Radiator drain plug/petcock
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Suzmaca12, Aug 7, 2022.
  1. Suzmaca12
    Suzmaca12 New Member
    Los Angeles
    I am attempting to drain the engine coolant but the petcock isn’t budging. Does anyone have any suggestions on how to loosen? It’s plastic so I want to be cautious and not break it. I found that you can get a socket for it but I don’t know which one would fit. Thanks! Suze
  2. rjparker
    9,512
    5,822
    The first time it will be tight. You could buy a replacement just in case or at least have one available at the time.
    #2 rjparker, Aug 8, 2022
    Suzmaca12 likes this.
  3. nicoj36
    nicoj36 Active Member
    518
    162
    Not even with pliers?
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,343
    2,337
    Taylors, SC
    I just lossened and took mine out with my fingers reaching it from the top behind the radiator.
    Tim Jones and Suzmaca12 like this.
  5. Mendel Leisk
    40,472
    A pair of pliers or adjustable wrench can help. Don't clamp hard, just snug on the flat part, carefully turn (counter clockwise).
  6. xliderider
    xliderider Senior Member
    8,033
    3,211
    Honolulu, HI
    Use something like this, put the "wing" of the drain cock in the slot and turn it.
    Additionally, using a 1/4 inch hex driver ratchet handle will help to turn the bit.
    Georgina must have "man hands" to be able to turn a drain cock that has been stuck in place for years without being moved by hand. Especially, since reaching the stopcock will force you to bend your wrist and fingers into awkward angles where you can't get any torque applied to turn anything. Screenshot_20220808-081916_Amazon%20Shopping.jpeg Screenshot_20220808-082248_Amazon%20Shopping.jpeg
  7. Suzmaca12
    Los Angeles
    Thank you all for responding! I really appreciate the suggestions. I tried again after posting and was able to loosen from a different position underneath using my right hand instead of left. It’s probably a girly strength issue lol
    Thanks again!
    Mendel Leisk and Tim Jones like this.
  8. Tim Jones
    Tim Jones Senior Member
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    I took mine out several times and no problem at all. U sure you unscrewing....?
  9. Tim Jones
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    I always got mine from the top................. pretty easy
  10. Tim Jones
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    Why did you take it out?
  11. Suzmaca12
    Los Angeles
    I drained to replace along with inverter coolant. Have taken out intake manifold to clean along with EGR pipe and cooler. I also replaced pcv valve while I had manifold out. This thread EGR cooler cleaning-Prius V 2016 | PriusChat helped me get out the cooler when I thought of giving up.
    xliderider and nicoj36 like this.
  12. xliderider
    8,033
    3,211
    Honolulu, HI
    I also drained and replaced the ICE coolant while doing the EGR circuit cleaning as well.
    Now it will be on a 50K cycle of coolant replacement and EGR cleaning since the coolant change interval after the factory coolant is replaced is 50K. This is due to the fact that some of the original coolant remained in the heater core and hoses, so subsequent coolant drain and fills are on shorter intervals.
  13. Suzmaca12
    Los Angeles
    50k interval… thanks! Got it…
    xliderider likes this.
  14. Tim Jones
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    No sell it before it puts you in the poor house. All gas $$$ will be lost when the car craps out on you.......and it will...............
  15. Mendel Leisk
    40,472
    Hey I've got a pair of vise-grip style oil filter pliers I keep in a drawer in the kitchen, primarily for breaking loose the lids on spaghetti sauce jars... :unsure:
  16. xliderider
    8,033
    3,211
    Honolulu, HI
    My sister with arthritis recommended this handy jar opener. It is very easy to use and lightweight, but gives you leverage on the most stubborn caps/lids. 4000+ positive reviews. Screenshot_20220809-164514_Amazon%20Shopping.jpeg
  17. xliderider
    8,033
    3,211
    Honolulu, HI
    Here's another picture of how it looks opening a jar of spaghetti sauce lol.
