Rooftop tent on the v
Discussion in 'Prius v Main Forum' started by Suebee, Jun 1, 2022.
  1. Suebee
    Suebee Junior Member
    Bay Area CA
    I’ve seen this question asked in different forms but nothing specific to the v. Is it possible to put a rooftop tent on a Prius v? And with my moonroof get in the way?
  2. Air_Boss
    Air_Boss Senior Member
    4,189
    1,177
    New Yawk
    You can put a roof rack on a v, you can put a slab on the rack for a floor, and you can put a tent on the slab, but how much total load on the rack and v roof will be the issue.
    #2 Air_Boss, Jun 2, 2022
  3. BiomedO1
    3,496
    1,818
    SacTown, Ca
    The short answer is NO; roof rack limitation is somewhere around 100 lbs. A properly done rooftop tent system is usually on pickup trucks; with a heavily modified, roll-cage style rack to support the extra weight of tent and occupants.
  4. Gandolf989
    Gandolf989 Junior Member
    34
    I have a 2012 Prius V and I was thinking about taking out my back seats and building a platform with panels that open towards either back door. I could then put in an air mattress and car camp. I could store stuff under the platform in the back seat if I wanted. Thus leaving the car on all night I would have a temperature controlled sleeping area. There are also small tear drop trailers that a Prius V might be able to handle. Its hard to void a warranty that has already expired...
  5. BiomedO1
    3,496
    1,818
    SacTown, Ca
    Get the car windows ceramic tinted. Everything behind the drivers door 'limo tint'; then the lightest tint you can find for the front doors. Ceramic tint has a very high heat rejection rate and it'll keep the inside cool. Make sure you can access your spare tire; if you need to - without ripping the car apart.
    There's a lot of YT videos on how to setup your Prius camper
    Good Luck
