Silver plastic cover under hood.
Discussion in 'Gen 3 Prius Main Forum' started by Carol3Jones, Dec 15, 2022.
  1. Carol3Jones
    Carol3Jones New Member
    Central Texas
    Is it okay for me to remove the silver plastic cover that surrounds the place where you put in oil. I have to add oil now and then and I cannot unscrew oil cap with it in the way and it is hard to get off and hard to put back on. I'm afraid I'm not going to get it pegged down correctly and it will do damage under there. Thank You.
  2. Tideland Prius
    16,406
    Yup that’s fine.
    there are 3 pegs IIRC.
    Carol3Jones likes this.
  3. Carol3Jones
    Central Texas
    Thank you so much. What a relief not to struggle with that silly thing.
    mollymudpie likes this.
  4. Carol3Jones
    Central Texas
    And yes there are three pegs which I have trouble lining up. One kind of slides and two pop on and the one that slides has a rubber grommet deal that's getting decrepit.
  5. Tideland Prius
    16,406
    Oh yeah. There’s that weird C-shaped one right? (Sorry I sold my Gen 3 in 2019 so I’m going off memory here).
    Yeah it’s just a decorative cover.
  6. Carol3Jones
    Central Texas
    You have a very good memory! Thanks again.
  7. xliderider
    xliderider Senior Member
    8,016
    3,198
    Honolulu, HI
    I have no problem removing my oil filler cap with the engine cover on. I use a large adjustable wrench with smooth jaws to loosely break the cap loose.
    You could even put a rag over it to protect it from the wrench, but haven't had a problem using the smooth jaws on my wrench.
    Montgomery and mollymudpie like this.
  8. ChapmanF
    16,965
    How tight is this ever-lovin' cap? I use my fingers....
  9. xliderider
    8,016
    3,198
    Honolulu, HI
    Like the plastic oil filter housing, the plastic on the oil filler cap tends to swell and becomes tight.
  10. Mendel Leisk
    40,245
    That plastic cover is purely ornamental. I pull it off whenever I'm doing an oil change, avoid possible spills on it. If you put a little dab of silicone grease on the rubber grommets on the underside it goes on and off much easier. When putting it on, I find helps with alignment to eyeball the oil filler cap: get the hole on the cover centered on it, a little further back than you think it needs to be, and squared up. Gets to be second nature.
    I'd leave it off, but knowing me I'd misplace it, and it keeps the engine bay looking "stock".
    mollymudpie and Carol3Jones like this.
  11. CR94
    CR94 Senior Member
    2,658
    1,147
    Northwestern S.C.
    Maybe somebody overtightened the cap? It should be easy with bare hands without removing the cosmetic plastic cover thingy. However, the first time I took it off I had to use a tool, because of course the dealer people had overtightened it.
    Two tricks to make removing and replacing the cover easier:
    1) Smear a tiny bit of silicone grease on the top ball of each peg;
    2) To align it before pressing down, make sure the hole for the oil cap is centered around the cap, and the length (or front edge) of the cover looks perpendicular to the length of the car.
  12. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,319
    2,324
    Taylors, SC
  13. ChapmanF
    16,965
  14. Salamander_King
    Salamander_King Senior Member
    11,001
    8,923
    New England
    Yeah, but on a regular HEV Prius, if it is being driven regularly, I can't see the mouse being able to "live" in the nest built directly above the engine. The car in the video had to be sitting undriven for a while.
    On the other hand, in my Gen4 Prius Prime which was driven often enough but not much with the engine, mice decided to build a cozy nest under the DC-DC inverter and under the hood on the hood insulation.
    Mouse nesting locations in the Prius Prime | PriusChat
    #14 Salamander_King, Dec 16, 2022
    Georgina Rudkus likes this.
  15. mollymudpie
    mollymudpie Junior Member
    Scottsdale
    Good point Thanks for posting the link
    #15 mollymudpie, Dec 19, 2022
  16. OptimusPriustus
    OptimusPriustus Active Member
    328
    136
    Finland
    Prius gen3 is the most trickiest of cars i’ve seen to add oil. Cannot align bottle freely. Not enough space
    CR94 likes this.
  17. Mendel Leisk
    40,245
    An offset funnel would help.
    I should get one, lol. I plunk a regular funnel in there (with the plastic cover off): it sits on an awkward angle, but stays put.
    Montgomery likes this.
  18. ASRDogman
    ASRDogman Senior Member
    7,015
    3,670
    You could use a funnel. Or cut a water bottle in half, and place
    the cap portion in the opening and pour the oil in....
  19. Mendel Leisk
    40,245
    I noticed @Ragingfit was using an oil bottle (with the bottom cut off) as a funnel, the kind where the neck is offset to the end, and it was wide neck, seemed like the thread diameter and pitch matched the filler cap: he sorta screwed it in. Maybe he’ll see this and comment.
  20. CR94
    CR94 Senior Member
    2,658
    1,147
    Northwestern S.C.
    Yes, offset would be best, if there's a way to keep it upright. I use a smallish regular plastic funnel, with the "silver" rocker cover in place, and the funnel resting against the cover. The drawback is that the low side of the funnel is only gently sloped, so I have to pour slowly. Without the cover, the funnel falls over. A larger regular funnel won't work.
