suspension/struts/coils/shocks replacement
Discussion in 'Gen 2 Prius Main Forum' started by Senchronize, May 25, 2022.
Tags:
  1. Senchronize
    Senchronize Junior Member
    30
    arizona
    Hello,
    My new(old) prius has loud clanking noise (I think it's the strut mount) whenever it goes over any bumps at >25mph speed. The passenger side front also wobbles when I try to manually push down that side of the car. The previous owner replaced them at 80000 miles and it is currently at 178000.
    Has anyone done a strut/coilover replacement for their gen 2 prius. I don't know if I should do this myself or have the shop do it. I know I'll have to replace both sides as a pair. Those of you that have done it please let me know which one do you recommend and what are some tips and tricks or videos? The shop I called says they must do an alignment afterwards, is that something that's' pretty easy to DIY for a gen 2? How long would it take? Thank you for your time
    for some ability reference I changed all the fluids in the car myself and I took the instrument cluster out and soldered the capacitor to fix the black screen problem, cleaned out the hybrid fan, and changed the spark plugs
  2. alftoy
    alftoy Senior Member
    1,132
    514
    Saskatchewan, Canada
  3. Senchronize
    30
    arizona
  4. alftoy
    1,132
    514
    Suggestion was to scribe the knuckle where it attaches to the bottom of the strut. Pic attached, not the greatest freehand. I'll probably just get an alignment since I am replacing the pads, rotors, hub and wheel bearings as well.
    Also have the printout from my Alldata DVD, only difference is the manual documents disassembling the strut and coil spring, not necessary if you buy the complete strut and coil spring.
    Senchronize likes this.
  5. Senchronize
    30
    arizona
    Thank you very much, it looks like that's something I can do. Scribe as in trace with a marker?
    Btw I just changed the spark plugs couple days ago and the windshield cowl doesn't need to be disassembled, but since you are doing the strut you might as well :D
  6. alftoy
    1,132
    514
    Scribe with a sharp nail set, fine paint marker or just wire brush the area and spray some paint. Preferably so its still visible when you install the new strut.
  7. Senchronize
    30
    arizona
    Do that before the wheels leave the ground right?
  8. Senchronize
    30
    arizona
    Video at 32min shows him greasing up the boot of the sway bar, isn't this not recommended anymore? As new sway bars come pre greased?
    Also he tightened the strut mount nuts before he put the wheel on and let it sit on the ground, isn't that a big no no as well? Thanks.
  9. alftoy
    1,132
    514
    Might be easier with the wheel off. Shock/knuckle definitely not moving either way.
    Don't think so. Not sure, I only watched till he removed the cowling. Note last 2 pages of the attached manual.
  10. Senchronize
    30
    arizona
    Ok thanks, I think I"ll follow this one, less down time in between
  11. Senchronize
    30
    arizona
    Also, where is your PDF from? I'm seeing a lot of different torque specs from youtube videos and website searches: https://toyota-specs.com/cars/2005/prius1.5/torque-specs_front.php
    https://attachments.priuschat.com/attachment-files/2017/08/131028_Frontwheelhub.pdf
    #11 Senchronize, May 25, 2022
  12. alftoy
    1,132
    514
    Alldata service dvd which they get from Toyota, also have a snip of actual Toyota service manual. Easier for me to search the dvd. Why are you getting torque values from toyota-specs.com or even you-tube back yard mechanics, has no affiliation with Toyota.
  13. Senchronize
    30
    arizona
    Just want to double check since I saw that the video had different info :) Thank you this helps a lot
  14. ColoradoCrow
    ColoradoCrow Senior Member
    1,093
    449
    Leawood, KS
    I
    HI. I have replaced all 4 on my car and I am going to do my wifes car in a few weeks. I did all the work myself. The rears are easier that the fronts. If you have removed and cleaned the hybrid battery fan in the back then that is half the rear job. To gain access to the bolts on top of the rear shock mounts. I would go with KYB Strut plus. They are OEM and all in one. KYB SR 4223, KYB SR 4224, KYB SR 4513, KYB SR 4514. Are the part numbers. I also replace the front sway Bars link at the same time. I don't think you can align the rear on a Gen 2 prius. a front end alignment is recommended after replacing the front struts. If you have the right tools it is straight forward. The Rears are a lot easier than the fronts.
  15. Senchronize
    30
    arizona
    Thank you, just needed to do the fronts though, as the back is perfectly fine for now. Good to know OEM is KYB, thanks.
    I don't have tools for alignment, what tools would I need?
  16. ColoradoCrow
    1,093
    449
    Leawood, KS
    I
    Well you can mark the lower swing arm where the bolts go through the front struts with a grease pencil to make sure that you tighten the new bolts in the same position as the old ones. Compare and measure all the lengths of your old parts and compare them to to new ones. Measure 5 times and write it down. Take lots of pictures. Go slow. plan on a full day for the fronts. I took my time and cleaned and regreased and re torqued my connections and drank coffee and listen to music and it took 4 hours. Just an FYI. You dont technically need an alignment it is just a good idea to prevent tire wear. Obviously if you get weird tramlining or tracking issues I would take it in for a front end alignment straight away. Ive seen 4 x 4 guys use tape measures and long aluminum L stock to make marks to transfer to their new truck. Check out YOOOOOuu Tube. I'm sure there is a video or 20 that show home garage alignments.
  17. Senchronize
    30
    arizona
    Thanks for the tip, when I mark it, do I mark it with the wheels already taken off and the car lifted or try to mark it while the tire is still on?
  18. ColoradoCrow
    1,093
    449
    Leawood, KS
    I
    Mark it with the wheel off while everything is still tight. I cleaned my old strut really well and dried it then used a white China marker to make my marks. Be sure to clean an re lube all the bolts when you put it back together.
  19. Senchronize
    30
    arizona
    do i need to disconnect 12volt first? I remember reading about when changing brakes need to disconnect that or it will cause problems, same for strut change or don't need to?
  20. ColoradoCrow
    1,093
    449
    Leawood, KS
    I
    Since your not touching anything mechanical I don't think you need to. For extra Safe ty you can disconnect the 12Volt. Never a bad idea. I use A trip for gas mileage info and B trip for tire rotation. so I just take a picture of the mileage and adjust my window stickers after I reconnect.
