Short Ram Intake
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Nov 20, 2022.
  1. CR94
    CR94 Senior Member
    2,687
    1,166
    Northwestern S.C.
    It won't if it ever encounters sub-40°F humid air.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Nope its gotten very cold here with high humid once in a while no issues.
    Grit likes this.
  3. AzusaPrius
    AzusaPrius Senior Member
    2,172
    915
    You must have poor mpg edthefox.
    The intake I have is not a cold air intake.
    This is a short ram intake and because of that it gets warmer air than normal intakes.
    This saves fuel in the winter because the ICE is not using fuel as much to keep the 180F temp since it is staying warmer easier.
    What you are doing is wasting fuel.
    Your ICE is on more than normal because of your little hack.
    Anyway Im loving this SRI and it really has made the prius run better, it may be a combination of that and the Magnaflow cat, so easy and without hassle to take on steep inclines at any speeds now.
  4. edthefox5
    10,096
    4,833
    Clearwater, Florida
    If you think the warm air coming from the engine through your intake is saving you gas your looney toons. There is already warm air coming through the throttle body after it warms up its heated by its coolant loop.
    The throttle body is already heating the air intake. Want to to make the engine warm up fast put a piece of cardboard in front of the rad people on this site have been doing that on a Prius for 15 years now. If i lived up north so would I.
    Your point doesn't matter anyway you should be driving the second you start the car.
    I got 55 mpgs with a new hybrid battery. You have no idea how an engine works.
    Your car is peppier because you have an after market cat. I saw the same exact thing when I sold my G2 cat on ebay for $1400 and used an aftermarket cat. Car ran much much better. The OEM cat is restrictive.
    And bottom line nothing will make you car faster but more fuel.
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,440
    2,404
    Taylors, SC
    I'd have to agree with you. My reasons for switching to a short arm air intake gas to do with none of the above,
    As I have stated in earlier postings, it has to do with convenience, engine compartment clearing and accessibility, and the exclusion of rodents,
    The nicest thing is that it frees up the OEM filter box area and allows me to put the oil catch can there. I can use very short hoses instead of the long hoses used by many individual installing yje can in the space behind the driver side headlight unit. occ installed Prius V 003.jpg
    #65 Georgina Rudkus, Dec 10, 2022
  6. Georgina Rudkus
    3,440
    2,404
    Taylors, SC
    This weekend, I upgraded and replaced the original K&N that HPS supplied with my short arm intake with an AEM dry filter.
    I have uploaded a new current photo of my complete set up wit the conveniently located oil catch can.
  7. AzusaPrius
    2,172
    915
    @edthefox5
    Let me ask you this...
    Does cold weather effect mpg?
    My intake gets warmer air compared to all others and it really helps in cold weather.
    Mornings where I live are below 32F right now so I save fuel because the engine is taking in warmer air.
    I do not have to deal with covering the front of my radiator and now I can access my water pump and thermostat without removing anything else.
    I hope you can grasp the concept of taking in warmer air in cold weather helps improve mpgs.
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Run with this to the next step. Why don't you build a shroud for the radiator/fans that will funnel all (or some of) the air that passes through it, into a plenum built around the air filter? That way the radiator preheats all the air going into the engine. It would be pre-warmer version of ram air. Make it removeable so you can pop it out when the weather gets warmer, or leave it in to see if hot air helps mpg in the summer.
  9. AzusaPrius
    2,172
    915
    Great news!!!!
    We already get better mpg in the summer.
    Once the ICE reaches optimum temp to burn the fuel efficiently, it will use less if it gets help keeping the temp in range.
  10. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    If you shape the shroud carefully, the radiator fan might act similar to a supercharger while it runs. As the car picks up speed, the fan will turn off, but more air will be rammed into the shroud and into the engine, especially if you enlarge the openings in the front grill a little bit.. It may make it hard for the electronics to control the engine. I guess the am air would eventually cause problems since the stock fuel pump probably wouldn't be able to keep up. You'd probably have to upgrade that to. I think 155lph pumps are fairly popular. That should do the job. The 100lph models may be a bit cheaper, but may not have enough capacity.
  11. Bill Norton
    Bill Norton Senior Member
    2,145
    734
    MONW, Ks.
    Why not create a shroud around the exhaust and feed that HOT air into the intake?
    Like they used to do...
    Is there a limit to how hot the intake air can be?
    Is there a limit to how much 'fuel savings' this theory can produce?
    Some how, I thought modern engines, with the feedback from the O² Sensor, always keep the 'air/fuel ratio' at the ideal.(n)
    Hot, cold, humid, dry, high altitude, low altitude. The engine runs as clean and as efficient as it can.
    You don't have to dik under the hood and make claims you 'improved' the design.
    Hay'L, it's hard to get two tankfuls measure the exact same MPG. How could you ever prove these claims?
    #71 Bill Norton, Dec 13, 2022
  12. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Good idea. Totally forgot about the exhaust manifold hot air take-offs that were used on the old style air cleaners!! We can shroud the air from the radiator and make it flow through a jacket formed around the exhaust manifold and then feed it to the throttle body. Then run the car's exhaust to the front of the radiator. Get a self-maintaining heat loop going and eventually fuel usage will steady out at a pretty minimum level.
  13. AzusaPrius
    2,172
    915
    Took a trip down to San Bernardino and this prius just had no problem at all over taking and passing cars with ease.
    Keeping light on the pedal and kept a 70-80mph pace without a high revving engine or having my foot pushed all the way down, sheesh not even half way down and that was going North on the 15
    I know you guys seriously like to waste time bickering back and forth for a reply from anyone but facts are facts and what I have done to my prius is made it run faster and more efficient than others.
    Now as we are all joking around here...
    My car now weighs less without the OEM air intake system. Hah!
  14. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    The obligatory question since this is a fuel efficient vehicle, what was the trip mpg?
  15. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    @AzusaPrius you did say in your initial post:
    “Let me know your thoughts…”
    I’d hate to put back the original intake every time I need a smog check, although I can’t remember if the guy even opened the hood last time.
    It seems the filter surface area may be small/smaller than the original filter. For reason(s) I don’t remember I thought the goal is to keep or increase filter surface area.
    I think most of the time someone will wait until it’s time to replace the stock filter, to install a new intake. I mean I’d be really surprised if you had a brand new air filter in there just before you replaced the stock intake with your new one. While I believe you are experiencing a true benefit, I how it would compare to a new Toyota or even performance replacement filter…
  16. AzusaPrius
    2,172
    915
    @jzchen
    I know mine looked under the hood and the car but it is so easy to remove and replace with OEM.
    I will be getting a cat shield soon but should I not get it because there is a chance the smog guy will not like it?
    Too many pros and only one con and that is having to remove it once every 2 years.
    Also I actually had a K&N filter for the OEM intake that I bought shortly after I got the car and I never oiled it.
    So I went from old beat up and sluggish OEM system then added a K&N, then to a new rebuilt engine with same K&N to new cat and now new intake.
    Trust me when I say this, I can feel the difference with each addition very easy.
    #76 AzusaPrius, Dec 13, 2022
    jzchen likes this.
  17. Bill Norton
    2,145
    734
    MONW, Ks.
    I trust that you have "Feelings. Nothing more than Feelings." [Andy Williams]
    But this is a car forum. "Numbers. Nothing matters but Numbers." [me]
    Now it's too late to gather 'Before/After' numbers.
    That leaves us with "Trust",,,,, for you and your sponsors.
    Did you really get "20 - 25% Fuel Savings" by feeding your engine 'Enhanced Air' (water)?:whistle:
    What a quality site!!!! Trust them.:rolleyes:
  18. Bill Norton
    2,145
    734
    MONW, Ks.
    Can't tell if you are serious.:whistle:
    What intake air temp will provide this 'minimum level'?
    100°?
    120°?
    150°?
    Why don't any manufacturers use such a system?(n)
    Isn't this just changing the Density Altitude of the intake air?
    How would this be different than driving at 12,000 ft. in the mountains, to the engine?
    The aero drag would remain the same...
    Georgina Rudkus likes this.
  19. Georgina Rudkus
    3,440
    2,404
    Taylors, SC
    I agree with Norton that there is no performance advantage to using a short ram air intake.
    I never expected any gain in horsepower, since I know that the air is metered by the ecu from the data provided by the maf sensor.
    The only advantage to a short ram air intake is physical. It clears away all that plastic ducting in the engine compartment and allows efficient addition of an oil catch can (OCC). With relocation, the OCC cup can be unscrewed and emptied with no additional removal of anything else. The filter is in full display and is easily visually checked every time the hood is opened. And, there is no rat trap.
    On my setup, the intake point is in the same location as the OEM intake. My new replacement AEM dry filter eliminates the oil used in the originally supplied K&N. The new filter has nearly twice the surface area of the original and will provide extended service before cleaning. Removal for cleaning takes a screwdriver to remove one worn drive hose clamp. Cleaning the filter takes 10 minutes. I'll let it dry overnight and use the K&N temporarily until I can put it back on the next day. Easy. HPS w AEM 3.JPG
    Noise is not an issue. Under normal conditions, it is not even noticeable. It only roars when the accelerator is pushed down hard.
    #79 Georgina Rudkus, Dec 14, 2022
    jzchen and Bill Norton like this.
  20. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    I figured the minimum level of fuel usage would eventually be zero, lol, when the engine shut off...
