More cargo space…
Discussion in 'Gen 5 Prius Main Forum' started by hyhi, Dec 18, 2022.
  1. Mksky
    Mksky Member
    61
    33
    Los Angeles
    2024 Prius
    Another angle for the trunk at 8:36.
    51,021
    that was much better! i really like the extra depth
  3. daisy555
    daisy555 Senior Member
    1,644
    691
    CT
    This is a confusing video. Maybe Japanese model has Prius tires with Prime interior. I don’t recall seeing that drop of about 4-6 inches in the cargo space during the US reveals of the Prius. Maybe I missed it.
  4. CR94
    CR94 Senior Member
    2,660
    1,149
    Northwestern S.C.
    Fixable with plywood and a saw to cut it to fit?
    GuyLR likes this.
  5. Mendel Leisk
    40,459
    The Matrix had a nice hatch area, at least the earlier years with the deck and rear seat backs all durable plastic, with ridges running longitudinal. With the back seats flipped down it was a veritable cargo van, everything flat and flush.
    here the backseat’s up, but they flip down dead-flat:
    believe there’s a spare under there too.
    #25 Mendel Leisk, Jan 3, 2023
  6. bisco
    51,021
    should be, since there's no battery or charger. did it even have an independent rear suspension?
  7. bisco
    51,021
    what are prius tires?
    i don't think there were any good shots of the hatch floor in the usa reveal
  8. Hammersmith
    Hammersmith Senior Member
    1,961
    1,966
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Okay, the 2023 manual shows three different options for under the cargo floor tray:
    High options:
    1. Spare tire with white organizer pieces surrounding it that hold the jack and tools
    2. Type B white organizer(deep) - appears to be the most common - shown in all the USA XLE/Limited videos
    Pros:
    - flatter floor when rear seats are down
    - shorter lip under rear hatch to make loading/unloading easier
    Cons:
    - less total cargo space
    - cargo floor is not flat left to right; there are low pockets behind each wheel well
    Low option:
    3. Type A white organizer(shallow) - shown in the Japanese video above
    Pros:
    - more cargo space
    - flat floor from side to side
    Cons:
    - uneven floor when rear seats down
    - deeper lip that items have to be lifted over
    https://assets.sia.toyota.com/publications/en/om-s/OM47E41U/pdf/OM47E41U.pdf
    1. pg. 496
    2. pg. 485
    3. pg. 484
    Tideland Prius and daisy555 like this.
  9. GuyLR
    GuyLR Junior Member
    30
    25
    Atlanta, GA
    Only the AWD model had IRS.
    Tideland Prius likes this.
  10. bisco
    51,021
    awd matrix?
  11. Trollbait
    12,312
    They existed.
  12. bisco
    51,021
    did they have the same floor as above?
  13. daisy555
    1,644
    691
    CT
    Sorry I meant to say the car in this video has Prius hub caps. The Prime hub caps are a different design.
  14. Mksky
    Mksky Member
    61
    33
    Los Angeles
    2024 Prius
    I wonder if we can choose the low option for USA XLE/Limited trim.
  15. Hammersmith
    1,961
    1,966
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I strongly doubt it, other than ordering the other version and installing it ourselves. We'll know for sure once parts.toyota.com is updated with the new parts list. Best just to take deep breaths and wait for all the info to be available.
    daisy555 likes this.
  16. Tideland Prius
    16,428
    And a fold-flat front passenger seat back that doubled as a work surface.
    There was also that underfloor storage bin immediately behind the rear seats.
    Mendel Leisk and Trollbait like this.
  17. Trollbait
    12,312
    Mine wasn't AWD, but I can't think of any reason to have a different interior. I don't think the FWD and AWD Sienna does.
    The HHR also had the front folding front seat; nice for hauling long things like lumber or pipe. The HHR also let you mount the cargo floor higher up to make a shelf.
  18. Tideland Prius
    16,428
    @bisco the changes going to an AWD Matrix is the IRS (double wishbone) as stated above and a slight hp/tq reduction due to repositioning the exhaust pipe. 123hp vs 130hp and 118lb-ft vs 125lb-ft. In Canada, "Base 4WD" & "XR 4WD" models got standard ABS (opt on XR FWD, not available on base FWD) and automatic transmission. It was a $2,200-$2,670 upgrade for the AWD models (if you compare it to the automatic FWD models)
  19. bisco
    51,021
    did it sell well?
  20. Tideland Prius
    16,428
    Don’t think so. Most Matrix I recall seeing back then were FWD models. $20k for a base AWD was quite expensive (but still cheaper than an Impreza I think) and if you wanted the XR 4WD, it was running into Camry money at $24k. A fully loaded Corolla LE Pkg B was $23k for reference. (Leather, moonroof, 6-speaker audio)
