Most Obscure Prius Facts (Way out there)
Discussion in 'Gen 2 Prius Main Forum' started by 200Volts, Nov 20, 2006.
  1. kimgh
    kimgh Member
    297
    San Jose, CA
    <div class='quotetop'>QUOTE(Tom_06 @ Nov 28 2006, 12:18 PM) [snapback]354910[/snapback]</div>
    Hmmmm, there's nothing in there about driving off with the driver door incompletely closed. That happened to me, and I kept getting a constant beep and a very unhelpful error message. Scared the heck out of me, until I realized that the door open light was on and I closed the door. Glad that doesn't make me an idiot! :blink:
  2. Cheap!
    Cheap! New Member
    1,157
    The center seat belt in the rear seat can only be fastened to the correct fastener. They are different sizes.
    Data Daedalus likes this.
  3. GeronimoPFudgemuffin
    62
    <div class='quotetop'>QUOTE(Tideland Prius @ Nov 28 2006, 11:25 AM) [snapback]354795[/snapback]</div>
    Au contraire! I don't know how long the safety REVERSE has been used in automatic transmissions, but all the '68 Fords would NOT shift into reverse at forward speeds of more than about 3-mph or so. They just roll along in neutral until speed gets below the threshold.
    But the thing is, I would never test this lest my car be the ONLY one that ever got out of the factory with a defective bypass valve (or, in case of the Prius, faulty software).
    My buddy read it in the manual and proved it to me. Sure 'nuff, it worked as stated. If I were a betting man, I'd wager a week's pay that no current car will shift into reverse at any speed that would allow it to hurt iteself... but I'm not a betting man. Or woman.
    jrc
  4. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(kimgh @ Nov 28 2006, 07:44 PM) [snapback]355040[/snapback]</div>
    It's only part of the list.
    But whoever screwed up the (unhelpful & incorrect) door open message is perhaps a candidate. I used the "idiot" description based upon the somewhat more diplomatic phrasing on the introductory page.
    The tech training stuff has lots of good stuff in it and is way more descriptive that the boring old service manual. Definitely worth the $10 admission to the Toyota techinfo site.
    - Tom
  5. Sarge
    Sarge Senior Member
    1,323
    777
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Just thought of another one...
    Most new Prius owners do not realize that the rearview mirror is actually double-jointed, so taller drivers can simply grab firm hold of it and push UP to move it further out of their line of sight. :)
    Alternately, the mirror will actually rotate around entirely, which also gives better visibility for said tall drivers. Though I prefer option #1, since the HomeLink buttons stay on the bottom. B)
  6. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(hyo silver @ Nov 20 2006, 07:16 PM) [snapback]352386[/snapback]</div>
    Why twice? Once turns on my last selected audio device, and other presses cycle through the other devices.
    AM, FM1, FM2, CD.
    Dave M.
  7. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(GeronimoPFudgemuffin @ Nov 28 2006, 07:58 PM) [snapback]355053[/snapback]</div>
    Hmmmm. Wonder what transmission they had in that Ford Falcon (Australian) in Mad Max? It sure was going way faster than 3mph, and I remember reading that even the stunt crew was surprised when the transmission survived that "reverse stop" gig.
  8. Tideland Prius
    16,408
    <div class='quotetop'>QUOTE(dmckinstry @ Nov 28 2006, 07:05 PM) [snapback]355090[/snapback]</div>
    He's been corrected :)
  9. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    <div class='quotetop'>QUOTE(dmckinstry @ Nov 28 2006, 11:05 PM) [snapback]355090[/snapback]</div>
    You're right, I was wrong. I had admitted to this in an earlier post, and have now edited the original. My public flogging will begin at noon tomorrow.
  10. DieselConvert
    DieselConvert Member
    121
    Central Coast, CA
    <div class='quotetop'>QUOTE(JackDodge @ Nov 28 2006, 11:21 AM) [snapback]354885[/snapback]</div>
    ... and, even if they looked (unless they were linguists) they would be unlikely to find it without a link from PriusChat or similar. The index surely wouldn't give it away. :p
  11. Sufferin' Prius Envy
    3,998
    Obscure Prius Fact :
    With the dash lights on, while shifting out of the null position, the shift lever goes dark. The light for the shift knob does not actually turn off – rather, a blackout cover slides over the light and darkens the shift knob while not in the null position.
    The light and the blackout cover can be seen on the lower right side of the shift lever shaft as you move the lever towards the “N†position.
  12. prius2006rocks
    prius2006rocks New Member
    159
    CA - Central Valley
    Yeah it says like Shift Out of Neutral - Batteries Won't Charge right? Yeah I wonder why that message comes up...
    <div class='quotetop'>QUOTE(Tom_06 @ Nov 28 2006, 05:04 PM) [snapback]355057[/snapback]</div>
  13. GeronimoPFudgemuffin
    62
    <div class='quotetop'>QUOTE(Beryl Octet @ Nov 28 2006, 10:22 PM) [snapback]355094[/snapback]</div>
    Oops! I was unwittingly (how else?) engaging in a USA-centric view. I should've said, "All The 1968 US Fords." All bets are off when you jump outside my borders.
    Though this reverse safety valving may have been in effect before that year, many of us (ahem!) chronologically-challenged USA-dwellers may remember 1968 as the year the auto industry was forced to pony-up and install seat belts, buzzers, low brake fluid warning lights, key-off steering locks, and a ton of other safety items. At this point, Australia (for instance) may not necessarily have been singing from the same page of the hymnbook.
  14. dmckinstry
    1,034
    <div class='quotetop'>QUOTE(Tideland Prius @ Nov 28 2006, 07:52 PM) [snapback]355106[/snapback]</div>
    Sorry. I just responded as I got to that point in the thread. Anyway I am picking up a lot of new things in this thread. Some things I had already discovered from the owner's manual, and some things just by accident.
    Dave M.
  15. sub3marathonman
    sub3marathonman Active Member
    557
    75
    I don't know if this is an obscure Prius fact, but the lug nuts require a 21mm socket. That will be the one socket you don't have when you're ready to rotate the tires. Also, the lug nuts should be torqued to 76 ft-lbs, which is 103 Nm.
  16. Tideland Prius
    16,408
    <div class='quotetop'>QUOTE(dmckinstry @ Nov 29 2006, 06:04 AM) [snapback]355178[/snapback]</div>
    np.
    Yeah, this is definitely a good thread to browse.
    This one's in the manual:
    If the front doors are locked, pulling on the interior handle will both unlock and open the door. No need to manually unlock before getting out.
    This one I think catches most people of and so far, I've seen it incorrectly installed at all dealer/demo Priuses.
    The tray in the centre console can be installed in two places.
    1. is rearward and that's a no brainer. It fits with 3 sides touching the centre console box
    2. This one is the one where I've seen it installed incorrectly. Most people think since the first position is all the way to be back, the forward position is all the way to the front. Nope!!!
    There's a slot slightly rearward from the leading edge of the centre console. Think of it this way. Our console box has that weird vertical slot (probably an iPod holder or something). The way the tray is installed is such that that slot is still accessible. (IOW, there's about an inch or so between the edge of the console and the leading edge of the tray) If this doesn't make sense, I'll try to attach a picture.
  17. pjelkins
    pjelkins New Member
    This seems to be true on my car anyway: The odometer doesn't round to the nearest mile. It always rounds up. I've never gotten around to resetting trip meter 2, so it's presumably still registering the total mileage. I noticed a while ago when I was switching around that the odometer was higher, but it wasn't until a couple of days ago that I realized it rounds everything up. The trip meter was on 1911.0, but the odometer registed 1912.
    Pete
  18. Prius Maximus
    Prius Maximus Senior Member
    954
    806
    Northeastern IL
    <div class='quotetop'>QUOTE(Tideland Prius @ Nov 29 2006, 02:24 PM) [snapback]355337[/snapback]</div>
    Take the tray, stick it in the slot, lower the cover, you get and adjusted height armrest.
  19. Actual Mileage
    153
    Portland. Maine
    <div class='quotetop'>QUOTE(Prius Maximus @ Dec 1 2006, 01:38 PM) [snapback]356300[/snapback]</div>
    I have those 2 trays here in my office - 1 trapeziodal and 1 rectangular w/ black velvet.
    I have no idea what to do with them and I am certainly not going to read the owner's manual!
    Here is my obscure fact -
    There is no place to store change in the Prius.
    (OK - that was an attempt to find out where it is meant to go, see above manual comment.)
  20. GeronimoPFudgemuffin
    62
    Well, if sarcasm is allowed, here a couple of my "favorite" features:
    1) The LED clock won't run down your battery. Never mind that it's <ahem!> 'CAUSE THE STINKIN' THING WON'T WORK UNLESS YOU TURN THE WHOLE BLOOMIN' CAR ON! (really hoping I'm not missing something here, which would be truly embarrassing, eh-wot?)
    You'd think that, with car turned OFF, a simple dab at either of the time-set buttons might light up the LED just long enough to let me see what time it is. Or at least *I* would think; you may not.
    2) The CD player is as-above, but worse. The only way to turn-on the CD player is to boot-up the car and LEAVE IT ON. (I think) That means the MFD is assasinating electrons at an alarming rate. I would expect to hit the CD's PWR button and have it come on in some sort of "skeleton" mode, waking up just enough electronics to allow Bruckner symphonies to waft through my speakers. Why else would I haul around a 100-pound Ray-O-Vac if I can't listen to the stereo while I wash the car? But can I? Noooooo way!
    I'm sure the above "features" are saving me (or the planet) from some terrible fate. And although I can't imagine what calamity that might be, I humbly thank the Toy engineers for their care on my behalf.
    GeronimoPFudgemuffin (who really likes the car, but doesn't understand so many details being "right," while missing so many seemingly-larger points)
    <div class='quotetop'>QUOTE(Actual Mileage @ Dec 1 2006, 04:03 PM) [snapback]356382[/snapback]</div>
    Well, you're right, but not completely so. You see, even though there's no change tray, all of you can handily store all paper money in my conveniently-located trouser pockets. Need my address?
    PS: only 20s and larger, please
