P0AA6 w 526 and 612 : I don't think it's the battery - what next?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Goneballistic, Aug 1, 2022.
  1. mr_guy_mann
    mr_guy_mann Senior Member
    4,036
    1,965
    NJ-USA
    Interesting. So if you set your normal DVOM to volts, you don't get any voltage reading at all between #13 stud and the battery case?
    I can't tell from your pics, but I'm wondering what that dark half-circle is under the base of #13 (near where the mounting screw would be on the underside?). Don't know if that's a smoking gun or not...
    And I probably would NOT use a megger while the battery ecu is plugged in- don't think it would like 500-1000V.
    Goneballistic likes this.
  2. Goneballistic
    Goneballistic New Member
    26
    Utah
    Oh man, I didn't even notice that. I don't remember any discoloration so that might be a shadow but I might have missed it. Good catch, I'll go check right now.
    I have the ECU unplugged so I should be ok. Hopefully. I may have run the first test before I unplugged it. I can't remember.
    I'm going to go look at 13 now.
  3. Goneballistic
    26
    Utah
    ECU socket looks perfect. But good call on the harness, I'll check resistance on each wire. Might be worth just replacing the whole thing if it's that cheap
  4. ChapmanF
    18,062
    The answer could be simpler. Your megger is showing a resistance there of 9.5 million ohms. What's the maximum resistance reading your Craftsman multimeter will display?
    Even with the megger pushing 500 volts, the leakage current through a 9.5 MΩ resistance is only about 53 microamps.
    With a regular multimeter, which is probably only using a few volts in the resistance mode, it would have to detect a resulting current down at some fraction of a microamp. That can be a tall order for a general-purpose meter.
    Well, in the catalog, it's called "wire, frame, #2", the same way a catalog might list a "bearing, wheel", a "cover, valve", or the like.
    When we take the commas out and aren't talking like Yoda, those are valve covers, wheel bearings, and number two frame wires.
  5. Goneballistic
    26
    Utah
    See this is why being dumb is a severe handicap. That's a great point and I'm guessing a nearly 20 year old consumer grade ohmmeter cannot do that.
    So that makes sense to me.
    It's actually surprising that if this is, in fact, the problem, that the Prius could detect that small of a leak and shut itself down.
    Another question, I just tested resistance on the longer #2 frame wire, it's testing between .4-.7 ohm.
    The shorter one is zero.
    Is that cause for concern at all? Or does that seem normal for a heavy wire that's about a foot or foot and a half long?
  6. ChapmanF
    18,062
    The Prius itself does not just rely on detecting tiny current leaks to detect an isolation failure. On top of the battery's DC voltage, the battery ECU imposes a distinct, recognizable AC waveform that looks like something invented by Klingons. The manual, in a funny translation, calls it the "short wave". Not as in, you know, the radio band, but just a wave, that's used to check for shorts.
    If the battery ECU can then detect any of that same AC waveform outside of the high-voltage wiring, you get the code.
    Your zero reading is what's more surprising.
    Yes, 0.4 to 0.7 Ω is too high for a couple feet of heavy wire. But normally, when you're testing something like that with a general-purpose ohmmeter, your reading ends up being more about your test leads and how clean the surfaces are where you put the probe tips, than it is about the resistance of the thing you meant to measure.
    A milli- or micro-ohmmeter made for measuring such low resistances will have a four-wire connection, to make sure it can cancel out those lead and contact resistance effects.
  7. PriusCamper
    PriusCamper Senior Member
    12,680
    5,118
    Pacific Northwest, USA
    They used to cost $60... Do you know anywhere they're still that low? I'm seeing up near $80 these days. I'm actually working with Professor Joe and some rebuilders to try to create and aftermarket version of these, as well as refurbished ECU because both of the parts are getting harder to find.
  8. PriusCamper
    12,680
    5,118
    He said ships in 1-2days on website orders. Most battery folks use UPS for shipping and my experience is if you order early Tuesday you get it by Friday, but sometimes that turns into Monday.
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    $62
    2009 Toyota Prius Parts - ToyotaPartsDeal.com
    Goneballistic and PriusCamper like this.
  10. alftoy
    alftoy Senior Member
    1,132
    517
    Saskatchewan, Canada
  11. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    I order them 10 at a time, which kind of dilutes the shipping cost, and have never had any problems getting them.
    Shipping from Japan is $17 the UAE is only 10 bucks? That's impressive, but I've never ordered anything from yabbadabbado, is it reliable? 3 weeks? or is that typically accurate? Any personal experience with those delivery times?
  12. alftoy
    1,132
    517
    Haha, speaking from personal experience? Yes I did order some plastic clips (half price including shipping compared to Canada) from UAE, currently there is no postal delivery from Japan to Canada. Yes took 3-4 weeks but I received the order. There is postal service Japan to USA, seems to be more cargo flights.
    Gen 2 batteries $1300 from Amayama, but Amayama cannot obtain MSDS from Toyota to allow them to ship. DARN.
    Email from Amayama
    Japanese Customs does not allow flammable, high pressure or prohibited items such as batteries, airbags or gas generated seat belt pretensioners to be sent by any form of shipping from Japan without an MSDS document (data sheet from the manufacturer outlining safety procedures for the product) which the manufacturer has refused to provide to us, so I'm afraid we cannot supply it.
    #32 alftoy, Aug 5, 2022
  13. Goneballistic
    26
    Utah
    Ok what is the lowest voltage an individual battery missing should go to? And what is the highest?
    I thought they should not go lower than 6.0 v or 6000 mAH, and not over 7.5v or 7,500mAH.
    I set up my charger to cut off at 7500mAH in the discharge -> charge cycle and the four I did charged to over 8v. Some of them to 8.6v
    Hopefully I didn't mess up those cells. No idea why the charger went over my cutoff value.
    This thread shows a much higher variance of cell charge values
    How I Recondition Cells | PriusChat
    My charger right now
    #33 Goneballistic, Aug 7, 2022
  14. PriusCamper
    12,680
    5,118
    Welcome to the hell that is using toy remote control car battery chargers to repair non-toy real car hybrid batteries... In this use case, the less you rely on the "features" of your charger the better.
  15. Goneballistic
    26
    Utah
    Goshdanggit. Well that's frustrating. I'll shut it down..I really wanted to use the cycling capability.
    What's the recommended max voltage for these? 7500mAH?
    they didn't get warm at all.
    Are there chargers that work? Ive seen a round one that says it's for hybrid batteries in some of the videos. I'll find which one it was.
    ETA: It's frustrating cause I even got the higher end one hoping it would work better.
    Oddly the voltages on the screen are not matching my multimeter.
    Now I trust nothing
    #35 Goneballistic, Aug 8, 2022
    PriusCamper likes this.
  16. PriusCamper
    12,680
    5,118
    Yep, that's what I was referring to that @TMR-JWAP says is no big deal and you can do this with cheap equipment. Of course he's more determined than most, so gets better results.
    As for how I do it: I usually charge them up till it reaches roughly 8.7volts... I also charge in stages to keep heat down. But once you have a rack of modules being charged with multiple chargers ( I'm up to seven total chargers and 7 total light bulb dischargers) it's easy to have some charge too long. I've found that the more in need of reconditioning a module is the faster and higher the charge goes. As in when I first start working on a bad pack, many modules will soar up past 9volts quickly, but after a third round of reconditioning it takes way too long and creates an uncomfortable amount of heat charging them back up to a full 8.7v, which of course quickly drops down from that number soon as you stop charging.
    #36 PriusCamper, Aug 8, 2022
  17. Goneballistic
    26
    Utah
    OK so a couple of questions;
    1. so it's OK to charge them up to 8.7v? If that's OK I'll throw them back on the charger. It's trying to charge them up to about that. I had it set on a Discharge/Charge cycle, and I THOUGHT I had set an upper limit of 7500mAH, but I think that limit was for manual charging. So the auto charger was discharging them down to about 6.5 and up to about 8.7'ish. If that's OK maybe I'll just let them cycle each cell 3 times while I wait for me replacement. the other problem is that the voltage indicated on the charger, isn't what my ohmmeter is saying. So now I'm kind looking at the charger with a jaded eye....o_O
    2. I am not sure how to test their capacity now, I ran a load test with a light bulb. Just hooked a headlight bulb up to each cell for 10 minutes, checked voltage before and after the test, but none of them showed any real variance. They all tested about the same. So I was going to run the discharge/charge cycle and let the machine tell me what they cycle would allow, to try and get a sense of true capacity. Without that test, I"m just guessing when I put these all back in.
    3. Last thing is I'm stressed, I'm not sure how to balance these cells. When initially tested, all cells tested within .002 v of each other. now with the charger I'm going to be all over the place. I have seen on videos where people flip half the cells around and use solder wire to connect all the positives, and all the negative terminals, do you just let it sit like that for a day or two? or do I throw a charger on it and charge all the calls together with the +'s and -'s connected to each other?
    Not sure how to balance this the correct way before I put it back in the car.....
  18. Goneballistic
    26
    Utah
    I *think* my pack is in pretty good shape, other than 13 which appears to be leaking. So I'm going to probably just try to get them back to 7.7v or something and then get them balanced.
    Unless you can think of another test I can use to determine if any of them are lower capacity and should be replaced.
  19. PriusCamper
    12,680
    5,118
    Now that I have 7 chargers and 7 dischargers the reconditioning is fairly efficient, but still takes a long time. But early on with far less gear took forever.
    And don't worry too much about resting voltage balance too much, just get all the modules as fully charged as possible by charging multiple times to keep temps down. The voltage balance during a heavy charge or discharge in the car is where the lack of balance is the problem. And it's not that expensive to: Build Hybrid Battery Maintenance Gear For Under $100 | PriusChat
    In general, it's quite the rabbit hole to go down... Some people just replace the bad module and luck out with as much as a year with no further hassles.
    Obviously because it's your daughter's car, you're gonna wanna make sure she has an OBD2 in the glove box and has Dr. Prius app on her phone so ya'll can monitor the pack's vital signs and clear error codes so she doesn't get stuck on the side of the road.
    As for additional diagnostic work you may want to do on the pack, here's a list of how many things you can try starting with your requested test for lower capacity:
    --Record voltage drop at the 2 minute mark with a 12v, 50w bulb (Halogen bulb from Prius Headlight is ideal) 0.2v to 0.4v is normal loss
    --Test modules for voltage loss with higher amp loads for shorter period of time
    --Use thermal camera to detect cells running hot because they'll fail sooner than ones that don't
    --Weigh each module on a scale and eliminate the lightest ones (hydration/venting damage)
    --Record voltage loss of each module 3 days or longer after full charge & balance (self discharge test)
    --Monitor voltage discharge during reconditioning for modules that fall off a cliff faster than other (symptoms improve w/each conditioning round)
  20. Goneballistic
    26
    Utah
    Ok, new plan: frick it, we're going with the auto charger.
    Since running a manual cycle was super time consuming and the results were about the same, I'm just going with the auto charger. It's easier and doesn't appear to be doing any harm. It's not respecting my upper limit but I can set niMH rebound sensitively that will keep it from over charging.
    I left it on default. I can choose 1-20 mV per cell, I don't know what"default" is, but YOLO.
    Set it to run last night, hoping i would not wake up on fire. This morning two of four cells were done, two still charging at 3.0A, and not warm at all to touch. Could not tell difference between a charging or resting cell.
    Here's the setup
    I also got two cells in the mail, priuscampet your guy sent a very clean cell that was fully charged.
    The eBay cell is really dirty and not charged.
    I tried balancing them and that worked PERFECT. so now I know I can slack balance them without power. Just hook them together
    Looking good, working on next four cells now. I have two other chargers, will get them in the game later
