Huge Crack in windshield, $1200 quote!
Discussion in 'Prime Main Forum (2017-2022)' started by robAlatte, Sep 12, 2022.
  1. robAlatte
    robAlatte Member
    60
    40
    Palm Springs, CA
    Does this sound right? Some jerk in a truck went around me and threw rocks up which led to a giant crack in the windshield. Quoted $1200 from a reputable installer which I've used before. He said it's because there's a ton of technology in the windshield. I was hoping it would be under $500 but $1200 is super steep yikes.
    This is a 2021 Prius Prime Limited
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    771
    303
    Maine
    We have replaced our windshield previously, and it was 100% covered by insurance.
    robAlatte likes this.
  3. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    Check with your insurance.
  4. Leadfoot J. McCoalroller
    8,071
    7,552
    Pennsylvania
    2018 Prius c
    Assuming you have comprehensive coverage that should be a $100-150 deductible, tops.
    If you don't have comprehensive, you just found out what it is good for.
    robAlatte, MalachyNG and Mendel Leisk like this.
  5. Salamander_King
    Salamander_King Senior Member
    11,016
    8,947
    New England
    Yep, that sounds about right if using Toyota OEM glass. I think the Limitted trim needs this windshield.
    Part Number: 5610347921
    The MSRP of the glass alone is $ 1,002.73.
    I had the windshield replaced on my 2017 PP Premium without HUD, ICS, and IPA. The cost was about $1000 total for the glass + installation cost + re-calibration cost. But it was covered 100% by my insurance. I hope you have comprehensive coverage. Even if you don't have the comprehensive or have it with the deductible, some states, and some insurance companies have special provisions on the glass replacement which covers the replacement cost without paying a deductible. Worth checking it out before you pay out of your pocket. Also, make sure that the cost of replacement includes the re-calibration procedure needed for the front-facing camera and maybe for the HUD. This alone performed at a dealer can cost a few hundred dollars.
    #5 Salamander_King, Sep 12, 2022
  6. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    rob, check the price at Safelite just for comparison. And call your insurance agent or read the fine print in your insurance policy to know where you stand on that. As mentioned above, special glass is needed if your car has the heads up display, and the cameras behind the black housing by your rear view mirror need recalibration, all expensive operations. There may be suitable aftermarket glass available, but probably not many options.
  7. Rmay635703
    Rmay635703 Senior Member
    2,668
    1,687
    Somewhere in Wisconsin
    2013 Chevy Volt
    And people wonder why I ignore passenger side glass cracks, no sooner do I fix but it’s broken again. Very disappointed that the local glass repair places have gotten so picky on what they will repair with the clear goup
  8. ColoradoBoo
    ColoradoBoo Senior Member
    1,231
    824
    Monument, Colorado USA
    I don't have my estimate, but do think my windshield was over $1,000 last fall when I hit a deer and it got cracked. After installing, they also have to re-calibrate the safety features. Hopefully you're insurance can help!
  9. Sounds about right. Windshield on mine got chipped about a year ago... but I didn't see anything hit it. Anyway, chip became long crack, and long crack led to the whole windshield replaced. My insurance covered nearly all of the $1000+ cost.
  10. Hidyho
    Hidyho Senior Member
    2,699
    531
    2018 Prius
    Going through insurance, Safelite was a little over $500 for a HUD non-Toyota windshield and everything, insurance was $500 deductible, so insurance paid almost nothing. If you have glass insurance or just comprehensive insurance, you simply pay the deductible, which is usually discounted for the insurance company. If you have a lower deductible, even better.
  11. robAlatte
    robAlatte Member
    60
    40
    Palm Springs, CA
    Yeah my deductible is $1000 so Im just going to pay out of pocket. Ugh.
  12. Mendel Leisk
    41,329
    $500 for collision and $300 for comprehensive is a better sweet-spot.
  13. PT Guy
    1,085
    711
    The only bad time to review one's insurance coverage is immediately after a loss--know what you have before you need it. So...I buy comprehensive coverage with a $250 deductible but full safety glass coverage. $87 a year for the Prime Advanced from Safeco. Comprehensive is any loss except a crash. I choose $500 deductible for collision. You can choose anything that meets your needs.
    Keep in mind that there is no industry standard definition for "full coverage." It is whatever the agent puts into your policy, and it might duplicate other insurance you have or it may leave holes in your coverage. Give "full coverage" a careful review regarding your situation. Also, for older cars, consider dropping some coverages--rule of thumb: if you can write a check for the damages you don't need insurance. And drop coverages for cars in long term storage, just insure them for comp. If they aren't on the road they don't need collision or liability coverage or the other coverages.
    Also for older cars that you love, if you have collision coverage and get into a moderate wreck that old car you love will probably be totaled if the cost of repairs is above something like 85% of book value (varies by state). If you buy it back it'll have a branded title of Salvage or whatever your state requires. If you don't have collision insurance and pay for the fix yourself you keep your car with a clean title.
  14. GregersonIT
    GregersonIT Member
    172
    92
    Livermore
    2020 Prius Prime
    If you get a good installer, they can swap the windshield without realignment. This is good for up to two replacements. After that you have to get it realigned.
