2020 lift kit needed because of low clearance
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Dabiz, Dec 8, 2022.
  1. Dabiz
    Dabiz New Member
    Al
    2020 Prius
    I have a 2020 and the fro t end has scrapped across so many speed lumps and going I to my driveway that had an i clone that the front plastic under plate has ripped off and the whole plastic under shielding(no idea what its called) is sagging and is about 4 inches off the ground. I am going to take it to be fixed if possible but want to know if i am the only one with this problem. I want to have the car lifted at least a cpl inches. I see kits. So they work??
  2. 2020XLEAWD
    2020XLEAWD Member
    85
    43
    City of Angeles
    2020 Prius
    XLE AWD-e
    Prius off road sells 1.5 inch spacers. I believe they sell springs now too
  3. th3118
    th3118 Junior Member
    Mesa, AZ
    2022 Prius
    I put in the off-road 1 1/2” spacer lift in my 22. Very happy with it.
  4. avocadoman1
    avocadoman1 Member
    217
    36
    Fallbrook-CA
    2022 Prius
    I, too, added the 1-1/2” spacer to ‘22 Limited
    $350 parts
    $4-500 install (or DIY)
    $100 (+/-) for necessary toe-in alignment
    Now, no more scraping
