2010 Prius P3004
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ryeck, Jun 20, 2022.
  1. Ryeck
    Ryeck New Member
    Kansas
    I have a 2010 Prius setting a p3004. I just replaced the HV ECU for a p0a0d. Car still won't start but I saw my SOC was at 0%. Would that cause the p3004 and if so is that battery junk? All cells are above 15v. I know that is still low. Any help appreciated.
    Thanks Ryan
  2. PriusCamper
    PriusCamper Senior Member
    12,777
    5,177
    Pacific Northwest, USA
    SOC takes time to establish accurately after system is reset. What's voltage of the pack? You sure you got everything reconnected correctly?
  3. Ryeck
    Ryeck New Member
    Kansas
    Cell volts are a little over 15v on all. The only thing I havent rechecked is the inverter connectors. I've done my services plug Idk how many times hoping it would fix it.
  4. bisco
    51,969
    Did you complete the third step sliding the safety plug?
  5. Ryeck
    Ryeck New Member
    Kansas
    Yes I did.
  6. bisco
    51,969
    #6 bisco, Jun 20, 2022
  7. Ryeck
    Ryeck New Member
    Kansas
    Yeah I've done that multiple time making sure it wasn't me. I'll have to get it in to my shop and go through the pinpoint testing and really diag it I guess
  8. Ryeck
    Ryeck New Member
    Kansas
    3004-800
  9. bisco
    51,969
    sounds like you need an inverter, has the ipm recall been done?
  10. Ryeck
    Ryeck New Member
    Kansas
    Yeah recall has done already.
  11. Ryeck
    Ryeck New Member
    Kansas
    Ok finally got back to it and it was the inverter. After trying a couple hv ecu I threw an inverter in. When doing the pinpoint test it had me ohm the wires from the inverter to the ECU and spec was 120 -140 but I had 150 on each ecu and if out it says replace ECU.
  12. ChapmanF
    18,238
    o_O as in, somebody actually verified that the safety interlock circuit had continuity all the way through, and the ECUs interlock sense input had failed?
    I think this is the first time I've heard of a P0A0D solved that way.
