Wheel bearing replacement
Discussion in 'Prime Main Forum (2017-2022)' started by Storm88000, Feb 25, 2022.
  1. Storm88000
    Storm88000 Active Member
    321
    145
    LHValley, PA
    2020 Prius Prime
    Has anyone replaced a wheel bearing on their Prius Prime? Although mine is a 2020 w/ 26k miles, apparently the front left bearing is on its way out.
    I assume this would NOT be covered by Toyota’s 36k bumper to bumper warranty.
    Has anyone done it themselves, and if so, how difficult or easy? Thanks guys.
  2. schja01
    schja01 Senior Member
    1,809
    1,202
    Chicagoland
    2024 Prius
    Limited AWD-e
    I would assume it WOULD be covered. 3yrs 36,000 miles.
    Mendel Leisk and Storm88000 like this.
  3. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Yes but isn’t that considered a “wear & tear” item?? Just like brake pads and tires.
  4. schja01
    1,809
    1,202
    Chicagoland
    2024 Prius
    Limited AWD-e
    Nope. Wheel bearings should last the life of the car. Same with ALL bearings in the vehicle.
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,319
    2,324
    Taylors, SC
    Unfortunately, accordingly the "life of the car" figuratively means the period specified in the warranty.
  6. schja01
    1,809
    1,202
    Chicagoland
    2024 Prius
    Limited AWD-e
    The OP is still within the warranty period. It’s covered.
    Storm88000 likes this.
  7. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Okay, I just called my dealer and left a voicemail after hours about making an appointment. I hope they do it. Also need an oil change anyway so hopefully get both done.
    Thanks guys I appreciate the info. I thought it was odd for a wheel bearing to go bad already in a 2020 not even past 30k miles.
    here’s to hoping you guys are right
  8. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    I question whether the problem actually is a wheel bearing. Anything can be defective, but a wheel bearing at this mileage is highly unusual. On the repair order be sure they accurately describe the problem as well as the service writer's guess as how to fix it. If the repair doesn't fix the problem, don't pay for anything--but it should be a warranty item.
  9. Mendel Leisk
    40,239
    There should not be a "cover charge" for the initial assessment, or at the least: if and when they determine it's covered by warranty you they should reimburse any charges.
  10. Salamander_King
    Salamander_King Senior Member
    11,001
    8,923
    New England
    Why do you think the wheel bearing is bad? What symptoms is your car exhibiting?
    Trollbait and Mendel Leisk like this.
  11. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    You guys were RIGHT!!!
    Toyota replaced it under warranty for free.
    And it was in fact the front driver's wheel bearing. Starting making a weird sound just after 26,400 miles (got car brand new early March of 2020). They had the vehicle overnight and it was done the next afternoon. Boy am I sure glad I made this thread. I honestly thought wheel bearings were considered wear and tear things - maybe not first 12k miles (kind of like the alignments are free up til then). I was looking at videos how to do it.
    The car was making that groaning sound at certain speeds and just noisy and I was pretty sure it was coming from the front driver side. I asked if this was usual for a bearing to go out so early, they said it happens sometimes. They checked the other 3 wheel bearings and those were all good. I got my oil changed there at the same time, even though its a little more expensive but at least they typically top off the fluids and check some other stuff. (I am past the 2 years of free Toyota Care).
    Apparently wheel bearings are warrantied until 5 years or 60k miles, at least in the 2020 Prime, so the service tech said. So hopefully I will be good. Thanks guys again, saved me a bunch.
    #11 Storm88000, Mar 18, 2022
  12. Salamander_King
    11,001
    8,923
    New England
    Great! I wonder what the cost would be if not covered by the warranty.
  13. schja01
    1,809
    1,202
    Chicagoland
    2024 Prius
    Limited AWD-e
    $100 Parts, $200 Labor. Give or take a grand.
    Back in the day when wheel bearings were "ball bearing" construction they failed quite frequently.
    Nowadays they are "roller bearing" type and much more robust.
    Wheel Bearing Replacement Cost - RepairPal Estimate
    #13 schja01, Mar 18, 2022
    Salamander_King likes this.
  14. BiomedO1
    2,580
    1,388
    SacTown, Ca
    That part number goes back to a pre-pressed bearing hub assembly; MSRP $400. It looks to be a very easy job, since it appears to be a bolt-on.
    FWIW: Usually the right bearings go bad - from rubbing and jumping curbs. That lateral pressure, slowly loosens the bearing - causing eventual failure. Bearings are covered under our 3yr 36K mile mechanical warranty - brakes & tires are not.
  15. Salamander_King
    11,001
    8,923
    New England
    LOL... so the final bill can be as low as $300 or as high as $1300. I can totally believe it though. My son just took his car to have two new tires put on. He damaged the sidewall driving over a deep pothole. I estimated the cost will be ~$200 total, 2x tires, and labor. As it turned out when he got his car back... the total cost was ~$850. Yep, they told him the car needed the rear brake jobs (new rotor and pad) as well as alignment. Plus, the wheel also needed to be replaced.
  16. ChapmanF
    16,957
    Prii use hub-bearing units, which are permanently assembled at the factory out of twin rows of ball bearings.
    The ball bearings are configured in "angular contact". You can see the way the inner and outer races are offset, in opposite directions for the inboard and outboard bearings, holding the hub securely in place on its axis.
    People sometimes ask about pressing a hub-bearing unit apart to "just replace the bearings". The picture shows why that's not really an option, though there do seem to be third-party inexpensive replacement "units" that really are a straight spindle and bore with a couple generic bearings pressed in. So, if someone is looking at a car where at one point those kinds of "replacements" were put in for the original HBUs, then it could be possible to press those apart and just replace the bargain-bin bearings inside, if the right size can be found.
    Storm88000 and Salamander_King like this.
  17. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    I didn’t get an extended warranty or anything - I could have sworn service rep said things like the bearings are warrantied to 5 years or 60k miles on the Prime. Shrug
  18. Trollbait
    12,240
    They might fall under the drive train warranty.
  19. BiomedO1
    2,580
    1,388
    SacTown, Ca
    1. The 3yr 36K is your bumper to bumper warranty - so your definitely covered there.
    2. The 5yr 60K is the power train warranty. Engine & transmission; not sure if wheel bearing are included or defined in that list of warrantied items; but you may be able to talk the service writer into it or escalate the matter to upper management.
    3. Then there's the EV drive train coverage, 10yr 150K for CARB state vehicles, or 8yr 100K for non-CARB state.
    ie. Say an ignition coil or engine control sensor goes bad at 58K miles; covered under #2. If the same part goes out at 75k, not covered. Bad traction control battery CPU at 115K, covered in CARB state; any other state - your out of luck (not covered).
    Hope this clarifies things.
  20. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    Anyways, I owe you guys big. I was going to waste all day tomorrow (Sunday) doing this damn bearing had I not known
