Toyota Class action lawsuit next?
Discussion in 'Prius v Main Forum' started by wafwat, Oct 17, 2022.
  1. wafwat
    wafwat Junior Member
    Gulfport, MS
    2016 Prius v wagon
    douglasjre likes this.
    51,843
    agree with the first comment, $2,700. isn't going to cover a new engine.
    with the gen 3 engine, idk that there is any known solution, other than replacing with a gen 4 engine.
    but i guess 2700 is better than nothing, which is what toyota customers are getting.
    wafwat likes this.
  3. Mendel Leisk
    41,326
    I like that impression "the implied merchantability", around 5:45. Another I've heard is "reasonable expectation". With both expressions, the inference is "you don't expect to be buying a pig in a poke"...
    Did a double take when I saw this in our Owner's Manual:
    Toyota should be obligated to show this prominently, in their sales brochures and ads.
    Replacement of rings/pistons (with 2015 style) is pretty good solution (see attached TSB's), except:
    1. It's a little nuts, probably easier/cheaper to put in a new short block.
    2. They'll only do this for the first 60K miles or 60 months, also a little nuts: consumption usually start later, around 100~150K, at which point they can tell you to go-pound-sand...
    #3 Mendel Leisk, Oct 18, 2022
    Air_Boss and wafwat like this.
  4. fuzzy1
    10,409
    When I originally saw that, I just wondered why every car of every brand I ever owned (up to that point), still had essentially the same claimed potential oil consumption rate.
    A different car purchased since, has now raised the bar to 1 quart per 1200 miles. But only after the first several thousand miles, once possible consumption has stabilized.
    #4 fuzzy1, Oct 18, 2022
  5. Air_Boss
    Air_Boss Senior Member
    4,189
    1,177
    New Yawk
    Use 100k and throwaway engines? The battery warranty is longer.
  6. bisco
    51,843
    it's more reliable :p
  7. CR94
    CR94 Senior Member
    2,687
    1,167
    Northwestern S.C.
    Well, 1000km/liter is better than my parents' '64 Buick that could manage only about 300 mpq when new. Dealer said just drive it faster to break it in, and it will get better. It didn't.
  8. Mendel Leisk
    41,326
    Never anything like that in our (unbroken) string of Hondas.
    in my experience they would often develop a modest consumption, never more than a quart over oil change interval. Very gradual onset.
  9. Air_Boss
    4,189
    1,177
    New Yawk
    Never had an oil burner.
  10. bisco
    51,843
    maybe i don't keep my cars long enough. but in my youth, i owned a variety of long in the tooth cars that burned little to no oil, except for a mercedes that i had to keep a case of oil in the trunk, and stop every few miles to add a quart :whistle:
  11. GregC1979
    GregC1979 Active Member
    201
    121
    Nowhere
    There's a solution, part of it is in your signature....the other part, I am not at liberty to tell.
  12. Mendel Leisk
    41,326
    Blizzard Pearl paint peeling Prius, another potential lawsuit?
  13. Led
    Led Junior Member
    37
    Huntington WV
    Toyota has fallen a long way in durability. My good old 2001 Avalon that I sold with 317K on the clock didn't use any noticeable oil between changes.
    The Prius is still basically new to me so how much oil it uses will be interesting to see. I have discovered the timing chain cover is leaking so getting a good measure on how much it's burning will be difficult.
    Later,
    Stephen
  14. bisco
    51,843
    notmuch comes out of the cover, unless your getting puddling overnight
    GregC1979 likes this.
  15. rjparker
    10,082
    6,249
    Toyota offered the solution fairly early with new design pistons and rings, many installed free in the impacted 2010-14 models. It is still a good idea rather than just replacing the symptom, eg the head gasket alone.
    The low tension piston rings are a problem on a variety of models:
    • 2007-2011 Toyota Camry HV (Hybrid)
    • 2007-09 Toyota Camry 2.4L
    • 2009-11 Toyota Corolla XRS
    • 2009-13 Toyota Matrix 2AZ Engine
    • 2006-08 Toyota RAV4
    • 2007-08 Toyota Solara
    • 2007-09 Scion tC
    • 2008-15 Scion xB
    • 2010-14 Prius 1.8L
    • 2005 Avalon V6 (vvti gear)
    • 2007-10 Sienna (vvti gear)
