prius camping and inverter questions
Discussion in 'Living Life in a Prius' started by taxce, Sep 4, 2021.
  1. douglasjre
    douglasjre Senior Member
    2,161
    713
    Null, NL
    I got renters that are intimidated by stuff. Overcome your fears or forever be a follower. Get whatever inverter you wish. I just got a 4kW pure for hardstarts on compressors. Never gonna get that much from 12v but who cares. Get what you like. More is better than less.
  2. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    405
    2013 Prius Plug-in
    well, id rather have them think the worst wrong-case scenario, and that be in the front area in their brain then think "oh its just for one over-nighter trip" and something happens. I do appreciate your concern with the method in which I choose to have my voice heard. It got your attention, didn't it!
  3. black_jmyntrn
    1,728
    405
    2013 Prius Plug-in
    i see, i must have thought I was quoting randy with his "recommended" stats.
  4. ChapmanF
    17,998
    Then it's easy to tell them that. "Don't use the inadequate wires that come with your inverter to power large loads, even for one over-nighter trip, or something might happen. Follow the instructions and use wires properly sized for your load."
    Why muddle that simple message on purpose with stuff about whether the car is a Prius or not, when the issue you want them to understand is completely independent of the kind of car? Unnecessarily confusing people doesn't make them safer.
  5. black_jmyntrn
    1,728
    405
    2013 Prius Plug-in
    heh... they are a different crowd than the fine folks here at priuschat... not that simple...
  6. ChapmanF
    17,998
    What kind of crowd are you suggesting understands something better when you lie to them about it?
  7. black_jmyntrn
    1,728
    405
    2013 Prius Plug-in
    well, never a lie, lamens terms? and the dig into the depth of this I'm not gonna do. thanks
  8. Simbaboy
    Simbaboy Active Member
    134
    112
    Mid-Michigan
    Old thread, I know.
    I used a 1000W sine wave inverter, 100 amp fuse, 5 ft of 4 gauge wire.
    No issues. Set up for camping but rarely used for that. However, I did use several times when we lost home power.
  9. Polie
    Polie New Member
    Ocala, Fl
    2022 Prius
    Has anyone figured out a way to tap into the main prius battery for an inverter?
  10. ChapmanF
    17,998
  11. Polie
    Polie New Member
    Ocala, Fl
    2022 Prius
