GPS and camera in permanent night mode
Discussion in 'Gen 3 Prius Audio and Electronics' started by Donners, May 15, 2022.
  1. Donners
    Donners New Member
    England
    About three weeks ago, I noticed that the GPS display had changed to night mode. I don't remember touching any levers or buttons but there it was in purples and blues (as seen in the pic - it used to be in colour). The reversing camera had also gone into night/negative mode meaning any lights behind me are showing up as black. Subsequently, as I am driving the map disappears and is replaced by an analogue clock and, when that appears, the stereo becomes very loud. Yesterday, when I reversed the camera view was almost whited out.
    Any ideas of how to revert this to normal? I have been through the settings but there is no day/night mode that I can find and most of the buttons when pushed say they are not active.
    All suggestions are gratefully received.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,148
    Tampa, FL
    Welcome, Donners. Let's see if @Tideland Prius has time to move this question to the Gen 3 forums so those drivers will be more likely to see it.
    Meanwhile, this doesn't look like a setting. More like some sort of failure in the display.
  3. Tideland Prius
    16,547
    *Moved*
    Hmm, it looks like the screen is failing.
    jerrymildred likes this.
