Just Fixed Water Pump, What's Next?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by messyj232, Nov 3, 2022.
  1. messyj232
    messyj232 Junior Member
    Hey everyone! My Prius has 180,000 miles on it, and I just replaced the Drive Motor Inverter Cooler Water Pump. I was wondering what MIGHT (?) go next? (Trying to decide if I should get a new vehicle or not...)
    Thank you!
  2. Tombukt2
    11,741
    2,078
    What year do you have
  3. ASRDogman
    ASRDogman Senior Member
    7,049
    3,692
    Did you remove the inverter to replace it? Or were you able to reach it be removing the
    head lamp assembly?
  4. bisco
    50,874
    head gasket
    m.wynn and Mendel Leisk like this.
  5. CR94
    CR94 Senior Member
    2,660
    1,149
    Northwestern S.C.
    That's a significant possibility, especially if the manifold EGR passages haven't been cleared out.
    However, nobody knows what will go next.
  6. ASRDogman
    7,049
    3,692
    It is called "preventive" maintainence for a reason.
    You replace parts and fluids BEFORE they break or break down, which could cause more damage.
    Foxglove likes this.
  7. Mendel Leisk
    40,307
    Yeah assuming no EGR cleaning, I’d second @bisco.
    If you want to be proactive: replace engine coolant pump (aka water pump) and thermostat? There’s been lots of reports, failures around your miles.
    m.wynn likes this.
  8. messyj232
  9. messyj232
    (... from my mechanic...)
    Drive Motor Inverter Cooler Water Pump Assembly 1 Unit
    Drive Motor Inverter Cooler Water Pump Bracket (Upper) 1
    Drive Motor Inverter Cooler Water Pump Bolt 2 Unit
    Drive Motor Inverter Cooler Water Pump Bolt 3 Unit
    Drive Motor Inverter Radiator Hose 1 Unit
    Drive Motor Inverter Radiator Hose Clamp 1 Unit
    Hybrid Coolant 0/50 Pre-Mix (PINK) 1 Gallon 1 Unit
