I have a Socal 200k 2009 Prius and wanted to know when I should expect my hybrid battery to die?
Discussion in 'Gen 2 Prius Main Forum' started by Kaptainkid1, Mar 17, 2022.
  1. Kaptainkid1
    Kaptainkid1 Active Member
    308
    246
    Los Angeles
    I'm considering buying Dr Prius and wanted to know if this app is good to determine the life expectancy left on my 200k 2009 Prius hybrid battery. I want to do a 2500 road trip but wasn't sure if this car will break down on my long road trip.
    The Prius has been flawless since New. Only issue was inverter pump, tires, 12volt, oil changes and 1x brake job since New. I consider this car to be my most dependable car ever with very low maintenance.
    Android ?
  2. Isaac Zachary
    Isaac Zachary Senior Member
    2,541
    1,280
    On May 12th, 2024 at 5:20pm.
    Merkey, edthefox5 and bisco like this.
  3. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    And let’s also worry when will a 9.0 quake of the San Andreas fault hit L.A.?
    No need to worry about it. The HV battery will give you warnings that most people ignore, then it will be $2,000 or less to fix it.
    My 2007 with nearly 200k miles has the original battery and I don’t preoccupy myself with it. If ICE runs more or mpg starts falling, I’ll start to focus on it. I occasionally run Dr Prius to check fell voltages and IR. I see no problems. Maybe if you want to do something proactively, get a good quality OBD2 dongle and the free version of Dr Prius.
  4. bisco
    51,838
    everyone's experience is different. no one can tell you when your car will break down, for whatever reason.
    we all have different risk tolerance. i don't take long road trips in older cars, others have driven cars like yours from florida to alaska and back. it just depends on your comfort level.
    there's always your cell phone and triple a. but you do read a horror story every now and then
    Merkey likes this.
  5. Tombukt2
    12,900
    2,315
    My 09 died about 120 days ago 1646 Toyota new battery. Twas toast too. The cars never sat since put on road in 09. My wife’s 10 been commercially driven since new . Other than wiper motor and installing a a 15 battery Hv in car at purchase 650. Nothings ever failed . Err flow is good hi side . Never been touched 267K now . Never a hic up . Now tomorrow cyl no 2 will fail He He..
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    It will last just about as long as your cat.
  7. Kaptainkid1
    308
    246
    Los Angeles
    Has anyone used Dr Prius and was able get information on the hybrid battery condition?
    Android ?
  8. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Dr Prius is a useful tool. Just make certain that the OBD2 adapter that you purchase is known to work well with DR Prius on an Android Tablet or Phone.
    JeffD
  9. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Dr Prius works good. You just need to buy a Carista Bluetooth adapter on Amazon for $29.99
