My Prius went off-roading...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sneakychalupa, May 7, 2018.
  1. Sneakychalupa
    Sneakychalupa New Member
    Pensacola
    Long time lurker, first time poster...
    My car got stolen two weeks ago... the cops found it out in the sticks. The body is surprisingly not THAT bad, but as the car was on the wrecker I saw there were four wires hanging down underneath chasis: black, black, blue, white. Anybody know what these are for?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Welcome to your first post(y).
    Some questions:
    • Do you have a pic that is not as zoomed in?
    • Have you tried to start it yet?
    • Are there any dash lights?
    • What other damage is there?
    Keep us posted (y).
    m.wynn and SFO like this.
  3. Sneakychalupa
    Pensacola
    So, I got a key programmed (key from dealer, programming from reputable local on-site locksmith) the key works only to start car (no-remote locks or proximity starting).
    We put the key in.... everything was fine. Made the usual Prius noises... THEN it switched to the engine... imagine the worst sound 90's riced out Honda Civic, then put playing card in its spokes. I'll upload a video tomorrow. It drives fine, SOUNDS AWFUL. Taking it to repair tomorrow... hoping it's just a cracked exhaust pipe or something. Worst thing is that I didn't have comprehensive insurance so all of this has been out of pocket.
  4. Sneakychalupa
    Pensacola
    Nice gouge in the driver side door, took the rear view mirror, the wheels & tires, busted up a door panel, and stole the trunk mat.
  5. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Looks like they did a fair bit of damage :(.
    Do all of the electronics work when you fired it up?
    Any dash lights?
    Are you able to read the lights that come up?
    The wires don’t seem to be connected to an oxygen sensor or anything on the drive line, but to something else.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Thats the sound it makes when the engine runs out of oil and blows the bottom end of the engine up. Check the engine oil. They may have ripped off the oil filter or busted the oil pan.
    Will insurance total it out? Did you have collision? Post a recording if you can.
    How did they get it? Had to be left running or they stole the FOB.
  7. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    Are there any warning lights?
  8. fuzzy1
    10,405
    I'm also curious how it was taken, if it drove off under its own power. That isn't supposed to happen without a key fob. Some car prowls are alleged happening with spoofing devices, though actually starting the car with such devices is a more advanced step.
    #8 fuzzy1, May 8, 2018
    SFO likes this.
  9. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    The wires look to be to the missing rear O2 sensor. That's the grommet that goes up through the floor in the pic. And the exhaust appears to be missing entirely... They probably "harvested" the cat.
    #9 m.wynn, May 9, 2018
    SFO, edthefox5 and Raytheeagle like this.
  10. Sneakychalupa
    Pensacola
    You win the prize! Finally had a chance to put it up on ramps... and boom no Cat. Freaking blowholes... alright... taking it to exhaust shop on Monday.
    Also, they stole the mat/cover for the spare in the trunk, is that innate to prius or might it match another Toyota?
    @EyePrime, yea, check engine light came on, hopefully it will just be the fact that there is no oxygen sensor.
    Raytheeagle and m.wynn like this.
  11. m.wynn
    684
    1,229
    Queensbury, NY
    Sorry about that(n):(:(:(...
    The CEL will definitely show the rear o2 code (any of P0136-141) and/or P0420 cat code . You may want to see that the car gets an oem rear o2 sensor, either dealer factory part or Denso cross reference, which are one and same. Toyota's typically don't play well with aftermarket sensors, Bosch and the like. Given the age of the car, a new o2 sensor may or may not end up "exposing" the air/fuel ratio sensor as lazy, since both sensors will no longer be "aging in unison." Don't be completely surprised if in a few days or weeks after repair the car throws an A/F sensor or lean bank 1 code. Again, this is not a definite but definitely a possibility.
    Good luck with it(y).
    Raytheeagle likes this.
  12. Sneakychalupa
    Pensacola
    Thanks... I'm just gonna take it to an exhaust shop and have them do it. More than I wanna mess with. Thanks again for the help!
  13. Tjane
    Tjane Junior Member
    Ok
    Yes, I do. It was your catalytic converter they stole it to reap the gold and platinum. Same thing happened to me. I had to get a piece welded from manafold to muffler to quiet it down. The wires they clipped to get it, now your ck engine light will be on. Sorey friend, its gonna cost ya.
  14. Tjane
    Tjane Junior Member
    Ok
    I was at work at Chili's and someone in broad daylight stole my catalytic converter right out of a busy parking lot. Sounded like a moped but way louder. The wires hanging are the same color as mine .
  15. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    Tape up the bare wires so they don’t short out or they can cause ECM damage
