2014 Prius V parasitic drain on efi2 fuse=4.2
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Mike from Merrick, Oct 29, 2022.
  1. Mike from Merrick
    Mike from Merrick Junior Member
    32
    New York
    So after the battery drained on 2 consecutive nights, I did the fuse test according to the humble mechanic onyou tube.
    The efi2 fuse showed 4.2 draw. Can’t seem to locate the efi relay, and the dealer said the 60a fuseable link is on”back order”
    Anyone else ever have/solve this?
  2. Tombukt2
    12,901
    2,316
    4.2 amp draw just sitting in driveway daum. That'd be like a stereo playing full time a pretty decent one too . No?
    Mike from Merrick and Air_Boss like this.
  3. Air_Boss
    Air_Boss Senior Member
    4,189
    1,177
    New Yawk
    50 watts?
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    4.2 what ? Amps.....milliamps......big difference.
    And what does the 60 amp main fuse have to do with this ???
  5. Mike from Merrick
    32
    New York
    To answer your response, I believe I may have had the setting on dcv, 20, so now Ill go back and check for ma., and I read on one of the posts that changing out the relay which could be stuck was an option.
    I suck at electrical stuff, so its a continuing learning experience for me.
  6. Mike from Merrick
    32
    New York
    no, believe I ran it across the fuse on dcv 20 and it read 4.2. Going to redo the test later
  7. Air_Boss
    4,189
    1,177
    New Yawk
    50 watts or 50 miliwatts?
  8. Mike from Merrick
    32
    New York
    Agree. This car was a taxi, had all of the hack up wiring still in it for the meter and other electronic stuff for the taxi etc. I was able to remove all of the taxi wiring, testing and checking each circuit. Changed out the EFI2 fuse, and after a day and a half, it didn't lose hardly any voltage. It must have had a circuit attached to the audio though. I now have no radio, lol
  9. Tombukt2
    12,901
    2,316
    The EFI fuse at rest showed 4.2 draw of what amps? milliamps? 4.2 volts?
  10. rjparker
    10,082
    6,249
    I think he was doing a mv test across fuses as a way to determine which circuit was responsible for excessive parasitic draw. Then he was shotgunning the circuits. May have got lucky by just cleaning up the old taxi wiring.
    Mike from Merrick likes this.
  11. Mike from Merrick
    32
    New York
    rjparker, you are right, exactly what he did! Now to figure out the audio tuner on that center screen!
