Chilled out Traction Battery??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tommy West, Nov 29, 2022.
  1. Tommy West
    Tommy West Junior Member
    51
    In a Prius
    As me and #ladythepitbull travel the USA in our 2010 Prius we often wonder if we're crazy for running the AC on the traction battery 100% of the time we are driving the car. Even now in winter I have the AC vents taped up and run the AC just for the traction battery. In summer I also hook a large ice chest that rides in the passenger seat to the AC vent in front of it to transform it into a refrigerator but in winter that's taped up as well so just the traction battery gets the AC.
    My question is does the AC actually blow directly into the battery? Doesn't heat causea lot of the degradation of the battery cells? Shouldn't keeping the traction battery as cool as possible extend it's life?
    I'm sure it does cool the battery because when I first bought the car it would throw a hot battery code immediately every time I didn't run the AC but NEVER when I did. Thanks so much you guys for reading my post. Have a super great day. Lady says, "Woof thanks Woof"
  2. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    did you ever clean the battery fan?
  3. Grit
    Grit Senior Member
    6,422
    4,182
    Wilkes Land
    Asrdogman always say the ac blows over the battery and cools it down, but the backseats are right in front of the battery. I have a mod that was inspired by...asrdogman which takes the cold air from the ac cents directly to the hv fan air intake. Duration of 20 mins for the battery to go from 110F to 90F.
  4. Tommy West
    51
    In a Prius
    Oh. When I take everything out of the back where I can see the hv battery I thought I saw an outlet that I assumed was where the AC came out of to cool the traction battery.
  5. Tommy West
    51
    In a Prius
    Hi. Yes I've cleaned the fan. I have 260,000 miles on this battery. I'm assuming it's normal for it to be getting too warm by now and I'm hoping the AC actually cools the hv battery like I've been thinking it had been
  6. Leadfoot J. McCoalroller
    7,841
    7,307
    Pennsylvania
    2018 Prius c
    The battery just pulls air in from the rear cabin. No direct link to the air conditioner.
    I don't know that it is worth the extra work to air condition the thing all the time. It wouldn't have been that hard for Toyota to do it- if they felt it was important it I think they would have just put in the plumbing.
    Keeping the pack cool is a good thing in general, but I think you'll find diminishing returns for the use of air conditioning past a certain point.
    StarCaller and Mendel Leisk like this.
  7. ASRDogman
    ASRDogman Senior Member
    7,172
    3,756
    Maybe a sensor is faulty? You said you cleaned the fan, did you pull the cover off the
    hybrid battery and check for dust or fur? When I had mine off to install the Prolong harness
    there were only a few pieces of fur and light dust. Even the ducts just had a fine layer
    of dust. Easily cleaned.
    I'm guess you bought it used. Did they previous owner have a dog or two?
    I bought the screen for the intake, and I bought some a/c foam. Both catch a lot of fur and
    dust. Both only take a moment to wash off.
    [QUOTE="Tommy West, post: 3304615, member: 194493"
    I'm sure it does cool the battery because when I first bought the car it would throw a hot battery code immediately every time I didn't run the AC but NEVER when I did. Thanks so much you guys for reading my post. Have a super great day. Lady says, "Woof thanks Woof"[/QUOTE]
  8. Mendel Leisk
    40,516
    I think it's normal for the battery to be a bit warm. I rarely run the AC, and just for it's design purpose: cooling the cabin.
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    Crazy ? YES mostly.
    As has been said, there is NO AC duct for the battery itself.
    So what you are doing is not much different than leaving the AC OFF.
    Even though mine says "ON", it really isn't most of the time because of the automatic temperature setting.
    Blocking the vents could cause the evaporator to ice up and might cause some damage to it.
    Grit likes this.
  10. Leadfoot J. McCoalroller
    7,841
    7,307
    Pennsylvania
    2018 Prius c
    I've always understood Toyota's logic to be that if the driver and passengers were "comfortable," then the battery fan would be capable of keeping the battery within the band of temperatures Toyota themselves would want, knowing they were on the hook for warranty replacements for many years.
    So in Southern California I'd expect air conditioning 300 days of the year, and in British Columbia I might expect it for 30.
    The real point is, keep the battery fan clean, set the controls to make yourself comfortable and chances are the battery will last as long as it ever would.
    Good luck!
    CR94 likes this.
  11. Mendel Leisk
    40,516
    I'm not sure even that is necessary.
    We've been getting pretty toasty up here in summer. Summer before last was worse, broke some records, temps in the low 40C's. This summer there was protracted drought.
  12. bisco
    51,066
    Someone here refitted the battery duct system to cool the inner modules, which made sense to me
  13. Tommy West
    51
    In a Prius
    So the AC compressor is NOT turning off I have the AC low on and it's 32 degrees outside?
    Thanks a lot and I appreciate it. I'm shocked that I haven't been actually cooling my traction battery with the AC. I read somewhere Toyota specifically saying "when you use the AC we use some of that to cool your traction battery". What a lie if they don't actually have a vent that reaches it. I notice that many people in winter are "comfortable" in the car at 85 degrees LoL. Obviously what I saw was part of the ducts for the cooling fan.
    Yes. Now that I know the horrible truth I might be doing that also. Every video I see from battery techs they say it's heat, heat, heat that destroys the battery and that's why you get the U shaped curve of degradation. It seems to me that a dedicated AC just for the traction battery would add many years to your battery but Toyota doesn't care because why would they need to make a battery last 500,000 plus miles. It would be counter productive for them.
    #13 Tommy West, Dec 1, 2022
  14. AzusaPrius
    AzusaPrius Senior Member
    2,137
    900
    The vent on the rear passenger side
    Is where the HV battery fan pulls in air that is set by you when you use the a/c system.
    So whatever the temp is in the cabin is what the HV battery will be sucking in to cool.
    So toyota is not lying actually...
    Mendel Leisk and CR94 like this.
  15. Mendel Leisk
    40,516
    * Thanks for that @AzusaPrius; I wouldn’t know where to begin.
  16. ASRDogman
    7,172
    3,756
    If the battery is at say 120 degrees, and you blow 90 degree air over it,
    it is cooling the battery. Even in the winter, the cabin air will likely never
    be over 80 degrees.
  17. sam spade 2
    7,035
    2,798
    2017 Prius c
    So I assume that you do not have any automatic features with your climate control except for a temperature setting.
    The AC compressor will run to lower the cabin humidity too .......sometimes when it doesn't need to for temperature lowering.
    Then.....if you are pulling 32 degree air though the vents, how do you KNOW that the AC compressor really is compressing and not just "free wheeling" ??
    This is NOT a good thing to obsess over.
    Most things aren't.
    Grit likes this.
  18. mr_guy_mann
    mr_guy_mann Senior Member
    3,950
    1,903
    NJ-USA
    If the HVAC system was pulling in 32°F air, then the ambient temperature and evaporator temperature sensors would report that to the ecu.
    The ecu is programmed not to engage the compressor when the temperature is too low - 'because ya don't need it!
  19. Tommy West
    51
    In a Prius
    Ok that's good to know. I thought it just kept doing it's thing. That makes sense so it doesn't freeze up.
    Oh it monitors the cabin humidity? I didn't know that. I have lived in the car with a pitbull for a year and a halfish so reducing humidity can't hurt lol. As soon as I put in a lithium upgrade traction battery I'll pull my stock one and rebuild it and I'm curious to see it there will be extra corrosion from doggy farts.
    Yes that's true. I don't see why they don't actually have an AC vent for the battery though. You may not need it but on an older battery I don't see how it wouldn't help. If 80 degrees air cold the battery all hunky dory then cold air should work better right?
    #19 Tommy West, Dec 1, 2022
  20. ASRDogman
    7,172
    3,756
    It doesn't need an ac vent. The instake takes in the air from the cabin.
    Whether it's cool or warm. Either way, it's cooler than the battery. If it starts
    getting too warm, the fan will turn faster bringing in more "cooler" air to blow over
    the battery to blow out the hotter air.
    How hot can you get the cab before you have to open a window? Still not hotter than the battery.
    I have two dogs. And have had several other dogs in the back of the Prius.
    You'll probably want to use this cover and filter to keep the fur out.
    Easily cleaned in the sink with just water.
    Mr. F and Bill Norton like this.
