Wait - Tesla braking isn't regenerative?
Discussion in 'Tesla' started by Lee Jay, Nov 24, 2022.
  1. Tideland Prius
    16,548
    No, it's wheel-mounted so it'll turn with the wheel.
    You shouldn't be shifting while turning lol. (there's also an aftermarket shifter extender to extend it upwards like a Ferrari if that makes it easier to find. Again, I don't shift often - usually in a straight line or at a stand still. Better than looking for it in a menu on the screen).
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,231
    824
    Monument, Colorado USA
    I was just checking out an older Tesla yesterday at our family Thanksgiving. The guy lives in Denver and it's great, he says, for zooming around the city and work but anytime he leaves the city he drives his Jeep...the range of his Tesla, since it's an older model, is only 150 miles.
    Maybe the reason Tesla doesn't have the high-tech regen brakes like our Prius is because much of the technology is patented by Toyota and they didn't want to pay the cost for using it.
  3. hill
    8,794
    One of the display screens on our plug-in minivan shows energy going in or out. since I prefer the highest regenerative feature, like many, I just let off the accelerator to the point where it's tantamount to being in neutral. it wasn't a hard skill to learn as that's what we hypermilers figured out nearly 2 decades ago. Even the early Prius screen aided people in learning where that neutral sweet spot was, showing power in or out or that sweet spot right in between .... just like our plugin minivan modernly. Still - many older people find it difficult to try new things. getting used to finding a neutral sweet spot on regenerative accelerators falls into that category ..... things that are uncomfortable to learn for older people. For those of us that fall in the OCD range though - one pedal driving is not only pretty easy - it's one of those many things that is obsessive.
    Zythryn likes this.
  4. mikefocke
    3,988
    1,801
    Sanford, NC
    Or re that light switch, how many on/off cycles leads to replacement. For the bulb, ditto. Even LEDs fail.
    I'm particularly conscious of this because I have had about a dozen 3-way switches fail over a 16 year period. Many brands. Now using $$$ industrial switches.
  5. Trollbait
    12,505
    These shifter paddles are mounted to the wheel since they appeared on formula race cars. This way they are always in the same position in relation to the driver's hands on the wheel. A turn tight enough to require hand over hand isn't one to be shifting in the middle of.
    Tesla does have high tech regen braking. They just chose to have it all controlled by the accelerator, like a locomotive. Blending regen and friction on the brake peddle like Toyota and others do leads to a 'quirky' experience compared to friction only brakes people are use to. Tesla avoided that as a potential costumer complaint.
    Tesla could implement blended braking on the brake pedal; everything is in place on the cars to do so. But why should they. There is a waiting list to buy the cars with one pedal driving or using friction brakes as the only options for increasing prices.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    What ???
    Do you really want to keep the accelerator pushed down a bit WHILE you are applying the brakes ??
    One pedal is for "driving" and the other is for "stopping".
    One at a time. Simple.
    Note: With a fully electric drive, I doubt that you would WANT to engage "full regeneration" because that would likely feel like slamming on the brakes.
  7. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Why would I want that?
    And what's for coasting?
    And inefficient, and not remotely the way I drive.
    Hence why I want it on the brake pedal.
  8. bwilson4web
    16,193
    • cruise control
    • shifter lever into "N" and back to "D" as needed
    Trollbait likes this.
  9. dbstoo
    dbstoo Senior Member
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    I can't find much to agree with in this post. After driving 50 years in dozens of car models, I can assure you that the Toyota regen on a hybrid is no more quirky than any other car produced in the the last 5 decades. You should have tried the power brakes in the 1978 Ford LTD. Big, heavy car. Power brakes that went from doing nothing to locking up with just a few pounds of foot pressure. Then there was the 1992 F150 Pickup that always felt like the brakes were fading at the end of a long commute.
    If Tesla had high tech braking, there would not be a need to "rent a car" (as suggested a few posts back) to learn how to drive the Tesla. If they wanted to emulate the speed/braking controls of a freight train it should have the accelerator mounted on a hand operated lever with stops that represent predetermined speeds.
    The silliest sentence in the post is this:
    PriusMechanic and Lee Jay like this.
  10. bwilson4web
    16,193
    One of my Marine drill instructors said,"One grain of observation outweighs 10 pounds of bovine fecal matter any day."
    That is why I ran a recent benchmark:
    Benchmarking Tesla Regenerative Braking | PriusChat
    The funny thing is the Tesla will regenerate to a dead stop descending a hill. None of our earlier Prius, 2003, 2010, and 2017 Prime, ever did this. The best we could do is use "B" to not accelerate so fast as to fly off the curve at the bottom of the hill yet we still had to apply the brake. The Tesla regeneration does not require application of the brake that heats the pads and wastes energy.
    NOTE: I find pulse and glide impractical in traffic. Predictable driving reduces horn honks and one finder salutes. Some well armed drivers in the South have been known to move from road-rage into a firefight.
    #30 bwilson4web, Nov 26, 2022
  11. Lee Jay
    5,850
    4,036
    I use N once in a while, but I find coast so often that, if that were the only approach, I'd wear out that handle. Cruise control doesn't do it.
    The other day I was bored so I counted. I chose to coast 16 times on a three mile trip.
  12. sam spade 2
    7,035
    2,801
    2017 Prius c
    I think you are being purposely dense here.
    You just PARTIALLY release the accelerator.......exactly like you would do with any other vehicle.
    Have you actually driven a Tesla ??
    Sure doesn't sound like it.
  13. hill
    8,794
    I already mentioned that above. also that doing so is how many of us have mastered the pulse & glide technique. but if the Tesla sweet spot for neutral ½way off the accelerator is too hard - then pulse & glide would be too difficult for someone also.
  14. Lee Jay
    5,850
    4,036
    I've ridden in a Model 3 and driven two other cars with optional single-pedal driving (Ioniq 5 and Bolt), in single-pedal driving mode. To say I hated it would be an understatement.
    PriusMechanic likes this.
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,148
    Tampa, FL
    What I like most about the HSI on the Gen 4 & Prime is that it gives you a graphical indication of how much you are pulling from or putting into the battery as you modulate the go pedal. The Bolt EUV I just got goes one better and showed it graphically and numerically. So, while I almost never see 0 kW going in or out, I often manage 0.5 or 1 kW and I'm fine with that. If I want to hyper mile, that is close enough for me.
    What I like better about the Bolt than the Tesla (well, one of many things) is that I can use one pedal or normal. If one pedal is not on, the brakes work like a Prius. My wife likes this. She's not a geek. I prefer the one pedal. I am a geek.
    hill likes this.
  16. hill
    8,794
    it's okay to be in a minority. A handful of folks hated those new fangled cars over their buggies too. Heck - Edison even hated AC. we all have our reasons.
  17. ChapmanF
    18,076
    Prius also begins regen as the go pedal pressure is released, and requires finding a partial go pedal sweet spot for gliding.
  18. Lee Jay
    5,850
    4,036
    I know, and I hate that too, but at least it's a small amount. With one-pedal driving, releasing the accelerator pedal is like slamming on the brakes.
    Releasing the accelerator pedal in one-pedal driving is like stopping pedaling on your bike and having the brakes come on automatically. Having to find coast someone in the accelerator pedal range is like having to stay pedaling on your bike to coast. It's stupid and counter-intuitive.
    I want my car to work like my bike - when I stop accelerating (pedaling/pressing the accelerator pedal), I coast.
  19. Trollbait
    12,505
    If you are doing a true, no regen coast in a Prius, then one pedal driving should not be an issue.
    Then let us know when you find a liftback EV that meets all your needs.
    There were plenty of questions and complaints about the brakes during the gen2's days here. My owner's manual had a section covering the new noises made by the braking system. That they were normal for drivers that had never experienced them. I'm sure plenty still went to the dealer about those noises coming from by the driver's foot.
    Smooth transition between regen friction took a couple generations to achieve.
    Locomotive engineers don't have to make turns.
    I thought I should have cleaned that up.
    Cost has nothing to do with why Tesla doesn't offer typical blended braking. The price I refer to is the price they charge for their cars. Not the cost of the braking system. If not having the blended braking some want was having a major impact on sales, Tesla could likely just apply it with a software update. Since they sell every car they make, while increasing prices, it must not be a big issue for customers.
  20. dbstoo
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    That's still a pretty weak argument, but one that is often made in excusing Tesla flaws. If the argument was valid, then YOU could claim (with just as much validity) that the not yet released cybertruck does not need to be improved, or even produced! After all, they have reservations for 1,000,000 (yes, a million) of the non-existent vehicles and they keep pushing the production date out. That's your justification, right? No need to change things if people are still buying the smoke and mirrors.
    https://electrek.co/2022/11/22/tesla-cybertruck-million-pre-orders-live-up-to-hype/ On the other hand, the rumors that Musk started just before the unveiling of the cybertruck did give Tesla a nice 25% boost (approximately) in stock price, so maybe the truck has already done it's job?
    In the mean time, I see that there are now two Rivian pickups driving through my neighborhood. I have not seen a F150 lightning yet. :) If Tesla is not quicker to market, it's competitors are going to eat it's lunch.
