12v suggestion
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Caldude805, Oct 16, 2022.
  1. Caldude805
    Caldude805 Junior Member
    My 2005 Prius voltage is 11.9v when I tested it after it was sitting for several hours. It’s also at least 4 years old. I want to replace it before I’m stranded (mpg also dipped).
    I’m debating between having the dealer do it $270 + labor or getting a DS46B24R from eLearnAid yellow top.
    Is one option better than another? Does the optima need any special conversion to install in 2005 a Prius?
    Part of the motivation getting the battery from the dealer is for the 84 month warranty.
    thanks
    #1 Caldude805, Oct 16, 2022
  2. JC91006
    JC91006 Senior Member
    16,766
    8,563
    If it's only 4 years old, you should just charge it up and use it for another few years. These batteries normally last 6+ years easily
  3. Caldude805
    I bought the car 4 years ago, that’s why I said at least. Just took a peek, it’s 5 years old next month.
  4. Tombukt2
    12,923
    2,322
    It won't leave you stranded I mean unless you're going to go somewhere and stay for days and not start the car move the car go to the store or whatever maybe even then I doubt it'll leave you stranded The minute you slip the key the hybrid battery should be applying about near 14 volts to the 12 volt battery charging it right up a 4-year-old battery should not have any trouble charging right up 11.9 after sitting six seven hours is nothing too shabby You're right at 12 volts a tenth of a volt off that could be in your measuring so I wouldn't say you have any kind of a problem it's when you're plopping down to below 11 volts heading to 10 Wake up in the morning and you're at 9.6 now no good 11.9 pretty stellar to me.
  5. RRxing
    RRxing Senior Member
    2,546
    1,821
    NEPA
    Keep a jump box in the car just in case.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Had 2 brand new yellow tops they seem to last only 3 years then tank and that's after lots of remedial charges. I was going to try the Duracell at batteriesplus they hare not to expensive and have a really good warranty.
    Btw, Always measure the battery voltage at the front jump point under the hood its meaningless to measure it at the battery itself.
  7. Tombukt2
    12,923
    2,322
    My red tops just died . They're both like 9 yes I'm shocked they've held up
  8. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Oh and here's a simple test while measuring at the front jump point and car OFF turn on the headlights in high beams. Whiile lights on and car OFF what does the battery voltage now measure?
  9. bisco
    51,882
    buy the oem and install it yourself, it's pretty straightforward. +labor is never a good option, how much $$$?
    and that is not full coverage for 84 months, it's pro rata after 2 years.
  10. rjparker
    10,117
    6,279
    Batteries can be load tested for free at most auto supplies. Low voltage does not necessarily mean a bad battery. An excessive parasitic load from many sources or the hatch light left on will reduce the overnight voltage but is not the battery's fault.
    On the other hand, any battery over seven or eight years old is suspect. Load testing tells the tale in either case.
  11. Mendel Leisk
    41,381
    You might be able to find the Yuasa other places, besides the dealership. Not saying for sure, nor the dealership is more expensive, but shop around.
  12. Caldude805
    I think I’ll do this. My local dealership wants $270 for the battery and $190 to install . A dealership 40 miles away sells the battery for $182 if you buy online and pick up locally.
  13. fuzzy1
    10,422
    The Prius charging system doesn't just "charge it right up". It is quite slow, and even slower on Gen2 than on Gen3. The car needs many many hours to bring the 12V to anywhere near full charge.
    This is why Prii that are normally driven only short distances very commonly have chronically undercharged 12V batteries.
    edthefox5 likes this.
  14. edthefox5
    10,096
    4,833
    Clearwater, Florida
  15. Mendel Leisk
    41,381
    Our yearly driving has dwindled down to around 3000 km.
    I keep a CTEK 4.3 connected pretty much constantly. If we've used the car one day, I'll leave it till the next day, but if we're not going to driving, and likely not for a few more days, on goes the CTEK, it starts it's charging regimen, then settles down to maintenance mode, and I leave it thus.
    Seems to be working: current battery went in September of 2015, tests like new.
    I appreciate for some, say street parkers in particular, this isn't doable.
  16. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    If you are mechanically challenged take it to a parts store that advertises free replacement. Not a tough job after you have done a few but ugly on the first try. More little bits to be removed that you would believe.
  17. Simbaboy
    Simbaboy Active Member
    134
    112
    Mid-Michigan
    I bought this battery from Amazon 2 years ago for $140 delivered (Prime Member).
    Its absolutely crazy what it costs today.
  18. bisco
    51,882
