Prime's "glass jaw" worse than expected
Discussion in 'Prime Main Forum (2017-2022)' started by Georgina Rudkus, Mar 4, 2022.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,319
    2,324
    Taylors, SC
    The Prius Prime is legendary for its fragile acrylic "glass jaw" bumper and grille. Here's another issue that can be exceptionally expensive.
  2. schja01
    schja01 Senior Member
    1,809
    1,202
    Chicagoland
    2024 Prius
    Limited AWD-e
    Everything is expensive. If you have the fancy LED headlamps they are $1000 each side.
    People poo poo the extended warrany but I think a case could be made for one on the Prime.
    Tideland Prius likes this.
  3. Mendel Leisk
    40,245
    I don't get the title.
    Salamander_King likes this.
  4. schja01
    1,809
    1,202
    Chicagoland
    2024 Prius
    Limited AWD-e
    I do. Basically the OP feels the front of the Prime is prone to damage like your jaw.
  5. hill
    8,576
    & like the Prime's heat pump .... that is the intimation
    #5 hill, Mar 4, 2022
  6. Georgina Rudkus
    3,319
    2,324
    Taylors, SC
  7. Salamander_King
    Salamander_King Senior Member
    11,001
    8,923
    New England
    But I have yet to read a report of failed LED headlight or failed compressor that would have been covered by an extended warranty. I am not sure what happened to the car in the video. But it sounds like it was in an accident, and the guy is salvaging the compressor? If the burn-out of the compressor happened in the 3 years 36 months, not due to accident damage, it would have been covered by the original warranty. If the failure is caused by an accident, then the warranty (extended or not) will not pay anyway.
    Has there been any report of frequent compressor failure in PP, within the 3/36 or beyond? Don't think so.
    #7 Salamander_King, Mar 4, 2022
  8. Washingtonian
    Washingtonian Senior Member
    726
    621
    The narrator says these compressors burn out regularly from being neglected or improperly charged. Does anyone know that to be a true statement?
  9. Georgina Rudkus
    3,319
    2,324
    Taylors, SC
    Check these out.
    hill likes this.
  10. bisco
    50,819
    a prediction is only valid if it comes to pass. what's the oldest prime, 6 years? not a bad track record so far
    Hicksite likes this.
  11. MikeDee
    MikeDee Senior Member
    1,571
    596
    San Francisco Bay Area
    You gotta watch curbs or those concrete things in the parking stalls, as the bumper is so low. Smashing your bumper into one can be expensive occurance. I try to park short of them.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,135
    Tampa, FL
    My Prime's bumper clears stuff that used to always scrape on my Gen 2 & 3. Even with the reduced ground clearance. Someone at Toyota finally wised up and put a slope on the bottom of the overhang.
  13. Trollbait
    12,240
    They found other ways to keep air drag low, I guess.
    jerrymildred likes this.
  14. Tideland Prius
    16,406
    Same.
    Oh? Was there a design update for 2021?
  15. jerrymildred
    11,517
    14,135
    Tampa, FL
    The curved glass in the back makes up for much of the front aerodynamic loss.
    If so, it's not very obvious. I made screen grabs from the 2017 brochure and from the online 2022 picture. The bottom one (2022) has a slightly higher point of view, so they are not identical angles.
    Edit: Actually, it looks like they are at the same angle now that I compare the A-pillars.
    Screen Shot 2022-03-13 at 8.05.21 AM.png Screen Shot 2022-03-13 at 8.05.39 AM.png
    #15 jerrymildred, Mar 13, 2022
  16. MikeDee
    1,571
    596
    Still, you don't want to scrape under the car either.
  17. farmecologist
    farmecologist Senior Member
    1,954
    1,797
    Southern MN
  18. jerrymildred
    11,517
    14,135
    Tampa, FL
    Very true. But I've still scraped it countless times. No real harm yet, but that doesn't mean I won't snag something bigger someday. I'm starting to get kind of serious about a lift kit if I keep it much longer.
