What Brand of Battery do you like ? (Auxiliary)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Jul 14, 2022.
  1. douglasjre
    douglasjre Senior Member
    2,085
    698
    Null, NL
    Where do I get this good deal
  2. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    Yes, the dealer -- but look around for discount coupons.
  3. Mendel Leisk
    40,457
    In Canada i can get the stock Yuasa battery MUCH cheaper, from SaskBattery.
  4. NewHybridOwner
    607
    283
    W. Michigan
    But I'm not sure that you would get the free towing (in the event of battery failure) if you don't get the battery from the dealer. And do you have to pay for shipping from SaskBattery?
  5. Mendel Leisk
    40,457
    I'm not sure if they ship outside of Canada, or it may require going through some "hoops". But anyway, my experience: free shipping (within Canada), and: we have two forms of sales taxes, GST (Goods and Services Tax) which (IIRC) is 5%, and BC PST ( British Columbia Provincial Sales Tax), which is 7%. If you're not in Saskatchewan they only charge the GST.
    One further wrinkle, when I checked their website they didn't list the Yuasa, but I emailed them and the response was that they had it, just the website is not always up to date. This was maybe a year back.
    Bottom line: you could email them and see the current situation, and what they could do considering you're in the States.
    For reference, this is the stock battery:
    YUASA S46B24R-GS
  6. johnHRP
    johnHRP Active Member
    550
    161
    tally, fl
    Yuasa still makes the best Battery, especially AGM
  7. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    I did get one of those batteries as you suggested and I need longer bolts and washers right to attach the terminals right? How long should those bolts be?
    In addition the bolt that holds down the bracket on the left side needs to be longer. What is a good length for that?
    Thanks
    #47 Taxi/Limo, Sep 22, 2022
  8. PriusCamper
    PriusCamper Senior Member
    11,977
    4,869
    Pacific Northwest, USA
    @Tideland Prius Photo uploads not working?
    I can't upload photos for some reason?
    M6 1.00 X 25 is the bolt size then add washer on both sides. Also a longer than standard 10mm bolt for the hold down bracket.
  9. Taxi/Limo
    524
    107
    So that is 1 inch long x25?
    Thanks
  10. PriusCamper
    11,977
    4,869
  11. Mendel Leisk
    40,457
    The 1.00 has something to do with thread pitch; my brain is full though. They’re 6mm dia by 25 mm long (tip to underside of head).
    Taxi/Limo likes this.
  12. Taxi/Limo
    524
    107
    I am still unclear if I should put a vent hole in my battery that looks like this https://www.ebay.com/itm/123818240501
    Does this battery have ventilation built in?
  13. douglasjre
    2,085
    698
    Null, NL
    1.0 thread/mm
  14. Taxi/Limo
    524
    107
    The bolts to afix the teminals to the battery worked good Thanks But you were WRONG on the bolt for the hold down bracket 10mm is way to short I had to make a second trip to the hardware store to get a 40 mm. This could be because my mobile battery is taller than you one you installed I should have measured
  15. PriusCamper
    11,977
    4,869
    Apologies, was a busy day... What I meant was a longer than normal bolt that works on a 10mm socket. Alternatively you can use the same bolt that was previously used if you rebend the hold down bracket in a vice so it sits taller. Or the third option is to remove the plate the battery sits on top of so it sits lower. All three ways work, was just in a rush and didn't have the time to write them all out. I'll do better next time!
  16. CR94
    CR94 Senior Member
    2,660
    1,149
    Northwestern S.C.
    Harbor Freight or any of various on-line sources.
  17. Taxi/Limo
    524
    107
    Good suggestions I did not think about removing the mounting plate Thanks
  18. Mendel Leisk
    40,457
    Toyota's style of hold-down bracket has pretty much zero tolerance to battery height variation. When I put in an Optima Yellow Top, supposedly tailor-made for this application, the height was ever so lightly more, needed a shim washer.
    Taxi/Limo, CR94 and douglasjre like this.
  19. Taxi/Limo
    524
    107
    I appreciate this forum
    Alot of good help here and no toxic critical comments
  20. OptimusPriustus
    OptimusPriustus Active Member
    328
    137
    Finland
    This topic suddenly started to interest me because this morning Prius was completely dead. Did not accept charging from engine compartment terminals, had to connect to battery directly.
    it’s 16months old Exide, probably not AGM as far i could see. Car has barely been used during recent weeks. AGM is only way to survive?
