More about that stupid UFO speaker
Discussion in 'Gen 4 Prius Main Forum' started by Chris Wolfgram, Nov 18, 2022.
  1. Chris Wolfgram
    Chris Wolfgram Active Member
    412
    167
    Sacramento CA
    2019 Prius
    So yea, my mechanic friend dug straight to it, and had it out in less than 10 minutes. We put a piece of foam over the front and shoved some under that little bracket piece on the back, then gorilla taped it, and threw it back in....
    I was very confident that it was going to quiet it way down, but to my disappointment, it hardly did anything ☹️
    Here soon I'll be taking the car in for it's 5000 mile service. And I'll see if I can get them to dial it back. Someone here said it has a 1, 2, or 3 loudness settings, and they usually come set to 3 from the factory.
    If they either won't drop it down to the lowest setting, OR they do and it's still to loud, I'm going to remove that stupid thing and put in a 3 ohm resistor to stop the pop up message from bugging me.
    Not trying to make it dead silent, but that ugly mechanical scraping sound is just hideous.
  2. Tande
    Tande Active Member
    521
    308
    Mich.
    Well .....that's interesting (assuming you are talking about the pedestrian warning) ......I have a 2017 & have NEVER heard mine......is there some particular situation needed to trigger it? .......:confused:
    Mambo Dave likes this.
  3. CooCooCaChoo
    CooCooCaChoo Senior Member
    952
    533
    Cow-lee-fornia
    2023 Prius
    They were only put in later years. My 2017 doesn't have it either.
    Tande likes this.
  4. Chris Wolfgram
    412
    167
    Sacramento CA
    2019 Prius
    Well, I could hear it in my 2019, but it's much louder in my 22 ☹️ And it's a really awful sound too. It sounds like some kind of metal part scraping or grinding. Kind of embarrassing really. I'm sure people think .. "Look at that brand new Prius already malfunctioning...."
    Well no. But it sure sounds like it.
    Oh, what do you have to do to trigger it ? Put it in reverse... Or drive, up to 15mph, as long as the gas motor isn't running.
    I think reverse is the loudest though...
  5. bisco
    51,066
    all toyota hybrids have had them since 2012. but until the law kicked in more recently, they were adjustable.
    now, they are set to the required decibels
    ShenmueTacos likes this.
  6. Chris Wolfgram
    412
    167
    Sacramento CA
    2019 Prius
    And that's what concerns me. I'm hoping I can get Toyota to dial it back a little, but I can see them giving me some crap about liability... Yada, yada..
    At which I'll just have to take matters in my own hands.
    But I really don't want to completely remove it..
    Only to quiet it down by about 80%....
  7. bisco
    51,066
    i wonder if wrapping it in dynamat would do anything
  8. Chris Wolfgram
    412
    167
    Sacramento CA
    2019 Prius
    I wish I had had some extra sound deadener. We just used closed cell foam and tightly wrapped it with Gorilla tape. I really expected it to make a bigger difference
    Oh yeah, and sound deadener already has super sticky adhesive, so no tape required....
    might bring a sheet of it next time I go to see my mechanic.
  9. Mambo Dave
    Mambo Dave Active Member
    641
    306
    2019 Prius
    L Eco
    I can't hear my 2019's speaker. I got lucky, or I didn't get lucky and instead became deaf over my lifetime (which I have).
  10. Leadfoot J. McCoalroller
    7,841
    7,307
    Pennsylvania
    2018 Prius c
    ...at least a few hearing tests needed in this thread.
    And the right way to quiet a speaker/beeper/dinger without removing it is to fill it with glue. Sometimes that means drilling a hole for access, sometimes it means getting a fresh box of hot glue sticks. But it works.
  11. ColoradoBoo
    ColoradoBoo Senior Member
    1,132
    741
    Monument, Colorado USA
    I had to redo mine a second time, too. What I ended up doing was buying a roll of gray pipe insulation that had one side pre-glued and wrapped it around ALL sides of the little speaker. At first, I used too much and couldn't get it back in but took off a layer and squeezed it in, got it re-bolted and plugged in, and now you can barely hear anything. (My wife's 2017 doesn't have it...it some sort of government requirement on hybrids/EV's but I've noticed the noise from Tesla's are WAY quieter...the loudest I've heard is from RAV4 Hybrids....ridiculously loud.)
  12. Mendel Leisk
    40,516
    Talk about regulators, manufacturers, and customers, all working at cross-purposes. Reminds me of the present state of gas cans.
  13. ColoradoBoo
    1,132
    741
    Yes, have you seen those insane "safer" nozzles on the new gas cans? Good grief, you need 5 hands to get the stupid thing to work...
