HID Foglight Install
Discussion in 'Gen 2 Prius Accessories & Modifications' started by cairo94507, Nov 19, 2006.
  1. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    Here is the front end without the bumper -note the styrofoam bumper pad which just pulls off.
    [attachmentid=5709]
    showing front bumper off for possible mounting points for ballasts
    [attachmentid=5707]
    other side
    [attachmentid=5710]
    The bolt at the bumper ends that must be removed to remove bumper-easy to miss. Just pull fenderwell away use a 10mm socket.
    [attachmentid=5706]
    new bulbs in bumper and harness
    [attachmentid=5711]
    new ballast (2)
    [attachmentid=5712]
    ballsts mounted with double stick tape and a cable tie to inside of bumper
    [attachmentid=5713]
    close up view
    [attachmentid=5714]
    head and fogs on
    [attachmentid=5715]
    head and fog lights on in garage
    [attachmentid=5717]
    just the fogs on in the garage
    [attachmentid=5718]
    closer view of head and fogs on
  2. Tideland Prius
    16,428
    Nice. I thought they matched the Prius' HIDs in colour?
  3. cairo94507
    923
    36
    Auburn, CA, USA
    <div class='quotetop'>QUOTE(Tideland Prius @ Nov 19 2006, 04:25 PM) [snapback]351782[/snapback]</div>
    Hey, I just ordered what DocVijay ordered. The color isn't exact, and when you see it in person it does not appear that different. So, I guess you could order a different temperature range HID to try to more closely match the headlights if you wanted. These are fine by me. I actually had my brother drive my car and follow me so I could see how they looked in the rear view mirror- big improvement over the stock lights.
    Good luck.
    Oh, sorry about the picture order; I still do not know how to add a picture and text and then another and text so they are in the order I would like......sorry.
  4. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    <div class='quotetop'>QUOTE(Tideland Prius @ Nov 19 2006, 03:25 PM) [snapback]351782[/snapback]</div>
    Yellow doesn't make a great fashion statement but it is usually better than white if the fog lights are going to be used for seeing through fog.
  5. darelldd
    6,057
    389
    Northern CA
    Thanks! Could you please go back and edit your first post and put "returns" between each of the first row of pictures. Have to scroll to read the whole thread - and that's on a 21" widescreen monitor!
  6. kdailey356
    kdailey356 New Member
    111
    <div class='quotetop'>QUOTE(darelldd @ Nov 19 2006, 07:02 PM) [snapback]351848[/snapback]</div>
    Your prius is my favorite. I have seen pictures on another thread and your car is stunning. Truly.
  7. Tideland Prius
    16,428
    <div class='quotetop'>QUOTE(seftonm @ Nov 19 2006, 02:02 PM) [snapback]351797[/snapback]</div>
    Yes, but that would be a pure yellow rather than this light yellow that halogens give off.
  8. cairo94507
    923
    36
    Auburn, CA, USA
    <div class='quotetop'>QUOTE(CapeCodPrius @ Nov 19 2006, 07:06 PM) [snapback]351850[/snapback]</div>
    CapeCodPrius,
    Thank you very much. I enjoy my car; my wife just cracks up, but likes the Prius too. Last night I went to an early Thanksgiving dinner and when friends arrived thay laughed and said you have an NSX sitting in your garage and you drive the Prius? I told them I love driving the Prius. I am going to be buying wheels and tires as my next project to replace the Scion wheels with light weight 17" wheels and try to recoup some of my mileage. Hoping to find a tire/wheel package for about $1500. Thanks again.
  9. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    sometimes the camera cant present light as our naked eye does, btw i would have probably gotten the 5500 K hid bulbs, i ordered them on ebay for my stock prius HID's 85 bucks and wow they are great. I thought cheap HID bulbs were not worth it, but the color temperature amazed me
  10. mrbigh
    3,686
    699
    Long Island, NY
    <div class='quotetop'>QUOTE(cairo94507 @ Nov 20 2006, 09:18 AM) [snapback]352041[/snapback]</div>
    Hi Cairo94507, how much of a MPG hit you have? mine dropped to - mpg since my 17TC's at 40 F/38 R psi. Besides, these TC rims are not much heavier that the OEM's, the difference is in the tire path/contact with the road surface and LRR.
  11. cairo94507
    923
    36
    Auburn, CA, USA
    <div class='quotetop'>QUOTE(mrbigh @ Nov 29 2006, 12:21 AM) [snapback]355132[/snapback]</div>
    Mrbigh
    I probably lost 3-4 MPG. As far as the weight difference, my understanding is that is was a substantial weight difference between stock and Scion wheels. Anyone out there know the actual numbers?
  12. FL Buckeye
    FL Buckeye Member
    146
    WC Florida
    cairo94507, in your first couple of pictures, are the red/black pigtails going to the fog lights part of the original wiring harness or part of the upgrade? I'm trying to decide if I need to have a quick disconnect close to the fog lights for removal of the bumper, or can just run to the lamps directly from the main harness I will be making. Thanks for any info.
    I saw some Packard Weather Pack connectors on waytekwire.com that look very similar to the 9006 connectors I already bought, minus the pigtails. I now need a good source for the denso relay as I want to install the relay in the factory position. Toyota's price is close to $50, a lot higher than the $5 Hella relay.
  13. nyprius
    nyprius Member
    385
    24
    Saratoga Springs, NY
    <div class='quotetop'>QUOTE(cairo94507 @ Nov 19 2006, 02:20 PM) [snapback]351737[/snapback]</div>
    Great job!
    Did you rewire the fogliights so they work independently of the headlights (ie: the fogs can be on regardless if the headlights are off, low or high)?
    Also, do you know anyone in New England who would install the HID fogs and wire them independent of the heahlights?
  14. Cheap!
    Cheap! New Member
    1,157
    It looks like you mounted that heat sink to the foam bumper. Do you think it could get hot enough to melt the foam?
  15. cairo94507
    923
    36
    Auburn, CA, USA
    <div class='quotetop'>QUOTE(FL Buckeye @ Nov 29 2006, 11:46 AM) [snapback]355246[/snapback]</div>
    FL Buckeye - if you look at the end of the red/blk wires you will see the factory brownish color plug that plugged into the factory bulbs in the bumper. The red/blk are part of the kit.
    <div class='quotetop'>QUOTE(nyprius @ Nov 29 2006, 02:39 PM) [snapback]355319[/snapback]</div>
    No - I still need to do that. I want them to operate with the parking lights on without the headlights. I will do it as soon as I find out how to do it easily.
  16. nyprius
    nyprius Member
    385
    24
    <div class='quotetop'>QUOTE(cairo94507 @ Nov 29 2006, 08:02 PM) [snapback]355441[/snapback]</div>
    There was a thread on PC about a year ago where someone described how to make the fogs independent from the headlights. I think it involved putting in a diode between two pins on a plug. The person that did it wasn't available to do it for others though. The work didn't seem that hard. But at 48, my soldering, wiring and sticking my head under dashboard days are over. I'm still looking for someone in New England that could do the job.
  17. Cheap!
    Cheap! New Member
    1,157
    If you need to do a mod go where we all go for documentation EVNUT.Com Darell
  18. nyprius
    nyprius Member
    385
    24
    <div class='quotetop'>QUOTE(Cheap! @ Nov 30 2006, 01:10 AM) [snapback]355578[/snapback]</div>
    Thanks! There's an excellent description of the mod on evnut.com. Darell describes the level of difficulty of the mod as easy to moderate. But that's for Darell. For others, like me, it would range from difficult, to incredibly frustrating to impossible! I wish I could just pay someone to do this. Does anyone know someone in New England that has done this mod before and is willing to do it for others for a fee?
  19. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    I'm a bit late in replying to this thread...
    Anyway, those are the same HID's I used for my fog conversion. THe color is as close as you're going to get with aftermarket. Also, the bulbs undergo a color-shift after a little while, sort of a settling in procedure and afte that they color will be very close. Mine look identical when viewed directly, and pretty darn close against my garage wall.
    ANyway, the main benefit is that the fogs now actually produce some useable light!
  20. koa
    koa Active Member
    980
    45
    Hawaii
    cairo or DocVijay, Do you have to remove the bumper to install those HID's? Thanks.
