MPG too high?
Discussion in 'Prime Fuel Economy & EV Range' started by Lievre23, May 30, 2022.
  1. Lievre23
    Lievre23 Junior Member
    Wading River, NY
    2021 Prius Prime all of a sudden driving in EV mode a lot (not charged). Gas mileage has gone up 10+ mpg in recent drives (to 65-70 mpg). Great for wallet but mechanical Issue?
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,148
    Tampa, FL
    Those numbers sound about right for rural or city driving in a Prime. At 50 mph on level ground my Prime only runs the engine about 50% of the time. In those situations I get 65 mpg or better. Over 60 mph on level ground, the ICE will run almost continuously.
  3. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    Lotsa folks here drive nearly always in EV for months. The car will warn you if the gas in the tank is getting stale and reading the manual it only expects you to burn 5 gallons in 12 months.. so about half a tank of gas in a year. If you're filling up more often than once a year you're good to go
    douglasjre and jerrymildred like this.
  4. bisco
    51,840
    i don't understand your first sentence. do you mean the engine is running less, but all other variables are the same?
  5. MalachyNG
    304
    225
    Northern NY
    2022 Prius Prime
    I think I misunderstood. Are you worried that the car is hesitant to use the gas engine because of a possible fault?
    If so, no you would definitely have a check engine light, dash warnings or it simply wouldn't let you start.
  6. Gokhan
    Gokhan Senior Member
    6,147
    2,431
    Paramount CA
    No, this is entirely normal. 65–70 mpg is still on the low side for the Prius Prime. EV-mode usage during HV driving varies. I got up to 120 mpg in 50-mile round-trip HV driving in stop-and-go traffic in warm weather.
    jerrymildred and CR94 like this.
  7. Lievre23
    Wading River, NY
    My concern is...I typically average 55mpg, and all of a sudden its up to 65mpg+ (same exact commute). I am not charging the car but it seems to be using EV mode more than ever
  8. bisco
    51,840
    but i don't understand. you say you're driving ev more.
    rbwilli likes this.
  9. Lievre23
    Wading River, NY
    By EV “mode” - I mean this ^.
  10. ETP
    2,802
    1,170
    Auburdale FL
    Consistent long term 74ish on the mpg read out only.
    Might be 4-5 mpg off. Very difficult to verify with SAMS club pumps all over the place in accuracy.
    It did not get that high until 2-3 full charges. Now I just drive it and put gas in once in a while. :)
