Tire Upgrade - Walmart
Discussion in 'Gen 2 Prius Main Forum' started by ibcs, Nov 14, 2007.
  1. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    Took about 20-30 minutes of talking to the tire installers. They did not want to put anything on the car except the original tire size. I know that the 185/60-15 is the OEM, but the Goodyear Assurance ComforTred came in the 195/60-15 size only. They called local Toyota dealer and they said it might mess up the hybrid stuff.
    Hope I like the new tires.
  2. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    Well, Comfortreds came in the 185/65-R15 size as little as three weeks ago, because I ordered them and installed them on my wife's Prius through Walmart. About a year ago I put the same tires on my other Prius, again through Walmart. But now I see on the Walmart web site that they are only listed under a search for 195/65-R15.
    The Goodyear site still lists the Comfortreds in the 185/65-R15 size, but I wonder if they are discontinuing them in that size?
  3. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    <div class='quotetop'>QUOTE(Marlin @ Nov 14 2007, 12:38 PM) [snapback]539508[/snapback]</div>
    Yes, I was going by Walmart's web site and they were not listed. They installed them and the short ride home did not tell me a whole lot about 2 miles. I'm heading to the Michigan / Ohio State game this weekend about 3 1/2 drive, so I'll have a better feeling after that trip. I know the mileage will go down for the short term.
    Go Bucks!
  4. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    Just an update - Had a great trip to Michigan. The Comfortreads are much quieter than the stock tires and seem to have a softer ride. Handling in the rain is exceptional.
    One thing I did notice is that going over a particular speed bump, going downhill, each day, if I had my foot touching the break the traction control would come on and make the Prius feel squirmy. Since replacing the tires, I can go over the same speed bump with my foot on the brake and the traction system does not active.
    First impressions, love the new tires - should have gotten rid of the Integrities when I purchased the car. Mileage dropped 5 MPG for the first tank, but instead of driving my normal 65, I was driving 80-85 on the open highway and the tires are not broken in.
  5. donzoh1
    donzoh1 Active Member
    447
    153
    Lenexa, KS
    I got a new set of tires from WalMart. Basically, these were just the cheapest stuff I could find at around $230 for the set. They were shipped to store and then I let them sit in the basement for a month or so. I also got a new set of tire pressure sensors as I had recently replaced one and then within a couple months, the light came on again as another one failed. I went back to WalMart and they mounted them free (since I had bought them from WalMart) and then charged me $70 out the door for balancing, installing new valve stems/pressure sensors that I got online, setting new TPMS codes, and disposal of old tires. I though that was a pretty good deal and the tires really look pretty good. We'll see how they do.
