LRR Tires- No Longer being hyped?
Discussion in 'Gen 3 Prius Main Forum' started by kc5dlo, May 20, 2018.
  1. douglasjre
    douglasjre Senior Member
    2,177
    717
    Null, NL
    Douglas at Walmart is made by Goodyear They cost about $44 each $15 each for installation and they last the same as every other and it grips the same in the rain. Even if the fuel economy were slightly different you couldn't make up the price difference of $80 more per tire if you tried. Do what you want with your money but these $44 tires are awesome. By the way I get 195 60 R15. I can't stand the high sidewall If you want good tires you have to read the sidewall. The date of manufacture the tread wear the traction the temperature the load rating in the speed rating all matter. Brand means nothing except how much you pay for their advertising campaign
