Can't find this clip.
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Aug 17, 2022.
  1. Prius92
    Prius92 Active Member
    592
    121
    Iowa
    Looked in all the parts catalogs.
    There is a clip that should go in the plastic around positive battery terminal, into the metal hold down bracket on the battery.
    Must of been lost when first changed.
    Goes in this hole, seen here.
  2. Prius92
    592
    121
    Iowa
    Idk why this forum hates links, pics, etc. Such a big annoyance...half the links I post on here get auto removed.
    The clip would of went in the hole on the right hand side of that plastic mount. It keeps the wiring from moving around as much.
  3. alftoy
    alftoy Senior Member
    1,132
    517
    Saskatchewan, Canada
    That is so weird, I go to reply and the image pops up on my reply, but doesn't show on your post.
    Red fusible link cover? Pic of my battery link, doesn't have a cover on the right side of the fusible link. My red cover missing the little cover that goes over the pos post.
    #3 alftoy, Aug 17, 2022
  4. Prius92
    592
    121
    Iowa
    I have the red cover, not the clip that goes into the hole.
