanguage II, Escort 360 Max Radar Detector, Vantop H612T Dash Cam
    Lights: internal lights LED and LED yellow foglights 55w
    20210821_154138.jpg 20211023_163928.jpg DSC01877.jpg 20220213_211313.jpg 20211112_145613.jpg
    #1 Matth Torrijos, Feb 15, 2022
  2. black_jmyntrn
    black_jmyntrn Senior Member
    1,691
    393
    2013 Prius Plug-in
    them flares though... :: fire emoji ::
    Matth Torrijos likes this.
  3. PistAchiYo
    PistAchiYo Junior Member
    Chicago
    how long does it take to install these. Approximately?
  4. Kevin Pavitt
    Kevin Pavitt New Member
    Paauilo, HI
    I'm sorry but it's a Prius. They make lots of sports cars. WHY?
    gboss, tellyourdogisaidhi and geripsy like this.
  5. Matth Torrijos
    114
    207
    Poway
    Depends, most of these are just bolt on stuff. If you got a bunch of people that are willing to help about 3 days for everything
  6. artistic_gore
    artistic_gore New Member
    24
    Washington State
    There seems to be a lot of push-back regarding modifying the prius.
    That said I am going to bore the throttle body to 58mm (max it will go), probably get an intake though I haven't settled on which one, I haven't looked too hard at this yet but the one video I watched showing a dyno run with the Injen intake, it lost HP.
    I also want to get an Injen throttle controller (the latest model is PT0002B they have it in stock on Summit racing) to help with throttle response, both quicker on the freeway and slower for stop and go and the like.
    Last for engine stuff I want to try a red bullet VVT solenoid, a lot of people claim it is snake oil, it might be but I'm willing to throw down a couple hundred and see for myself.
    I also ordered a Lithium battery from projectlithium.com.
    If my motor goes, I don't really care, I am doing what I can to keep it going for now but I ultimately want to swap in a 2016+ engine anyway due to their improved design.
  7. AzusaPrius
    AzusaPrius Senior Member
    2,137
    900
  8. black_jmyntrn
    1,691
    393
    2013 Prius Plug-in
    I'm installing the rear sub frame from Lexus UX and a electric motor that's can bus controlled, need to get prius up to 350v now
    The M20A-FXS is also going in as my swap... stay tuned.
  9. GregC1979
    GregC1979 Active Member
    201
    121
    Nowhere
    Matt your car is one of the coolest Prius' in So- Cal..nice to see it in person man.
    TGrracie and Matth Torrijos like this.
  10. Matth Torrijos
    114
    207
    Poway
    Thank you greg!
    GregC1979 likes this.
  11. black_jmyntrn
    1,691
    393
    2013 Prius Plug-in
    EHHH... I've seen better. jajajajajajaja
  12. christian cox
    christian cox Member
    115
    ohio
    What advantage was there to upgrade to the lithium battery pack and was it worth it?
  13. AzusaPrius
    2,137
    900
    @christian cox
    Well it is not as heavy as OEM or compared to any other HV pack on the market.
    The lithium battery charges up faster and stays charged longer than a regular pack.
    There are some other things to mention.
    You can find out about it on the site.
    Use my link and you will save some cash.
  14. christian cox
    115
    ohio
  15. Matth Torrijos
    114
    207
    Poway
    Keep me posted on this build!
  16. Matth Torrijos
    114
    207
    Poway
    lol
  17. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Poway Matth Madness at its best! Really digging your rim and extended body mods!
    Matth Torrijos and GregC1979 like this.
  18. GregC1979
    201
    121
    Nowhere
    Ok besides yours man :p
  19. Montgomery
    2,254
    2,241
    Orange County, CA
    Cleaned and ready to drive!!
  20. black_jmyntrn
    1,691
    393
    2013 Prius Plug-in
    lol nah, just giving him a hard time
