Just Bought a 2013 Prius 248k miles & found out it has blown head gasket
Discussion in 'Gen 3 Prius Main Forum' started by tannersprague, Apr 2, 2022.
  1. tannersprague
    tannersprague New Member
    Tulsa, OK
    I am seeking out advice on what direction to take with the situation I have found myself in. I recently purchased a 2013 Prius hatchback w/ 248k miles on the obo. I bought it from a locally used lot and I was under the belief at the time of sale to me that it had been thoroughly checked out to ensure it was operating fine for both the engine and the batteries.
    Fast forward to the same evening I bought the car I found out that the check engine light was on but given their word on that it was mechanically sound I dismissed the check engine light as something any old O' Reilly's store employee could clear and caulked up to not a big deal.
    So when the O' Reilly's employee who scanned the car just the following day after the purchase he received the P0301 code misfire cylinder 1 on his code scanner. They cleared it advising me that it's likely a coil pack or just a routine spark plug replacement fix.
    It ended up continuedly having some rattling and knocks in the engine and after ruling out the coil pack and the 4 new spark plugs nothing was fixed.
    I have an appointment scheduled for the this up and coming Monday to see if the dealership will treat me right and take back the car along with a full refund.
    I found out yesterday while desperately seeking out a solution to fix whatever the constant issue that approximately three months prior my purchase, according to the the actual service records at Toyota at nearly the same exact mileage I bought it for they advised the previous owner "...FOUND MISFIRE CODES. FOUND NUMBER 3 CYLINDER WITH WATER IN IT. POSSIBLE BLOWN HEAD GASKET OR CRACKED CYLINDER HEAD. BEST OPTION IS TO REPLACE ENGINE WITH A USED ENGINE. ESTIME GIVEN OF $6250 PLUS TAX AND MISC PARTS NEEDED TO REPLACE THE ENGINE ~ NO WORK DONE AT THIS TIME OTHER THAN DIAG. POSSIBLY TRADING CAR IN FOR ANOTHER CAR..."
    I am currently having the vehicle diagnosed again by the local Toyota dealership, and I intend on using this information to provide in my communication to the dealership Monday to in hopes of the full refund and return.
    If this somehow does not get resolved from the used car lot, I am looking at possibly having the Toyota service department address the blown head gasket if reconfirmed officially today.
    Is there anyone here from around the Tulsa, Oklahoma area that could assist if worse comes to worse and I am only left stranded with a mostly broken engine for a more affordable head gasket replacement/fix?
    I know this is a long winded post but I am just in a bad way at the moment and I'm out every dollar I spent to acquire this vehicle with something that was obviously previously documented as having know major engine issues.
    I look forward to hearing everyone's feedback.
  2. JC91006
    JC91006 Senior Member
    16,767
    8,565
    You already have the Toyota diagnostics, why do you need another one?
    248k miles is a lot of miles. You have to be careful not to go over the days allowed by law to get a refund, I think most places would be 3 days.
    #2 JC91006, Apr 3, 2022
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,462
    2,422
    Taylors, SC
    Unfortunately, another scam by one of those "buy here, pay here" lots taking advantage of those uninformed with lower income individuals with less income and resources.
    They evidently cleared the codes, sold the car to an unsuspecting buyer. The check engine light needs a few miles (50 or so) to develop a history and to be activated. By that time, it too late for the buyer to find out he or she has been scammed.
  4. Mendel Leisk
    41,392
    Any 3rd gen Prius over 150k miles is a likely candidate for head gasket failure. It’s sad when the misfire code crops up, that owners are steered into (usually useless) expensive coil/plug replacement.
    ^ Yeah consider this ASAP.
    #4 Mendel Leisk, Apr 3, 2022
  5. MPGboss
    MPGboss Member
    Los Angeles
    2021 Prius
    Sorry to hear, not sure there's a path to fix it without dishing out quite a bit of cash.
    However, given the current used car market values, I do wonder if fixing it to working condition you might be able to sell it without losing too much.
  6. Leadfoot J. McCoalroller
    8,075
    7,556
    Pennsylvania
    2018 Prius c
    A lot of this is going to be local- as in get familiar with OK state vehicle laws, contact the attorney general etc. I don't know what protections the State of Oklahoma has enumerated for you but that's where to start.
    If it works out that the car remains yours and you choose to fix the head gasket, take it somewhere other than Toyota. Lots of mechanics can replace head gaskets and there isn't anything special about the one in a Prius. It'll cost less getting it done at an independent shop.
    uncle pen and Mendel Leisk like this.
  7. tannersprague
    Tulsa, OK
    Although it was previously documented 3 months back as having the major engine issue at a Toyota dealership in Texas...I had the local Toyota dealership go ahead and do the diagnostic again to use as hard data on it's exact current condition as of now to show further to the owner of the used car lot, hoping it will make this situation right. :(
    I really appreciate everyone's replies and feedback. If worse comes to worse and I am forces to have to address it mechanically on my own, I'll take the advice from here about seeking a more independent shop.
    Thanks again,
    Tanner
  8. rjparker
    10,125
    6,287
    Most likely the car was traded in and then sent to an auction. Most used car guys have no clue and just moved it. But trying to do a head gasket alone is not recommended considering the cylinder already had coolant in it.
    Your best pathforward is a replacement engine. The 2010-15 Prius engines have several flaws, one being oil burning and the second being head gaskets. I wish there was a better way of warning people, several of us have been the sounding the alarm for years while others are simply fan boys about the car's issues.
    For close to $7,000 the dealer would have installed a rebuilt engine. A head gasket job alone is more like $1500-$3500 depending on factors like remachined heads and new water pumps and the like. But at this stage a simple head gasket job alone may fail and force an engine. However if you shop around you can have a rebuilt engine for as low as $3500 in some areas. Tulsa or OKC should be one of those areas.
    If you can get a refund do so immediately. A rebuilt engine is not the end of major maintenance for this car. $5k worth of master cylinder, pump and hybrid battery could and most likely will be in your future.
    The head gasket issue is so common some hybrid shops do three a day. Early signs are cold start rattles which most ignore or blame on egr. This shop does almost nothing other than gen3 head gaskets and engine replacements.
  9. tannersprague
    Tulsa, OK
    Thank you again for all of the good information, I'll take all of this into account! It has been a very unfortunate situation but i have faith hopefully something good can come out of this.
  10. Mendel Leisk
    41,392
    Yeah consider this: would you have bought this car knowing what you know now? Not a chance, right?
    There's a quasi-legal expression: "reasonal expectation". As in: you have a "reasonable expectation" when you buy a car, that it's gonna run ok, get you places, not immediately require heart-surgery.
    Tombukt2 likes this.
  11. JC91006
    16,767
    8,565
    The argument for reasonable expectation doesn’t really apply to a car with 248k. Maybe reasonable expectation is an engine overhaul
    Tombukt2 and Mendel Leisk like this.
  12. MPGboss
    MPGboss Member
    Los Angeles
    2021 Prius
    definitely a refund IF that's an option. I figured you would have looked into this already given the situation, these scam lots usually are good about one thing - it's yours once you drive off the lot.
  13. Tombukt2
    12,931
    2,322
    That's right and when i talk to these people selling these cars and they're asking $9,000 for a car that has 257,000 Mi on it and they're retort is well the car was almost $30,000 brand new i'm like who cares about that that is nothing to do in the reality of today even with today's prices i see generation twos with 173,000 MI with the hybrid battery been dealt with meaning a green check or a rebuilt car and reasonably nice looking from the exterior if it's the cloth interior it has the normal wear and tear on it and they're getting 6500 to $8,000 for this car in the southeast united states right now a year and a half ago i paid $2,000
  14. Tombukt2
    12,931
    2,322
    I just got done with this bud my recommendation would be go with the low mileage JDM asian takeout i bought an engine and transmission delivered to my door i don't remember 1186 or something like that probably the best thing i did with this car because having people work on it here is it costly parts are expensive and everything currently is expensive it cost me about $800 to get the engine and transmission in the car it didn't need anything the bolts put back in and it's sitting in the car and now it's running with no lights on and pretty much no problems if i would have rebuilt just the engine i would have had 3000 plus instead i got the engine and the transmission supposedly with 65k or less on it by the looks of it it looks like it even if it's got a hundred it's still a good deal mine had 220 230 whatever
  15. nicoj36
    nicoj36 Active Member
    518
    162
    Try this.
    Then clean your EGR, intake manifold, and throttle body.
