How do I remove the Toyota emblem from the hood? Need to prepare it for painting
Discussion in 'Gen 2 Prius Main Forum' started by SRQ, Mar 23, 2022.
  1. SRQ
    SRQ Member
    158
    56
    I'm overseas and don't have access to any Prius, but when I return I'm planning to repaint my hood. I couldn't find any guides on how to remove the front emblem; is it easy or is there an actual process?
    Edit: It can be removed with some fishing wire while carefully going around the 3 placement holes.
    #1 SRQ, Mar 23, 2022
    SFO likes this.
  2. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    Hair dryer to heat it up and soften glue?
  3. ydpplqbd
    ydpplqbd Active Member
    551
    253
    I agree on hair dryer. I would also add one of those disposable razor-knives that can be extended excessively (say extended to 1 inch or 1 1/2 inches beyond handle). The excessively extended, disposable razor-knife can be worked between hood and emblem AFTER emblem has been heated with hair dryer. If I was doing this procedure, I would likely apply blue painter's tape to hood around emblem (in an effort to avoid creating scratches in hood during emblem removal). Hood scratching is likely not an issue for OP as OP is repainting the hood. 03232022_razor_knife.JPG
    #3 ydpplqbd, Mar 23, 2022
  4. Mendel Leisk
    40,977
    Dental floss under it, after heating up?
    Another likes this.
  5. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    462
    Leawood, KS
    I
    Heating up the dental floss?
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    It has three placement holes? Mine fell off our 2006 while washing it last weekend and it only had 2 pins on the emblem and 2 holes in the hood. Used a razor to carefully clean off the remaining glue on the hood. Will probably reattach it this weekend.
