3M Headlight Restoration Results
Discussion in 'Gen 3 Prius Main Forum' started by Noahdoge, Jan 15, 2023.
  1. Noahdoge
    Noahdoge Active Member
    183
    128
    Mississippi
  2. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    Looks good hopefully it lasts.
  3. Noahdoge
    183
    128
    Mississippi
    There’s two coats of clear coat that comes with the kit. 3m claims it will last at least two years.
    2010moneypit? likes this.
  4. Mendel Leisk
    40,467
    I see for a new 3rd gen headlight (regular, not LED) suggested retail (according to Toyota USA) is over a grand USD, and US dealership near me is asking $704. Ouch...
  5. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    After market stocks go for $60 to $75 each
  6. Noahdoge
    183
    128
    Mississippi
    C08D570A-D97A-42E4-8F84-2AF897941981.jpeg This is the exact product that was used. Less than $20 and you get to keep your good quality oem headlights.
  7. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    Headlight photo without the light on. Same like post like new tires posts but upload only front and rear car view photos only.
  8. Montgomery
    2,254
    2,241
    Orange County, CA
    Don't get me wrong Noah. I admire your work. Came out beautifully! I did this once. It does work. I just don't want to spend the time doing it. You have to do it right, in the order for it to come out the way yours did and you nailed it! Now I just buy the replacements when needed.
    Noahdoge likes this.
  9. Noahdoge
    183
    128
    Mississippi
    Thank you! Yeah that was way more work that I thought it would be. Start to finish was around 2 hours. Super messy too, especially when you get to the wet sanding stage.
    #9 Noahdoge, Jan 15, 2023
    Montgomery likes this.
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    The problem I've experienced with several aftermarket (<$100 each) headlights is the gaps between the headlight assembly and body panels and hood is whacked. I've had much better luck keeping the originals and using very fine wet/dry sandpaper and a good clearcoat.
    alftoy, Montgomery and 2010moneypit? like this.
  11. Noahdoge
    183
    128
    Mississippi
    I did this strictly for cosmetics. It’s all about the visual clarity not anything to do with the brightness… even though it did help a bit.
    Johnny Cakes likes this.
  12. PriusII&C
    PriusII&C Active Member
    370
    130
    San Jose, California
    I used the 3M kit once on my old Odyssey. Yes, it took time, and it kept the headlights clear for a couple of years. But later I used some headlight polish compound from O'reilly. It was much easier to use, and worked about as well as the 3M kit.
  13. alftoy
    alftoy Senior Member
    1,132
    514
    Saskatchewan, Canada
    Aftermarket headlamp assemblies? Either TYC or Depo CAPA certified for proper fit.
    Car-part.com for OEM assemblies sometimes as low as $50 not faded.
    Meguiars Ultimate Compound
    Meguiar&#39;s G17216 Ultimate Compound - 15.2 oz. - Walmart.com
    3M Trizact 3000 grit and 1000 grit both wet dry
    3M™ Trizact™ Performance Sandpaper 03064SRP, 3-2/3&#34; x 9&#34;, 3000 Grit, 6/Case - Walmart.com
    11 Pcs 3&#34; Drill Buffing Kit for Auto Maintenance - Walmart.com
    Spray with a UV clear coat for added protection and longevity.
    Eastwood 2K DuraSpray Clear Coat Paint
    Will have enough to do maybe 5 or more cars, like I have among family, friends.
    #13 alftoy, Jan 16, 2023
    Montgomery and Noahdoge like this.
