Cleaning the batt cooling fan
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Nov 30, 2022.
  1. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    I was watching Nutz and Bolts video on cleaning the fan that cools the main battery
    I think I have all the tools needed except the plastic pry tool
    Do I really need that ?
    Thanks
  2. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    No.
  3. Taxi/Limo
    524
    107
    What do you use?
  4. nicoj36
    nicoj36 Active Member
    518
    162
    Flat head screw driver
    Taxi/Limo likes this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,136
    Tampa, FL
    I guess I'd have to go look at the video. Are you using it for removing the cable clamps? I use a clip removal tool.
  6. Mendel Leisk
    40,459
    One thing regarding the video: you don’t need to remove rear seat. There’s a single bolt needing removal, just below the air inlet grill, requires 12 mm socket IIRC. You can just push apart seat back and base upholstery and reach it with extension. Hold with your finger tips to avoid dropping.
    also, forget how the video goes, but you can clean fan without removal.
  7. nicoj36
    518
    162
    Yup. Here’s a video that doesn’t require rear-seat removal
  8. Mendel Leisk
    40,459
    First time, I found the fasteners attaching hatch deck to top of battery very stubborn. Left most of them off.
  9. jerrymildred
    11,517
    14,136
    Tampa, FL
    Correct on the seat removal. I never remove the seat to get out the fan. We clean the fans on every hybrid that we sell.
    They sure like to stay attached to the top of the battery case. LOL! That's another use for the tool I mentioned above.
