Five Stages document back
Discussion in 'Gen 2 Prius Technical Discussion' started by hobbit, Nov 9, 2006.
  1. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    I finally compared all the different versions of Daniel's "five
    stages of Prius hybrid operation" document, picked the most complete
    one, annotated it a little, and threw it up for grabs at
    http://techno-fandom.org/~hobbit/cars/five-stages.txt
    since the original KB article here seems to have finally fallen
    victim to the offshore crackers. I've stuck a link to it and the
    now-404ing original in my "linkfarm".
    _H*
  2. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(hobbit @ Nov 8 2006, 10:03 PM) [snapback]346114[/snapback]</div>
    Thanks. I'd printed this out once before, but of course I can never locate hardcopy when I want it.
    I've saved it to the hard disk now.
    Dave M.
  3. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Thanks Hobbit, I did not know it was gone but it is good to review from time to time. I also coppied it to my hard drive.
  4. 8AA
    8AA Active Member
    550
    62
    Maryland
    Thanks for reposting. I have an editorial comment and a question. Editorially I would replace 34 MPH with 41 MPH, or at least note the difference between the 2000-2003 Prius, and the later generation. Because the max RPM of MG1 was increased to 10,000 RPM, the maximum speed without running or turning the ICE is about 41 MPH.
    There seems to be a change in operation within S1. I only notice it when I'm starting the car cold in a parking garage, but for the first minute or so there seems to be a higher than normal resonance from the air intake (the ICE sounds more like a sewing machine). I'm guessing that the valve timing is being adjusted to minimize the time required to warm up the ICE. Not that anything is wrong, I'm just curious.
  5. hobbit
    4,089
    468
    Bahstahn
    What that metallic sound is, in fact, is from the very retarded
    spark timing. I used to hear this while fiddling with the timimg
    in older cars; it was indicative that I was *way* off the peak.
    Some of the combustion is probably still happening by the time
    the exhaust valve opens; some of the prius_technical_stuff guys were
    referring to it as "flames roaring down the exhaust header". Well,
    it does definitely get the catalytics heated up in a hurry, which is
    the whole point.
    _H*
  6. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    On cold start up the can view shows about 0.7 gal/hour fuel burn at idle for just over a minute. Then it drops quite rapidly to around 0.2 gal per hour.
  7. ken1784
    ken1784 SuperMID designer
    2,943
    1,380
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(8AA @ Nov 11 2006, 10:31 PM) [snapback]347403[/snapback]</div>
    It is written for 2004- Prius.
    The 34 mph is nothing relating to the 41 mph ICE spinning speed.
    If you drive above 34 mph, the S3 idling check ceremony is suspended.
    Ken@Japan
  8. 8AA
    8AA Active Member
    550
    62
    Maryland
    Thanks for the information Ken.
    It's probably because I've been in S4 when it happens. With a light load, I can stealth up to 41 MPH before the ICE has to spin. If I'm in a no load condition (downhill) I can hyperstealth with the ICE spinning, but if there is any load at all, the ICE typically fires up since it has to be turning anyway.
