Gas Engine Shakes at Startup
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by 12VTAO, Oct 29, 2022.
  1. Led
    Led Junior Member
    37
    Huntington WV
    Another question I have based on the heat cycling theory, are cars that are predominantly open road driven and/or cars from colder climates as susceptible to HG issues. In both these cases there would be less thermal cycling. Open road cars because the engine is always on above 45mph. In colder climates the ecu won’t let the coolant fall below 121F if the heater is on.
  2. Air_Boss
    Air_Boss Senior Member
    4,189
    1,177
    New Yawk
    Except in startup from ambient, I've never seen the coolant remain or cycle below below 170 F.
  3. Led
    Led Junior Member
    37
    Huntington WV
    I was watching my V with my Bluetooth scanner while waiting in line to get the kids the other day. It was chilly outside so the heat was on. As soon as the scanner reported 121F the engine would start, raise the temp by 10 deg give or take then shutdown. I wasn’t calling for maximum heat and the cab was at a comfortable temp so the heater was just maintaining. I wonder if the low limit coolant temp rises if maximum heat is called for.
  4. Air_Boss
    4,189
    1,177
    New Yawk
    To be clear, I was driving, not parked.
  5. ChapmanF
    18,072
  6. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I'm worried they'll warp your HG. I know it's a coincidence but people usually change their spark plugs around 120k mi, and roughly 30k mi later is the dreaded HG....
    A hotter plug is not a hotter burner on the stove, it doesn't distribute it's heat nice and evenly....
    GregC1979 likes this.
  7. 12VTAO
    12VTAO Junior Member
    Kansas City
    Wanted to give another update. After 1000 miles, the knock on startup returned. I took it to the dealership and they told me I had a warped cylinder head. It'll be $4000 for a new cylinder head. They aren't able to source a remanufactured engine at the dealership. I may shop around to see if there's anyone else local that is willing to do an engine swap.
    My other option is to just throw the car in the ocean and buy something new. I'm curious what you would do in this situation. I'd like, ideally, to make the most economical decision.
    I'm still trying to find out why the head gaskets fail. I do agree that the explanation by Gasket Masters isn't very satisfying. They aren't really describing conditions that are especially unique to Gen3 engines. You would expect all Priuses to have head gasket failures if it was just from the inordinate amount of times the engine turns on and off.
    Currently, this is my working hypothesis. I could be way off.
    Head gasket failure on Generation 3 Priuses is a result of corrosion to the head gasket material caused by unburned fuel mixing with the oil during cold starts.
    What leads me to believe this is looking at the difference between the Gen2, Gen3, and Gen4 engines.
    Gen2 and Gen4 both have system that allow the car to get up to operating temperature faster in order to increase fuel efficiency in the cold.
    Gen2 used a coolant reservoir that that could keep the coolant at 180 degrees for up to three days. The Gen 4 press release mentions a new system that gets the car up to operating temperature faster.
    Also, Gen2 and Gen4 have an engine coolant selector valve. This was removed from the Gen3, then added back in Gen4.
    The idea being that Gen3 engines spend more time operating at less than ideal temperatures, especially in cold temperatures when the car hasn't been started for a few days. A cold engine is not achieving 100% combustion and it is allowing unburnt fuel into the combustion chamber, past the those shoddy piston rings. A greater amount of the corrosive agent (fuel) in the oil is degrading the head gasket.
    Let me know if I'm completely missing something obvious here.
  8. Led
    Led Junior Member
    37
    Huntington WV
    Engine oil has additives to neutralize acids formed from the combustion process. HG corrosion is usually caused by coolant that doesn’t get changed often enough.
  9. GregC1979
    GregC1979 Active Member
    201
    121
    Nowhere
    Failed or failing water pumps also a big factor, when the coolant isn't flowing properly into the block...what happens? "Nearly" every vehicle that I see come into the shop for HG or engine related service, has a very "tight" water pump impeller or seized one. Everyone's answer is a viable one here, but there's still something else doing it...:censored:
  10. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I always scratch my head as to why this is on the inside back cover of my ‘85 300D diesel Mercedes manual. I hope that Haynes realizes that it uses glow plugs and not spark plugs! IMG_0186.jpg
  11. ChapmanF
    18,072
    A "hotter" plug is one whose own tip stays hotter, because less of it is in contact with the metal threads, and therefore it transfers less heat into the head around it.
    jzchen and Mendel Leisk like this.
  12. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Thank you for clarifying my misconception!
    iPhone ?
    Led likes this.
  13. Led
    Led Junior Member
    37
    Huntington WV
    Is water pump rpm monitored by the ecu.
  14. GregC1979
    201
    121
    Nowhere
    P261B is the waterpump code, the impeller is likely slowing down and the pump failing either because the car ran low on coolant or it's just that time and you have a lot of miles on that Original pump. I'd change it (with alot of miles on the car) before that light comes up if I were you.
  15. ChapmanF
    18,072
    The three water-pump trouble codes are P261B, P261C, and P261D. The first one is if the monitored pump RPM goes below 900 when the ECM wants it to run faster. The other two are electrical problems monitoring or controlling the pump.
    There's also the matter of the fail-safe behaviors the ECM adopts when it has given any of those codes. When it gives a P261C or P261D, it tells the pump to stop. (!) When it gives a P261B, it goes into this cycle where it tells the pump to stop for 30 seconds, run at 85% for 5 seconds, and repeat, like it might be trying to unjam something.
    Those fail-safe actions might be helpful for preventing an electrical problem from getting worse, or maybe getting the pump unjammed, but clearly they aren't recipes for cooling the engine really well. So it wouldn't be a good idea to drive around for very long with any of those codes.
    Also, with any of those codes showing, the engine will summarily shut off without further warning if the temperature ever hits 105 ℃.
    jzchen likes this.
  16. GregC1979
    201
    121
    Nowhere
    ^ usually once it detects something that magnet/impeller in the water pump has already failed or gotten so tight it's not flowing enough coolant to sufficiently keep the engine cool any more. It needs to be changed immediately or you WILL blow a head gasket or worse.
    jzchen likes this.
