How long can let car sit unused?
Discussion in 'Gen 3 Prius Main Forum' started by Robertyboberty, Jun 3, 2022.
  1. Robertyboberty
    Robertyboberty Junior Member
    Fort Worth, TX
    My 2012 Prius just got into the dealership luckily right before it’s 10th birthday to qualify for the free abs brake booster/actuator fix. But the parts are back ordered and they have had it for just over a month now. They gave me a loaner Camry, but I am worried about my Prius Hybrid battery sitting too long.
    A couple weeks ago I asked if I could just take my car and bring it back when the parts came in….but they didn’t want me to do that because it’s covered by the warranty and I guess a safety liability issue.
    Does anyone have any insight if letting it just sit unused for over a month could cause any damage?
    I am thinking I should go up there to start it and let it run for a bit, or maybe see if I can drive it around for an hour.
  2. JC91006
    JC91006 Senior Member
    16,639
    8,495
    This is a tough situation, a weak/older hybrid battery can go out of balance without being driven in a month
    Robertyboberty likes this.
  3. Mendel Leisk
    40,245
    Owner's Manual says this (on page 30):
    Still, over a month, I'd be starting to get concerned too.
    Robertyboberty and Johnny Cakes like this.
  4. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    I agree with jc91006. Especially a hybrid battery that has been in a lot of heat could be weak at 10 years old.
  5. Johnny Cakes
    Johnny Cakes Senior Member
    1,033
    772
    Virginia, USA
    Using the quote you got from Mendel Leisk, perhaps *they* would be willing to drive it for X miles. The dealership always thinks they are smarter than the customer, but it would be hard for them to argue with the manual put out by the manufacturer.
  6. ASRDogman
    ASRDogman Senior Member
    7,014
    3,669
    Go in and let it idle and charge the battery... They shouldn't have a problem with that.
    But, if it does go "bad" while under their care, they will need to charge it, or replace it....
  7. Rmay635703
    Rmay635703 Senior Member
    2,633
    1,654
    Somewhere in Wisconsin
    2013 Chevy Volt
    Too bad the car isn’t like the Gen 1 with a built in charger, I would think the dealership should have to do a balance charge occasionally and be liable for doing so while it sits in their care
  8. ASRDogman
    7,014
    3,669
    mmmm "If the hybrid battery becomes fully discharged
    and you are unable to jump-start the vehicle with the
    12 volt battery, contact your Toyota dealer"
    Wow, I didn't know the 12 volt battery was able to get the hybrid battery
    charged up! (y)
  9. Rmay635703
    2,633
    1,654
    2013 Chevy Volt
    A bit of misinformation or engrish
  10. 3PriusMike
    3,069
    2,399
    Silicon Valley
    The 12v battery starts the computer and the gas from the fuel tank runs the engine that charges the hybrid battery
    Mike
  11. 2010moneypit?
    314
    122
    Beaumont ca
    The HV battery is what turns over the ICE.
  12. 2010moneypit?
    314
    122
    Beaumont ca
  13. Mendel Leisk
    40,245
    But it can't do that without a wake up call from the 12 volt.
    2010moneypit? likes this.
  14. ASRDogman
    7,014
    3,669
    Might be a good idea to actually READ what was written........
  15. PriusCamper
    PriusCamper Senior Member
    11,869
    4,809
    Pacific Northwest, USA
    There was a long-haul trucker who posted on here once... He had a gen2 prius he bought and then didn't get around to driving it for over a year and if started right up with no issues. As the saying goes, "Your Mileage May Vary."
  16. PriusII&C
    PriusII&C Active Member
    370
    130
    San Jose, California
    My 2012 Prius C has been parked in my garage for over 2 years. I start the car and check the battery every 2 months. It never shows any change in the traction battery charge level. But the auxiliary battery does show voltage drop so I connect a smart charger to the 12V battery.
    Robertyboberty and bisco like this.
  17. Robertyboberty
    Fort Worth, TX
    Yes it has mostly been garage kept, but has been in the hot Texas summers every year.
    That does make me feel better. Thank you.
    #17 Robertyboberty, Jun 4, 2022
  18. Robertyboberty
    Fort Worth, TX
    Thank you all for the replies. Just to be cautious and help ease my mind some, I have decided I am going to go up to the dealership Monday and let it idle for a while and blast the ac and pump the gas so the ICE comes on. I need to get a few of my belongings out of it anyway.
    ASRDogman and bisco like this.
  19. bisco
    50,819
    don't use the a/c, just hold the brake down tight, floor the gas, and wait for the battery to fill up
    Robertyboberty and Mendel Leisk like this.
