2011 Prius noise taking off
Discussion in 'Gen 3 Prius Technical Discussion' started by Raphael Muscarelle, Nov 10, 2022.
  1. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
  2. Raphael Muscarelle
    661
    222
    Guys at the yard said the differential starts doing what I'm describing about the same time of my mileage about 400,000 mi I have 393ish miles
  3. Raphael Muscarelle
    661
    222
    I think I'll use my wires no telling how long these have been exposed to Florida. IMG20221114144356.jpeg
  4. Raphael Muscarelle
    661
    222
    Lol put drive shafts in to test it. Haha can't get it out easily. In it will stay IMG20221114144604.jpeg
  5. Mendel Leisk
    40,459
    Are those brand-new drive shafts?
  6. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    Thank you for the update. Let us know if the new to you transmission fixes it.
  7. Raphael Muscarelle
    661
    222
    Yup they are. The driver's side is shaped differently so I had to put it in to make sure it wasn't going to hit the housing. It's close but no it doesn't
  8. Raphael Muscarelle
    661
    222
    I think it is a magical noise if it doesn't since I replaced everything else.
    The guys at the junk yard said these transmissions start making this noise at higher mileage. Mine is like 395K ish miles
    They also said Toyota transmissions develop noise in the differential.
  9. ASRDogman
    ASRDogman Senior Member
    7,114
    3,713
    The junk yard guys don't know anything about toyota transmissions.
  10. Raphael Muscarelle
    661
    222
    I think they talk to people and people just might tell them why they are buying the transmission.
  11. Raphael Muscarelle
    661
    222
  12. Raphael Muscarelle
    661
    222
    Yes I put in new drive shafts cus I was betting on the noise being the drive shafts before it was the transmission.
  13. Raphael Muscarelle
    661
    222
    I'm fairly sure there is a lot less slop in this transmissions differential.
  14. Raphael Muscarelle
    661
    222
    Success the 2014 works in a 2011 no codes or nothing. Small problem though The new drive shaft I bought was not beveled on the end of the inner CV joint and I think it's hit in the transmission so I'm getting a clack clack clack noise like that other guy has
  15. Raphael Muscarelle
    661
    222
  16. Raphael Muscarelle
    661
    222
    It's all good now.
    Oops I'm unqualified to put on tires. New noise was lugnuts weren't tight enough. Ok I'm a bonehead
    WilDavis and ASRDogman like this.
  17. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    Glad you were able to discover the reason BEFORE it was to late. I well remember glancing down at the front-wheel (driver's side) one morning after fetching car from having the snow-shoes fitted, and noticed one of the lug-nuts was loose and had become unscrewed so it was on the last couple of threads! :eek: Solution: (1) re-torque ALL the lug-nuts (2) change tyre-shop, I've gotten into the habit of re-torquing lug-nuts ~100 miles after anyone has buggered around with the wheels/tyres. Timely reminder: Yesterday I had stealership swap ChgyPyg's summers for winter wheels, so in the next few days, I'll be doing just that! :)
    Brian1954 and Raphael Muscarelle like this.
  18. Raphael Muscarelle
    661
    222
    Tire shops around here think it's ok to put full torque from the impact gun on the lugnuts. Holly crap even with a 3ft breaker bar you can't get them off. Only need like 80fp and they are putting like who knows how many hundreds.
  19. ASRDogman
    7,114
    3,713
    Toyota calls for 76ftp.
    And once they are torque'd, you "can" check them, but it won't change.
    WilDavis likes this.
  20. Raphael Muscarelle
    661
    222
    Only thing I have used a torque wrench on is head bolts.
    CR94 likes this.
