Won't move and squeaky/horn noise when I push the gas. (P0A7A & P0A78), replaced invertor: same.
Discussion in 'Gen 2 Prius Technical Discussion' started by Gen2Gentleman, Mar 8, 2022.
  1. Gen2Gentleman
    Gen2Gentleman New Member
    Died on hwy, triangle. Codes: P0A7A & P0A78. The car will go into gear, but won't move. I swapped the invertor with a used one, same exact problem. Is this the transmission?
    forward
  2. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
  3. PriusCamper
    PriusCamper Senior Member
    11,869
    4,814
    Pacific Northwest, USA
    There's a 3 digit subcode that goes with those error codes... It'd help us help us help you if we could find out what they are?
  4. Gen2Gentleman
    Ok. I'm in the process of getting the Techstream thing. I DO have an update: I checked my fault codes, again, after replacing the invertor, and NOW it only shows: P0A78. Thank you.
  5. PriusCamper
    11,869
    4,814
    As we often mention on here in discussions with inverter error codes is the inverter handles so many different aspects of the high voltage system, that problems with other systems can falsely point to the inverter as the problem because the inverter has to deal with that problem more than the other systems. I still have a replacement inverter on my parts racks from a few years ago that I never needed to use because of this. So now's the time to get after the rest of hybrid system with cleaning, inspection and maintenance.
  6. Gen2Gentleman
    Ok. I was just hoping someone has seen the exact same problem. My cat shield is, now, going to be in my way, probably, I welded that thing on. I guess I'm gonna have to learn a lot about testing resistance and electrical stuff? All I have is a multi meter.
  7. bisco
    50,821
    i have read there is a snoflake to click on in tech stream that gives the 3 digit sub code
    SFO likes this.
  8. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
    Hopefully these images can help those that need to know the 3 digit INF, detailed code, sub code, etc.
    Then look for :
  9. Gen2Gentleman
    Can you walk me through the techstream insatallation?
  10. bisco
    50,821
    unfortunately, no. there are lots of threads here, and success is hit or miss, because it is a black market product
  11. ChapmanF
    16,966
    Techstream itself isn't a black market product. If you download it straight from Toyota and use their activation keys ($65 for two days of use), there's nothing seamy to worry about.
    Some of the cheaper J2534 dongles being sold online will tout that they come with a copy of Techstream that might possibly forget to check its activation key. Those, of course, are not official copies, and can present some challenges in setup. People using those tend to dedicate an old beater laptop and make sure not to use it for anything important.
  12. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
    Which version are you attempting to install on what operating system?
  13. PriusCamper
    11,869
    4,814
    My cheap cracked software license on the very first day said it was good for 9,999 days... Seems reasonable? :)
  14. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
    Any updates?
    If stuck, just let us know and we will try to assist.
