Rats--ways to block
Discussion in 'Prius v Main Forum' started by David knopf, Nov 24, 2022.
Tags:
  1. David knopf
    David knopf New Member
    san Rafael, california
    Does anybody have experience installing wire mesh to block out rats in 2012 Prius V wagon?
    Dealer has charged insurance $5000 + to replace blower box and assorted chewed on wires on two occassions. Are there clear enough areas underneath that could be blocked to prevent nesting? Have tried various non toxic products touted ro repel rates, but they still seem to be in engine area. Don't have garage and live near ooen space and brush.
  2. Mendel Leisk
    41,328
    Cabin air intake, below windshield, is the main entry point. They might get in through the hybrid battery vents, at rear corners below hatch floor. Worthile meshing the engine air intake snorkel too.
    I’ve done the cabin air intake and snorkel, using 1/4” mesh galvanized steel rodent shield. I should get on those hybrid battery vents too.
    for the cabin air intake you need to remove the wipers, wiper motor with its linkage, and probably the metal cowl beneath.
    #2 Mendel Leisk, Nov 25, 2022
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,231
    824
    Monument, Colorado USA
    Oh that's really a shame! We've had mice issues where we park out RV and, years ago, was told to put cut-up bars of Irish Springs soap (the original ones) all around inside the camper. Since we started doing that, haven't any mice issues. Apparently, they hate the smell so much they quickly leave if they do come in. Not sure if also repeals rats, though...I've have rat traps all around the car or get a good outdoor cat to catch them.
    Air_Boss likes this.
  4. CR94
    CR94 Senior Member
    2,689
    1,169
    Northwestern S.C.
    I've heard peppermint oil also repels them.
    Screening the rear air exits may require removing the bumper cover.
  5. Albert Barbuto
    106
    98
    Northeast USA
  6. Mendel Leisk
    41,328
    Yeah I've looked at it from the inside, seemed awkward. Can't remember exactly why; might have another look. There's gotta be a way.
  7. Salamander_King
    Salamander_King Senior Member
    11,016
    8,947
    New England
    I don't know how easy it is on V, but on Gen4 and my PP, the rear air vent was easily accessible by just removing the decking. Still requires some disassembly of the plastic, bolt, and pins. Again, my experience is only for the PP, but it also applies to Gen4 and earlier Prius. For the front engine compartment, there is just no way to completely prevent rodents from entering. You can block off the HVAC air intake to prevent mice from entering the cabin and nesting on top of the cabin filter. But that requires removing the wiper motor and cowl. Instead, I just covered the cabin filter case with hardwire cloth. This prevents the mice to chew on the cabin filter material and gaining further entry into the HVAC blower and cabin spaces.
    See on this thread what I did on my last PP which is now sold. Repellents are basically useless. Traps are effective in reducing the risk, but again it is not a permanent solution. They will come back and adapt to it. Yeah, the mouse problem was the last thing I wanted to keep dealing with on my PP. That was one of the reasons I got rid of the car. I hope my new car Escape PHEV is less attractive to them.
    Mouse nesting locations in the Prius Prime
