Featured Siemens’ Funky New/Different EV Connector
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by kenmce, Jul 27, 2022.
  1. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    Siemens and Philadelphia-based ConnectDER have come with a kind of crazy new way to set you up with an EV charger without having to screw around with the breaker box and running wires. You pull the electric meter off your house, plug their meter collar into the meter pan (The place where your meter mounts on your house) and plug the meter on top of it. Boom, your done. No other wiring required. Could be great if it works:
    https://electrek.co/2022/07/27/siemens-home-ev-charger-adapter/
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    As a paranoid, electrical devices before any fuses or circuit breakers seems suicidal.
    Am I missing a way to turn this off after the transformer on the pole?
  3. PriusCamper
    PriusCamper Senior Member
    12,721
    5,143
    Pacific Northwest, USA
    Of course some power companies will say they own your electric meter and won't let you "tamper" with it. And seeing as the device is proprietary there's going to be lots of conflicts. And I bet if you asked a professional electrician what they think of it they'll have a long list of reason for why its stupid. I mean they aren't solving problems for electricians, they're convincing consumers that their snake oil idea is "easier" but good luck getting an electrician to agree that adding circuits outside the box that's designed for adding circuits is a good thing. Add to that getting a permit from your local planning department to install it is going to be about as easy as pushing a rope.
  4. Salamander_King
    Salamander_King Senior Member
    11,016
    8,948
    New England
    Currently approved for only a handful of utility customers. Not available in my state. Yeah, if available, it will save $10k in my case..
    #4 Salamander_King, Jul 27, 2022
  5. PriusCamper
    12,721
    5,143
    In theory it will save you $10K... Catch is, you have to get a building permit/inspection for this kind of install and have you ever asked a planning department for a permit to do something they've never given a permit for? I mean maybe if you're in Houston, the largest city in the the US with no fire code or basic regulations, but not in places that are actually responsible.
  6. Salamander_King
    11,016
    8,948
    New England
    Not sure if that is going to be a problem. Since DER is not approved for use in our state, I have no first-hand information, but from the way it is explained on their website, DER is installed by the utilities, not by the individual homeowner. My feeling is that just like the meter belongs to the utility, the DER belongs to the utility. For example, the device is free for the installers for ConEd utility customers in NY.
    ln any case, it is not available for me. And as far as the permit goes, you are talking about the problem in a big city. I live in a tiny village in a rural area where people build their own houses DIY from scratch all the time. I doubt it will be a big deal. Incidentally, I recently asked a town clerk about a building permit needed to install an additional wood-burning stove and chimney in our home. The answer I got was "You don't need a permit for things like that." LOL
    #6 Salamander_King, Jul 28, 2022
  7. PriusCamper
    12,721
    5,143
    Yeah... That would make way more sense... But at the same time, the direct approach of expanding the existing box on the customer's side of the circuit is going to be a hard expectation to eliminate from everyone involved in the bureaucracy of power meters. Makes me wonder if there's a startup business that will do it differently than this meter adapter? The future demand for it is definitely going to be there, that's for sure.
  8. bisco
    51,882
    i doubt that will fly here, we've got more codes than paper to write them on
  9. PriusCamper
    12,721
    5,143
    No wonder we're running out of trees! I'm sure all the tree farmers would have way more trees ready to cut if they didn't have any regulations anymore right?
  10. mikefocke
    3,991
    1,801
    Sanford, NC
    But doesn't it assume you have a specific type of meter? Ours are read remotely so I don't have the type shown.
  11. Todd Bonzalez
    Todd Bonzalez Active Member
    250
    160
    Ireland
    Seems like an interesting way to burn your house down.
    I had assumed the utility company would need to come out to install this collar, but the article mentions electricians and EV charger installers too? In Europe, everything on the meter side of the distribution box is the utility company's property so you can't touch it. The same doesn't apply in the US or is it more nuanced? Wild :D
  12. kenmce
    1,544
    515
    NY
    They would never get a UL listing if it didn't have a fuse/breaker in it.
    For $10k you can put a little hustle on. Find a contact person. Tell them you're a heavy-duty electric car user who is all plugged in to the national electric car scene. Tell them you'd be a great beta tester and you'd be willing to write up online (Here in fact) the performance of their device in the demanding New England weather. The worst they can do is is decide to give one to Bisco, but not you. You know how it is, those &^%! Bostonians get everything...
    I assume they''ll have an early test model for whatever is the most common meter, and if it sells that they'll expand out to all the main types.
    In Europe Siemens may go under the name "Siemens Aktiengesellschaft", or in Éire they may use another name entirely, I don't know. In the US they are an industrial heavyweight with a solid history and reputation, particularly for making electrical equipment. If they were some no-name Chinese company I too would run screaming from the very idea. If their name is going on it then I would expect it to meet or exceed all current commercial standards for electrical devices.
    In the US at this time their is a big push on to increase the market share of EVs. We are quickly going to run into the problem of nowhere to plug them. If you have parking near your meter, this should be a fast and cheap way to get you hooked up and going.
    In terms of *who* puts it in place, anyone who is qualified and allowed to install a meter should be able to do this, and it won't even be a long service call.
    drash and Salamander_King like this.
  13. John321
    John321 Senior Member
    1,457
    1,405
    Kentucky
    Very interested is this device from an electrical engineering standpoint.
    Here is the cut sheet from the manufacturer
    Solar_Collar_Smart_Module_Cutsheet.pdf (connectder.com)
    "ConnectDER’s Solar Meter Collar + Smart Module is designed to rapidly connect grid-ready solar PV assets. It is a UL-listed, NEC compliant, low-cost alternative to traditional installation methods"
    The company that actually makes this is ConnectDER and they are partnering with Siemens to distribute and market
    The main advantage is the consumer doesn't need to upgrade their panel to install this. Estimated time to install is 10 to 15 minutes.
    Here is the company website for the device
    Solar Installer Interconnection Tools (connectder.com)
    #13 John321, Aug 3, 2022
  14. Storm88000
    Storm88000 Active Member
    321
    145
    LHValley, PA
    2020 Prius Prime
    I’m old school. If I:
    1) Don’t understand it
    2) It’s expensive or dangerous
    — I don’t touch it. Lol
  15. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    I can see apartment buildings being able to take advantage of these if they have separate meters outside. Easy way for renters to offer such a service for an additional fee. After all I'm sure the local electrical utility wouldn't mind adding an equipment rental fee.
    Yep there are certified electricians who are allowed to interface with the grid and/or electrical providers. If it become popular I'm also sure there would be an explosion of contractors for the electrical utilities spring up just to install and test these.
